Why does this setting cause a 400 error when replicating Zendesk macro logic?
How come this setting causes a 400 error when replicating Zendesk macro logic?
Migrating ticket routing to Genesys Cloud Architect flows feels like translating poetry into code. The Zendesk macro mapping seems straightforward on paper, but the implementation details are biting us hard. We are trying to replicate a simple “Set Status to Pending” macro using the set-interaction block in Architect.
The API returns:
 "errors": [
 "Invalid interaction attribute mapping for field: custom_status_code"
We have verified the attribute exists in the Interaction Settings. In Zendesk, this was just a tag update. Here, it requires a specific enum value. Is there a hidden dependency on the IVR language pack? We are using the default English (US) pack, but the error persists even when we hardcode the string value.
Has anyone successfully mapped Zendesk ticket status updates to Genesys Interaction attributes without using a custom integration? The documentation is sparse on exact field name mappings for legacy Zendesk imports.
My usual workaround is to bypassing the Architect UI’s implicit mapping for interaction attributes and instead leveraging a Data Action to directly update the ServiceNow ticket state via REST API. The set-interaction block in Architect is designed for Genesys Cloud internal data models, not for translating external CMS logic like Zendesk macros. When you attempt to push a “Pending” status directly into an interaction attribute that expects a specific Genesys enum, the API throws a 400 because the schema validation fails.
The more robust pattern for ServiceNow integrations is to capture the macro trigger in Architect, pass the interaction ID to a Data Action, and then call the ServiceNow REST API to update the incident state. This decouples the Genesys routing logic from the CMS state management.
Here is the recommended Data Action payload structure:
 "data": {
 "method": "PATCH",
 "url": "https://instance.service-now.com/api/now/v1/table/incident/{{incident_sys_id}}",
 "headers": {
 "Authorization": "Basic {{encoded_credentials}}",
 "body": {
 "state": 3,
 "comments": "Status updated to Pending via Genesys Cloud Architect macro"
This approach avoids the schema mismatch entirely. The set-interaction block should only be used for setting Genesys-specific attributes like wrap_up_code or queue. For external CMS updates, direct REST calls through Data Actions are significantly more reliable and easier to debug. Check the ServiceNow documentation for the specific state value corresponding to “Pending” in your instance, as it varies by version. Also, ensure the OAuth token or basic auth credentials are scoped correctly to allow write access to the incident table.
This is actually a known issue…
The error stems from mismatched enum values. Genes Cloud expects specific internal states, not Zendesk strings. Try mapping “Pending” to status: "pending" explicitly in the set-interaction payload. Ensure the target attribute accepts string inputs, not just predefined enums.
