Writing a Python Script to Generate Terraform Import Blocks for Existing Genesys Cloud Resources
This guide details the construction of a Python utility that queries the Genesys Cloud REST API, extracts resource identifiers, normalizes them against provider expectations, and outputs valid Terraform import blocks. The end result is a deterministic, dependency-ordered manifest that safely bridges legacy GUI-created resources into your Terraform state without triggering destructive drift or reference resolution failures.
  • Licensing Tier: CX 1, CX 2, or CX 3 base license. API access is included in all tiers, but specific resource types require add-ons (e.g., WEM for workforce management objects, Speech Analytics for transcription resources).
  • Granular Permission Strings: The service account must hold read permissions matching the target resource types. Minimum required: routing:queue:view, user:user:view, flow:flow:view, telephony:phone-number:view, telephony:trunk:view.
  • OAuth Scopes: urn:genesys:cloud:api:read for broad discovery, or resource-specific scopes such as routing:queue:read, user:user:read.
  • External Dependencies: Python 3.9+, requests library, tabulate for CLI output, Terraform 1.5.0+ (required for native HCL import block syntax).
  • API Base URI: https://{{organization}}.mygen.com/api/v2
1. OAuth Session Initialization & Token Lifecycle Management
Terraform import operations require sustained API connectivity. Using basic authentication or short-lived user tokens introduces unnecessary failure points during bulk extraction. We implement a dedicated OAuth client credentials flow to obtain a machine-to-machine access token. This approach decouples the script from interactive user sessions and guarantees consistent scope enforcement.
The authentication request targets the Genesys Cloud identity endpoint. We structure the payload to request only the scopes required for discovery, adhering to the principle of least privilege. The response contains an expires_in field measured in seconds. We cache the token and implement a refresh trigger before expiration to prevent mid-run 401 Unauthorized responses.
import requests
GENESYS_BASE = "https://{{org}}.mygen.com"
IDENTITY_URL = f"{GENESYS_BASE}/oauth/token"
def get_access_token(client_id: str, client_secret: str, scopes: list) -> dict:
    payload = {
        "client_id": client_id,
        "client_secret": client_secret,
        "scope": " ".join(scopes)
    response = requests.post(IDENTITY_URL, data=payload, headers=headers)
    response.raise_for_status()
    data = response.json()
    data["expires_at"] = datetime.utcnow() + timedelta(seconds=data["expires_in"] - 30)
    return data
def get_valid_token(token_cache: dict, client_id: str, client_secret: str, scopes: list) -> str:
    if not token_cache or datetime.utcnow() >= token_cache["expires_at"]:
        token_cache.update(get_access_token(client_id, client_secret, scopes))
    return token_cache["access_token"]
The Trap: Caching the token without accounting for clock skew or network latency causes silent 401 failures on the final pagination request. The Genesys API rejects tokens that expire within a 30-second window. We subtract 30 seconds from the expires_in value during caching to maintain a safety margin. Additionally, using a user-bound token instead of client credentials ties the script to a specific identity that may have MFA enabled or session restrictions, causing immediate authentication failure in CI/CD pipelines.
2. Endpoint Discovery & Pagination Normalization
Genesys Cloud does not expose a single unified catalog endpoint. Resource discovery requires querying individual collection endpoints. Each endpoint implements a distinct pagination contract. Some return a flat array of IDs, others wrap results in an entities object, and several use cursor-based navigation via nextPageToken. We normalize these variations into a single generator function that yields resource dictionaries consistently.
The pagination loop respects the pageSize limit (typically 100 to 500). We calculate the total pages dynamically or follow the nextPageToken until it returns null. The script maintains a registry of discovered resources, mapping each API response to a Terraform addressable identifier.
def paginate_resources(api_path: str, token: str, page_size: int = 500) -> list:
    url = f"{GENESYS_BASE}/api/v2{api_path}"
    params = {"pageSize": page_size, "pageNumber": 1}
    resources = []
    while True:
        response = requests.get(url, headers=headers, params=params)
        # Normalize flat arrays and entity-wrapped responses
        entities = data.get("entities", data)
        if not isinstance(entities, list):
            entities = [entities]
        resources.extend(entities)
        # Handle cursor-based pagination
        if "nextPageToken" in data and data["nextPageToken"]:
            params = {"pageSize": page_size, "nextPageToken": data["nextPageToken"]}
        elif len(entities) < page_size:
            break
        else:
            params["pageNumber"] += 1
    return resources
The Trap: Assuming uniform pagination structure across all endpoints causes index errors or truncated datasets. The routing/queues endpoint returns {"entities": [...]}, while users/users returns a flat array. The flows/flows endpoint uses cursor pagination exclusively. We abstract this variance into the normalization block. Failing to handle the nextPageToken fallback breaks discovery on endpoints that deprecated offset pagination. Additionally, ignoring the pageSize cap causes the API to return a 400 Bad Request with a page_size_too_large error code.
3. Identifier Mapping & HCL Import Block Generation
Terraform import syntax requires exact alignment between the provider address and the Genesys Cloud resource identifier. The provider expects specific ID formats. Some resources use raw UUIDs, others require namespace prefixes, and a few demand composite identifiers combining multiple UUIDs. We construct a mapping dictionary that translates API responses into valid Terraform import blocks using the HCL 1.5+ syntax.
The generation function iterates through the discovered resources, applies the mapping rules, and writes the output to a .tf file. We structure the output to be immediately consumable by terraform import or terraform plan.
RESOURCE_MAP = {
    "routing/queues": {
        "tf_type": "genesyscloud_routing_queue",
        "id_field": "id",
        "prefix": None
    "flows/flows": {
        "tf_type": "genesyscloud_flow_flow",
        "id_field": "id",
        "prefix": "flow:"
    "users/users": {
        "tf_type": "genesyscloud_user_user",
        "id_field": "id",
        "prefix": None
    "telephony/phone-numbers": {
        "tf_type": "genesyscloud_telephony_phonenumber",
        "id_field": "id",
        "prefix": "phone-number:"
def generate_import_blocks(resources: list, endpoint: str, output_file: str):
    mapping = RESOURCE_MAP.get(endpoint)
    if not mapping:
        return
    with open(output_file, "a") as f:
        for res in resources:
            raw_id = res[mapping["id_field"]]
            tf_id = f"{mapping['prefix']}{raw_id}" if mapping["prefix"] else raw_id
            tf_addr = f"{mapping['tf_type']}.{res['name'].lower().replace(' ', '_').replace('-', '_')}"
            # Sanitize Terraform address
            tf_addr = "".join(c for c in tf_addr if c.isalnum() or c in "_.")
            f.write(f'import {{\n')
            f.write(f'  to = {tf_addr}\n')
            f.write(f'  id = "{tf_id}"\n')
            f.write(f'}}\n\n')
The Trap: Generating Terraform addresses without sanitization produces invalid HCL. Queue names containing spaces, hyphens, or special characters break the parser. We strip non-alphanumeric characters and enforce lowercase naming conventions. Another critical failure mode occurs when mapping composite IDs incorrectly. The genesyscloud_telephony_phonenumber resource requires the phone-number: prefix in the import ID, but the API returns only the raw UUID. Omitting the prefix causes the provider to search the wrong namespace during state initialization, resulting in a resource not found error that halts the entire import pipeline.
4. Dependency Resolution & Safe State Injection
Terraform resolves resources in a directed acyclic graph. Importing a flow that references a queue before that queue exists in state causes immediate plan failure. We implement a lightweight dependency parser that scans resource definitions for cross-references, builds a dependency graph, and orders the import blocks accordingly. Resources with no dependencies appear first. Dependent resources follow in topological order.
The script extracts reference fields (e.g., queueId, userId, flowId) from the API responses, matches them against the discovered resource list, and assigns priority weights. We then sort the import blocks by weight before writing the final manifest.
def resolve_dependencies(resources: list, endpoint: str) -> list:
    # Simplified dependency extraction for routing queues and flows
    dependency_graph = {}
        ref_ids = []
        if "queueId" in res:
            ref_ids.append(res["queueId"])
        if "userId" in res:
            ref_ids.append(res["userId"])
        if "flowId" in res:
            ref_ids.append(res["flowId"])
        dependency_graph[res["id"]] = ref_ids
    # Topological sort implementation
    visited = set()
    temp_mark = set()
    sorted_resources = []
    def visit(node_id):
        if node_id in temp_mark:
            raise ValueError("Circular dependency detected")
        if node_id not in visited:
            temp_mark.add(node_id)
            for dep in dependency_graph.get(node_id, []):
                visit(dep)
            temp_mark.remove(node_id)
            visited.add(node_id)
            sorted_resources.append(node_id)
    for res_id in dependency_graph:
        visit(res_id)
    # Reorder original resource list based on sorted IDs
    id_to_res = {r["id"]: r for r in resources}
    return [id_to_res[rid] for rid in sorted_resources if rid in id_to_res]
The Trap: Ignoring dependency ordering causes terraform plan to fail with Reference to undeclared resource errors. The Genesys Cloud architecture heavily interlinks objects. A routing queue references a user group, which references users, which reference phone numbers. Importing in random order forces manual state editing or requires repeated terraform import executions. We enforce topological sorting to guarantee that every referenced ID exists in the state file before the dependent resource attempts to bind to it. Circular references are rare in Genesys but possible in custom flow loops; the script raises an explicit error rather than entering an infinite recursion.
Edge Case 1: Composite Resource ID Mismatches
The failure condition: The import block executes successfully, but terraform plan immediately shows a drift deletion and recreation for the same resource.
The root cause: The Genesys Cloud API returns a UUID that does not match the provider’s internal ID normalization. Certain resources, such as genesyscloud_organizations_apikey, require a composite identifier format like organizations:apikey:{{uuid}}. The provider validates the ID format before querying the API. A mismatch causes the provider to treat the imported object as a separate entity.
The solution: Implement an ID normalization layer that inspects the resource type and applies the exact prefix convention documented in the provider schema. Run terraform state show on a manually imported resource to verify the expected ID format. Update the RESOURCE_MAP dictionary to include the correct prefix for each endpoint. Validate the generated blocks against a single resource before bulk execution.
Edge Case 2: Permission-Scoped Pagination Gaps
The failure condition: The script completes without errors, but the resulting import manifest contains fewer resources than expected. Critical queues or flows are missing.
The root cause: The OAuth client credentials are bound to a service account with restrictive RBAC policies. Genesys Cloud filters API responses at the authorization layer. If the account lacks routing:queue:view for a specific division, the endpoint silently omits those queues from the pagination response. The script cannot distinguish between an empty endpoint and a permission-filtered response.
The solution: Audit the service account’s roles against the target divisions. Assign the admin:admin role or create a custom role with explicit division-scoped read permissions for all target resource types. Alternatively, implement a fallback discovery mechanism using the search/v2/search endpoint, which supports cross-division queries when granted search:search:read scope. Cross-reference the search results with the collection endpoints to identify permission gaps.
Edge Case 3: Terraform State Locking During Bulk Import
The failure condition: The import process hangs or returns Error acquiring the state lock after processing 30-50 resources.
The root cause: Genesys Cloud resources with high cardinality (e.g., users, phone numbers) trigger extensive provider validation during import. Each import request locks the state file, performs a remote read, writes the object, and releases the lock. Sequential execution under default timeouts causes lock contention, especially when combined with WFM or Speech Analytics resources that require external service synchronization.
The solution: Execute imports in batches of 10-15 resources. Insert a 2-second delay between batches to allow the state backend to commit and release locks. Configure the Terraform backend with increased lock_timeout and retries parameters. For state backends supporting concurrency (e.g., S3 with DynamoDB), enable parallel state operations. Monitor the terraform.tfstate.backup file for partial writes that indicate interrupted transactions.
