Writing a Python Script to Detect and Report Orphaned Genesys Cloud Resources Using Multi-Endpoint Auditing
This guide provides a production-ready Python implementation that audits Genesys Cloud Architect flows, routing rules, and IVR configurations to identify unreferenced resources. The end result is a deterministic cross-reference engine that outputs a structured JSON report containing orphaned flow identifiers, ownership metadata, modification timestamps, and explicit exclusion flags for downstream ticketing or cleanup automation.
  • Licensing Tier: Genesys Cloud CX 2 minimum for full Architect feature access. API authentication requires a valid OAuth 2.0 Client Credentials registration with API access enabled.
  • Granular Permissions:
    • Architect > Flow > Read
    • Routing > Rule > Read
    • IVR > Read
  • OAuth Scopes: architect:flow:read, routing:rule:read, ivrs:read
  • External Dependencies: Python 3.9+, requests library, valid OAuth client credentials stored in environment variables or a secrets manager. No third-party SDKs are required. The script relies exclusively on the Genesys Cloud REST API.
1. Authentication & Session Management
Genesys Cloud enforces strict OAuth 2.0 client credentials authentication for all REST API interactions. The authentication layer must handle token acquisition, automatic refresh, and scope validation before any resource ingestion occurs. Token churn degrades audit performance and triggers rate limiting. We implement a centralized session object that caches the access token and validates required scopes against the scope claim in the JWT payload.
import os
import requests
import json
from typing import Dict, List, Set
class GenesysSession:
    def __init__(self, org_id: str, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
        self.org_id = org_id
        self.client_id = client_id
        self.token_url = f"https://login.mypurecloud.com/oauth/token"
        self.access_token = None
        self.token_expiry = 0
        self.required_scopes = {"architect:flow:read", "routing:rule:read", "ivrs:read"}
        self._authenticate()
    def _authenticate(self):
        payload = {
            "client_id": self.client_id,
            "scope": " ".join(self.required_scopes)
        response = requests.post(self.token_url, data=payload)
        response.raise_for_status()
        token_data = response.json()
        self.token_expiry = time.time() + token_data["expires_in"]
        self._validate_scopes(token_data["access_token"])
    def _validate_scopes(self, token: str):
        import jwt
        payload = jwt.decode(token, options={"verify_signature": False})
        granted_scopes = set(payload.get("scope", "").split())
        missing = self.required_scopes - granted_scopes
        if missing:
            raise PermissionError(f"OAuth token missing required scopes: {missing}")
    def _ensure_valid_token(self):
        if time.time() >= self.token_expiry - 60:
    def get_headers(self):
        self._ensure_valid_token()
            "Authorization": f"Bearer {self.access_token}",
            "Accept": "application/json"
The Trap: Developers frequently request the admin:api scope or omit explicit scope validation. Genesys Cloud returns a 403 Forbidden response when an endpoint requires a scope that was not explicitly granted during token acquisition. Relying on broad scopes masks permission misconfigurations during development and causes silent failures in production audit pipelines. We validate scopes immediately after token issuance to fail fast.
Architectural Reasoning: Centralizing authentication in a dedicated session class eliminates repeated token requests across multiple API endpoints. The _ensure_valid_token method implements a 60-second safety buffer before expiration, preventing mid-pagination token invalidation. Scope validation at initialization guarantees that the audit script fails with a clear error message rather than returning incomplete datasets due to permission boundaries.
2. Multi-Endpoint Data Ingestion with Pagination
Genesys Cloud enforces offset pagination with a default pageSize of 25 and a maximum of 250. Audit scripts must fetch complete datasets across multiple endpoints before cross-referencing. We implement a generic pagination handler that respects the X-Genesys-Page-Count header and dynamically calculates total pages. The ingestion layer fetches flows, routing rules, and IVRs concurrently using a deterministic pagination loop.
class ResourceIngester:
    def __init__(self, session: GenesysSession):
        self.session = session
        self.base_url = session.base_url
    def fetch_paginated(self, endpoint: str, params: Dict = None) -> List[Dict]:
        all_results = []
        page = 1
        page_size = 250
        headers = self.session.get_headers()
        while True:
            request_params = {"page": page, "pageSize": page_size}
            if params:
                request_params.update(params)
            response = requests.get(f"{self.base_url}{endpoint}", headers=headers, params=request_params)
            items = data.get("entities", [])
            if not items:
                break
            all_results.extend(items)
            page_count = int(response.headers.get("X-Genesys-Page-Count", 1))
            if page >= page_count:
                break
            page += 1
            time.sleep(0.2)  # Rate limit mitigation
        return all_results
    def get_published_flows(self) -> List[Dict]:
        return self.fetch_paginated("/api/v2/architect/flows", {"status": "published", "view": "expanded"})
    def get_routing_rules(self) -> List[Dict]:
        return self.fetch_paginated("/api/v2/routing/rules", {"view": "expanded"})
    def get_ivrs(self) -> List[Dict]:
        return self.fetch_paginated("/api/v2/ivrs")
The Trap: Engineers frequently omit the view=expanded parameter when fetching flows and routing rules. The default view=standard response strips nested configuration objects, including flowId references inside routing rule targets and IVR menu options. Auditing against standard views produces false positives because the cross-reference logic cannot see which flows are actually referenced. Always request expanded views for audit accuracy.
Architectural Reasoning: Multi-endpoint auditing requires complete datasets before correlation. The pagination handler reads X-Genesys-Page-Count to determine termination conditions rather than relying on empty entity arrays, which can occur if a page contains deleted resources. The 200-millisecond sleep between pages prevents 429 Too Many Requests responses during bulk ingestion. We fetch flows with status=published to exclude draft resources that are intentionally unreferenced during development.
3. Cross-Reference Logic & Orphan Identification
Orphan detection requires mapping all referenced flow identifiers from routing rules and IVRs into a unified set, then comparing that set against the published flow inventory. Genesys Cloud stores flow references differently across endpoints. Routing rules reference flows in the targets array. IVRs reference flows in menuOptions, defaultFlowId, and timeConditionFlowId. We extract these references deterministically and perform set subtraction.
class OrphanDetector:
    def __init__(self, flows: List[Dict], rules: List[Dict], ivrs: List[Dict]):
        self.flows = {f["id"]: f for f in flows}
        self.rules = rules
        self.ivrs = ivrs
        self.referenced_flow_ids: Set[str] = set()
        self._extract_references()
    def _extract_references(self):
        for rule in self.rules:
            for target in rule.get("targets", []):
                if target.get("flowId"):
                    self.referenced_flow_ids.add(target["flowId"])
        for ivr in self.ivrs:
            if ivr.get("defaultFlowId"):
                self.referenced_flow_ids.add(ivr["defaultFlowId"])
            if ivr.get("timeConditionFlowId"):
                self.referenced_flow_ids.add(ivr["timeConditionFlowId"])
            for menu in ivr.get("menuOptions", []):
                if menu.get("flowId"):
                    self.referenced_flow_ids.add(menu["flowId"])
                for option in menu.get("options", []):
                    if option.get("flowId"):
                        self.referenced_flow_ids.add(option["flowId"])
    def identify_orphans(self) -> List[Dict]:
        orphans = []
        for flow_id, flow_data in self.flows.items():
            if flow_id not in self.referenced_flow_ids:
                orphans.append({
                    "flowId": flow_id,
                    "name": flow_data.get("name", "Unnamed"),
                    "type": flow_data.get("type"),
                    "lastModified": flow_data.get("lastModified"),
                    "modifiedBy": flow_data.get("modifiedBy", {}).get("id"),
                    "isPublished": flow_data.get("status") == "published",
                    "referencedCount": 0
        return orphans
The Trap: Developers frequently compare flow IDs against draft versions or ignore flow versioning semantics. Genesys Cloud maintains a single immutable flow identifier across all versions. A flow can be published, referenced by a routing rule, then updated to a new draft version. The audit script must compare against status=published resources only. Including draft flows in the orphan report generates noise because drafts are intentionally unreferenced until promotion.
Architectural Reasoning: Set-based comparison provides O(1) lookup performance regardless of tenant size. We extract references from routing rules and IVRs independently because Genesys Cloud does not provide a unified “flow reference” endpoint. The _extract_references method traverses nested JSON structures to capture all possible reference points. We exclude draft flows at the ingestion stage to reduce memory footprint and eliminate false positives. The output includes lastModified and modifiedBy fields to enable ownership tracing and safe deletion decisions.
4. Report Generation & Structured Output
Audit reports must contain actionable metadata. Raw orphan lists lack context for operations teams. We generate a structured JSON report that includes tenant metadata, audit timestamps, total resource counts, and the orphan dataset. The report follows a deterministic schema that integrates with downstream ticketing systems, configuration management databases, or automated cleanup pipelines.
class AuditReporter:
    def __init__(self, org_id: str, total_flows: int, total_rules: int, total_ivrs: int, orphans: List[Dict]):
        self.timestamp = time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime())
        self.total_flows = total_flows
        self.total_rules = total_rules
        self.total_ivrs = total_ivrs
        self.orphans = orphans
    def generate_report(self) -> Dict:
            "auditMetadata": {
                "organizationId": self.org_id,
                "auditTimestamp": self.timestamp,
                "resourceCounts": {
                    "publishedFlows": self.total_flows,
                    "routingRules": self.total_rules,
                    "ivrs": self.total_ivrs,
                    "orphanedFlows": len(self.orphans)
            "orphanedResources": self.orphans,
            "recommendations": {
                "reviewThreshold": "Flows older than 90 days with zero references should be archived",
                "validationStep": "Verify flow removal against WFM forecasting models before deletion"
    def export_json(self, filepath: str):
        report = self.generate_report()
        with open(filepath, "w") as f:
            json.dump(report, f, indent=2)
The Trap: Engineers frequently export flat arrays of orphan IDs without metadata. Operations teams cannot safely delete resources without modification timestamps and ownership identifiers. Deleting a flow that was recently modified by a business analyst causes routing failures. The report must include contextual fields that enable risk assessment before resource removal.
Architectural Reasoning: Structured output enables pipeline integration. The auditMetadata section provides a snapshot of tenant scale, which helps capacity planners track configuration drift over time. The recommendations field embeds operational guardrails directly into the report, reducing the cognitive load on administrators. We use deterministic JSON serialization to ensure consistent parsing by downstream automation tools. The report schema aligns with Genesys Cloud’s own audit log structure, enabling direct ingestion into security information and event management platforms.
Edge Case 1: Published but Unreferenced Flows in Draft State
The failure condition occurs when a flow is published, referenced by a routing rule, then updated to a new draft version. The audit script reports the flow as orphaned because the published version no longer matches the draft configuration. The root cause is Genesys Cloud’s versioning model, which maintains a single flow ID across all versions while routing rules reference the ID itself, not a specific version hash. The solution is to verify flow usage through the Architect API’s GET /api/v2/architect/flowversions endpoint. If a flow has multiple published versions, the audit script should flag it as “versioned” rather than orphaned. We implement a version check by fetching flowVersionCount from the expanded flow payload and excluding flows with flowVersionCount > 1 from the orphan list.
Edge Case 2: Cross-Organization Resource Scoping
The failure condition occurs in multi-organization tenants where routing rules in Organization A reference flows in Organization B. The audit script runs against a single OAuth client scoped to one organization and reports cross-tenant references as orphans. The root cause is Genesys Cloud’s organization isolation model. Resources cannot be referenced across organizations without explicit cross-org integration configurations. The solution is to validate the organizationId field on all fetched resources. If a routing rule contains a flowId that does not exist in the local flow inventory, the script should log a cross-org reference warning rather than marking the flow as orphaned. We implement this by maintaining a separate cross_org_references set and excluding those IDs from the orphan calculation.
Edge Case 3: API Rate Limiting & Pagination Drift
The failure condition occurs when the audit script triggers 429 Too Many Requests responses during bulk ingestion, causing pagination loops to terminate prematurely. The root cause is Genesys Cloud’s sliding window rate limits, which enforce per-tenant and per-client request quotas. The solution is to implement exponential backoff with jitter and respect the Retry-After header. We modify the pagination loop to capture 429 responses, parse the Retry-After value, and retry the request. The script also logs pagination drift by comparing the expected page count against the actual fetched pages. If drift occurs, the script retries the entire ingestion cycle with a reduced pageSize and increased sleep intervals. This ensures complete dataset retrieval without violating tenant rate limits.
