Why is my EventUser not being delivered correctly?
I am using Genesys SDK to connect to T-Server and exchange messages between agents using RequestUserEvent.
I see EventUserData but it is not being propagated to the client. Why, god, why?
10:56:18.075 Trc 04541 RequestDistributeUserEvent received from [440] (00000007 121.21.65.158:2973)
message RequestDistributeUserEvent
AttributeReferenceID	23
AttributeThisDN	'3447'
AttributeUserData	[23] 00 01 00 00..
	'TestKey'	'TestValue'
AttributeCommunicationDN	'3447'
10:56:18.075 Int 04543 Interaction message “RequestDistributeUserEvent” received from 440 (“”)
@10:56:18.0750 [0] 7.5.009.00 send_to_client: message EventACK
AttributeEventSequenceNumber	000000000000009a
AttributeTimeinuSecs	75000
AttributeTimeinSecs	1214445378 (10:56:18)
AttributeUserEvent	RequestDistributeUserEvent
10:56:18.075 Trc 04542 EventACK sent to [440] (00000007 121.21.65.158:2973)
@10:56:18.0750 [0] 7.5.009.00 distribute_user_event: message EventUserEvent
AttributeEventSequenceNumber	000000000000009b
AttributeUserEvent	EventUserEvent
10:56:18.075 Trc 04542 EventUserEvent sent to [404] (00000004 StatServer 121.21.65.160:3743)
10:56:18.075 Trc 04542 EventUserEvent sent to [392] (00000003 RoutingStatServer 121.21.65.160:3742)
10:56:18.075 Trc 04542 EventUserEvent sent to [372] (00000002 OCS 121.21.65.160:3741)
Where is sent to [XXX (My Client))?
And yes, I have registered 3447:
16:47:20.527 Trc 04541 RequestRegisterAddress received from [440] (0000003e 121.21.65.158:2973)
message RequestRegisterAddress
AttributeRegisterMode	0
AttributeControlMode	0
AttributeAddressType	1 (DN)
AttributeReferenceID	9
(tservice_proc) ControlMode set to 1 for 3105
@16:47:20.5270 [gctmi] Distributing request RequestRegisterAddress
@16:47:20.5270 [tsgctm] Address [3447,tDN,sIDLE] reqRegisterAddress
@16:47:20.5270 [gctmi] request RequestRegisterAddress removed from reqMgr
@16:47:20.5270 [0] 7.5.009.00 send_to_client: message EventRegistered
AttributeEventSequenceNumber	00000000000010fe
AttributeTimeinuSecs	527000
AttributeTimeinSecs	1214293640 (16:47:20)
AttributeExtensions	[144] 00 07 01 00..
	'AgentStatus'	3
	'queue-1'	'4871'
	'AgentStatusTimestamp'	1214293278
	'AgentLoginTimestamp'	1214293278
	'AgentWorkMode'	4
	'mwl'	0
	'status'	0
AttributeAgentID	'5173'
16:47:20.527 Trc 04542 EventRegistered sent to [440] (0000003e 121.21.65.158:2973)
Ok,
first of all, it seems like both of your clients use the same connection to T-Server:
16:47:20.527 Trc 04542 EventRegistered sent to [440] (0000003e 121.21.65.158:2973).
Are you by any chance using our GAS Server? Looking through the log, it seems like our GAS Server framework based on platform SDK. Am I right? If so, you cannot get the event back, because both of your clients are behind GAS, thus
Genesys T-Server would not return Event to it, because that connection is seen as originator of the request, thus only Ack would be returned to it.
I wonder if there is a different way to do it. Let me see what is going on.
Hi, Vic,
you are right, we are using STAR’s GAS 1.0 with Platform SDK. I wanted to modify the functionality so we would get the messages that agents send to each other inside tserver logs, by modify userEvent to issue RequestDistributeUserEvent.
PP
Hey,
I actually know who you are :slight_smile:
Well, it would not work; however, it should be fine, because GAS would not only issue a message to T-Server but actually if it determines that the other user is on the same GAS server, it will also forward the event directly to that user as well. I like your concept of adding RequestDistributeUserEvent because it means you could then exchange messages between two separate GAS servers. I think we should add it as default. Very nice thinking!
