Writing a TypeScript Library for Generating Genesys Cloud Architect Flow JSON Programmatically
This guide details the architecture and implementation of a TypeScript library that generates valid Genesys Cloud Architect Flow JSON. You will build a type-safe builder system that constructs flow graphs, resolves block references, handles versioning constraints, and produces deployment-ready payloads compatible with the POST /api/v2/architect/flows endpoint.
- Licensing: Genesys Cloud CX Standard or higher. Architect flows require no additional add-on, but deployment via API requires appropriate administrative access.
- Permissions:
architect:flow:edit,architect:flow:view,architect:flow:delete,organization:read - OAuth Scopes:
architect:flow:edit,architect:flow:view,offline_access - External Dependencies: Node.js 18+, TypeScript 5.0+,
zodfor runtime validation,uuidfor block ID generation.
1. Deconstructing the Architect JSON Schema and Establishing Type Safety
The Architect flow JSON is not a linear script. It is a directed acyclic graph (DAG) of blocks connected by transition conditions. Each block contains a routingId, a type, a parameters object, and an array of transitionConditions that map to other routingId values. Genesys provides a partial JSON Schema, but it lacks strict validation for cross-block references and parameter constraints.
We will define strict TypeScript interfaces that mirror the production schema while adding compile-time guards. The trap here is relying on any or loose interfaces for block parameters. When a parameter changes type in a minor Genesys release, loose typing allows invalid JSON to compile and deploy, causing silent flow failures or BLOCK_INVALID errors during runtime execution.
export interface FlowBlock {
routingId: string;
type: string;
parameters: Record<string, unknown>;
transitionConditions: Array<{
routingId: string;
label: string;
condition?: string;
defaultCondition?: boolean;
export interface ArchitectFlow {
description: string;
flowType: 'voice' | 'callback' | 'webchat' | 'email' | 'sms';
labels: string[];
outboundEmail?: string;
startNodeId: string;
blocks: FlowBlock[];
version: number;
We use uuidv4 for block IDs because Genesys requires unique identifiers across the entire flow. The routingId serves as the logical pointer for transitions. We separate id and routingId to match the exact payload structure expected by the API. The architectural reasoning here is immutability during generation. Once a block is created, its routingId must never change, or the transition graph breaks. We enforce this by generating IDs at construction time and marking them as read-only in the builder.
2. Building the Fluent DSL and Graph Construction Engine
A raw JSON generator is error-prone. We will implement a builder pattern that enforces valid transitions and prevents orphaned blocks. The builder maintains an internal registry of blocks and validates transitions against existing routingId values before finalization.
The trap in this phase is allowing circular references or dangling transitions. Genesys Cloud rejects flows with cycles, but the API error message is often generic (Flow is invalid). Detecting cycles during build time saves hours of debugging. We implement a topological sort validation before serialization.
import { z } from 'zod';
class FlowBuilder {
private blocks: Map<string, FlowBlock> = new Map();
private startBlockId: string | null = null;
addBlock(type: string, parameters: Record<string, unknown>, defaultTransition: string): FlowBuilder {
const blockId = uuidv4();
const block: FlowBlock = {
routingId: `block_${type}_${blockId.slice(0, 8)}`,
type,
parameters,
transitionConditions: [
{ routingId: defaultTransition, label: 'Default' }
this.blocks.set(block.routingId, block);
return this;
addTransition(fromRoutingId: string, toRoutingId: string, label: string, condition?: string): FlowBuilder {
if (!this.blocks.has(fromRoutingId)) {
throw new Error(`Source block ${fromRoutingId} does not exist.`);
if (!this.blocks.has(toRoutingId)) {
throw new Error(`Target block ${toRoutingId} does not exist.`);
const sourceBlock = this.blocks.get(fromRoutingId)!;
sourceBlock.transitionConditions.push({
routingId: toRoutingId,
label,
condition
return this;
setStartBlock(routingId: string): FlowBuilder {
if (!this.blocks.has(routingId)) {
throw new Error(`Start block ${routingId} does not exist.`);
this.startBlockId = routingId;
return this;
build(flowName: string, flowType: ArchitectFlow['flowType']): ArchitectFlow {
if (!this.startBlockId) {
throw new Error('Start block must be defined.');
this.validateGraph();
description: `Auto-generated flow: ${flowName}`,
flowType,
labels: ['auto-generated'],
startNodeId: this.startBlockId,
blocks: Array.from(this.blocks.values()),
version: 1
private validateGraph(): void {
const visited = new Set<string>();
const stack = new Set<string>();
const dfs = (nodeId: string) => {
stack.add(nodeId);
visited.add(nodeId);
const block = this.blocks.get(nodeId);
if (block) {
for (const trans of block.transitionConditions) {
if (stack.has(trans.routingId)) {
throw new Error(`Circular reference detected involving ${trans.routingId}`);
if (!visited.has(trans.routingId)) {
dfs(trans.routingId);
stack.delete(nodeId);
dfs(this.startBlockId!);
The builder enforces graph integrity. The validateGraph method uses depth-first search to detect cycles. We throw explicit errors during construction rather than allowing invalid JSON to reach the API. This shifts failure left. We also ensure every transition targets an existing block. The architectural decision to use a Map for block storage provides O(1) lookup during transition validation, which scales efficiently for flows with thousands of blocks.
3. Handling Parameter Serialization and Dynamic Content Injection
Architect blocks require specific parameter structures. A Queue block needs queueId. A SetContactAttributes block needs an array of attribute objects with name, value, and scope. Hardcoding these parameters defeats the purpose of programmatic generation. We will implement a parameter resolver that accepts raw values or dynamic expressions.
The trap is string interpolation for dynamic values. Genesys Cloud Architect uses a specific expression syntax (${contact.attributes.custom.someValue}). If you concatenate strings incorrectly, the platform treats the expression as a literal string. We will sanitize inputs and wrap dynamic values in the correct syntax automatically.
export const AttributeSchema = z.object({
value: z.union([z.string(), z.number(), z.boolean(), z.null()]),
scope: z.enum(['contact', 'interaction', 'custom']).default('custom')
export function buildSetAttributesBlock(
attributes: z.infer<typeof AttributeSchema>[],
): FlowBlock {
routingId: `set_attrs_${blockId.slice(0, 8)}`,
type: 'SetContactAttributes',
parameters: {
attribute: attributes.map(attr => ({
value: attr.value.toString(),
scope: attr.scope
{ routingId: defaultTransition, label: 'Complete' }
export function injectExpression(value: string | number): string {
if (typeof value === 'string' && value.startsWith('${') && value.endsWith('}')) {
return value;
return String(value);
We use Zod for runtime validation of complex parameters. This catches schema violations before JSON serialization. The injectExpression helper ensures dynamic values retain their expression syntax. We avoid manual string concatenation. The architectural reasoning here is separation of concerns. Parameter construction is isolated from graph topology. This allows reuse of block builders across different flows without duplicating transition logic.
4. Generating the Final Payload and Preparing for API Deployment
Once the graph is built and validated, we serialize it to JSON. Genesys Cloud requires the payload to conform to strict formatting. We will strip internal builder metadata and ensure the output matches the exact API contract. We also handle versioning and conflict resolution strategies.
The trap is ignoring the version field during updates. Genesys Cloud uses optimistic locking. If you submit a flow with an outdated version, the API returns a 409 Conflict. You must fetch the current version, increment it, and include it in the update payload. Failing to do this causes deployment scripts to fail intermittently in CI/CD pipelines.
export async function deployFlow(
accessToken: string,
flow: ArchitectFlow,
existingFlowId?: string
): Promise<ArchitectFlow> {
const url = existingFlowId
? `https://api.mypurecloud.com/api/v2/architect/flows/${existingFlowId}`
: 'https://api.mypurecloud.com/api/v2/architect/flows';
const method = existingFlowId ? 'PUT' : 'POST';
const headers = {
Authorization: `Bearer ${accessToken}`,
'Content-Type': 'application/json'
const body: Partial<ArchitectFlow> = {
description: flow.description,
flowType: flow.flowType,
labels: flow.labels,
startNodeId: flow.startNodeId,
blocks: flow.blocks,
version: flow.version
const response = await fetch(url, {
method,
headers,
body: JSON.stringify(body)
if (!response.ok) {
const errorText = await response.text();
throw new Error(`API Error ${response.status}: ${errorText}`);
return await response.json();
export async function handleConflictRetry(
existingFlowId: string,
maxRetries: number = 3
for (let i = 0; i < maxRetries; i++) {
return await deployFlow(accessToken, flow, existingFlowId);
} catch (error) {
if (error instanceof Error && error.message.includes('409')) {
const currentFlow = await fetchCurrentFlow(accessToken, existingFlowId);
flow.version = currentFlow.version + 1;
await new Promise(resolve => setTimeout(resolve, 1000 * (i + 1)));
} else {
throw error;
throw new Error('Max retries exceeded for conflict resolution.');
async function fetchCurrentFlow(accessToken: string, flowId: string): Promise<ArchitectFlow> {
const response = await fetch(`https://api.mypurecloud.com/api/v2/architect/flows/${flowId}`, {
headers: { Authorization: `Bearer ${accessToken}` }
if (!response.ok) throw new Error('Failed to fetch current flow version.');
The deployment module handles both creation and updates. The handleConflictRetry function implements exponential backoff with version fetching. This is critical for CI/CD environments where multiple branches may deploy flows concurrently. We fetch the latest version, increment it, and retry. The architectural decision to separate conflict handling from the core deploy function keeps the API interaction clean and testable. We also use standard fetch to avoid external HTTP client dependencies, reducing bundle size and attack surface.
Edge Case 1: Orphaned Blocks and Unreachable Nodes
The failure condition occurs when the generator creates blocks that are never referenced by any transition condition. Genesys Cloud accepts the JSON, but the flow becomes impossible to debug visually. The platform may also prune unreachable nodes during internal processing, causing unexpected behavior.
The root cause is adding blocks to the builder without linking them to the active graph. The validateGraph DFS only checks from the start node. It does not flag blocks that exist in the registry but are never visited.
The solution is to add a reachability check after DFS. Compare the visited set size against the total block count. If they differ, throw a build error listing the orphaned routingId values.
// Add to validateGraph()
if (visited.size !== this.blocks.size) {
const orphans = Array.from(this.blocks.keys()).filter(id => !visited.has(id));
throw new Error(`Unreachable blocks detected: ${orphans.join(', ')}`);
Edge Case 2: Parameter Type Coercion and Silent Failures
The failure condition manifests as blocks executing with default or null values instead of the intended dynamic data. The API accepts the JSON without error, but runtime evaluation fails silently.
The root cause is JavaScript type coercion during JSON serialization. Numbers become strings, booleans become strings, and undefined values become null or are omitted. Genesys Cloud expects strict types for certain parameters.
The solution is to enforce type checking during parameter construction. Use Zod schemas for every block type. Validate parameters before adding them to the FlowBlock object. Reject payloads that fail runtime validation. This prevents type drift from reaching the deployment stage.
Edge Case 3: Transition Condition Priority and Fallback Routing
The failure condition occurs when multiple transition conditions evaluate to true simultaneously. Genesys Cloud processes conditions in array order. If the order changes during serialization, routing logic breaks.
The root cause is using plain arrays without explicit priority markers. JSON object key order is not guaranteed in all environments, and array sorting may occur during minification or serialization.
The solution is to enforce a deterministic order. Add a priority field to the internal transition condition interface. Sort conditions by priority before serialization. Mark exactly one condition as defaultCondition: true. Validate that default conditions exist for every block to prevent dead ends.
// Update transitionConditions interface
export interface TransitionCondition {
routingId: string;
label: string;
condition?: string;
priority: number;
// In build() method, before serialization
for (const block of flow.blocks) {
block.transitionConditions.sort((a, b) => a.priority - b.priority);
if (!block.transitionConditions.some(t => t.defaultCondition)) {
throw new Error(`Block ${block.routingId} lacks a default transition.`);
