a problem about installing InteractionWorkflowSamples...
Hi, guys,
After finishing multimedia deployment, I tried to install InteractionWorkflowSamples, all related virtual route points, interaction queue, workbins were generated automatically, but the objects relating content analysis, response, autoacknowledge were not.
I wondered if I missed any steps or I had to create these objects using knowledge manager manually?
Kevin
I think that in the user guide it says that you have to import them manually. The files are there.
Yes, exactly, thank you, cavagnaro!!!
