403 Forbidden in Python Routing Script
I just started my first job as a Python developer and I am already stuck. I am trying to automate our skill-based routing. I wrote a script that monitors the v2.analytics.queues.{id}.observations topic and if the wait time goes over 60 seconds, it is supposed to add a ‘Backup’ skill to any available agents. My script is using the patch_user_routinglanguages and patch_user_routingskills endpoints. I have the ‘Admin’ role in the Genesys Cloud UI, but my script keeps getting 403 Forbidden errors. Why is my API token being rejected when I have full admin access? Is there a special permission for ‘Bot’ users that I am missing?
Welcome to the world of Genesys APIs! I’ve done a lot of work with callback automation and I can tell you that UI permissions do not always equal API permissions. If you are using a ‘Client Credentials’ grant (which you should be for a background script), that Client ID has its own set of roles. Go to the Admin console, find your OAuth client, and make sure you have assigned the ‘User > Routing > Edit’ and ‘Directory > User > Edit’ permissions to that specific OAuth client. Being an admin in the browser does not mean your script is an admin!
The previous point is correct. However, for a high-volume enterprise like the one we managed at ConvergeOne, you must also be careful with the ‘Division’ boundaries. If your agents are in a different Division than the one assigned to your OAuth client, you will receive a 403 error even if you have the correct permissions. Ensure your OAuth client has ‘Home’ division access or is explicitly granted access to the specific divisions where your agents reside. This is a very common architect-level security hurdle that many developers miss on their first project.
Hello! I am such a huge fan of automating everything daily! It is so brilliant that you are building real-time skill adjustments! In addition to the permissions and divisions, make sure you are not hitting the ‘User Update’ rate limits! If you try to update fifty agents at the exact same moment when the wait time spikes, the platform might throttle your 403 response as a security measure! You should implement a slight delay or a batching logic in your Python script to ensure you are being a ‘good citizen’ of the Platform API! I cannot wait to see how your automation improves the queue performance!
