Why does this config cause a 400 error when replicating Zendesk macro logic?
Migrating ticket routing to Genesys Cloud Architect flows feels like translating poetry into code. The Zendesk macro mapped perfectly to a simple Set Variable block, but the API rejects the JSON payload with a ‘Invalid Flow Data’ error. The documentation mentions a strict schema for digital channel inputs, yet the error logs remain vague. Is there a hidden dependency in the flow structure that differs from the Zendesk ticket form fields? The migration feels stalled without a clear mapping strategy for these complex variables.
Take a look at at the schema validation for digital channel inputs. The setVariable block often fails if the variable type isn’t explicitly defined as string in the JSON payload.
resource "genesyscloud_flow" "zendesk_migration" {
set_variable {
name = "ticket_priority"
value = "high"
type = "string" # Explicit type required
Verify the type declaration matches the Zendesk macro output format.
How I usually solve this is by checking the concurrent connection limits on the load generator side. The 400 error during migration isn’t always a schema issue; it can be a capacity throttle when the API tries to validate large JSON payloads under high concurrency. If you are using a tool like JMeter to test the flow import, ensure your thread group isn’t hitting the WebSocket handshake limits for BYOC edges. The documentation suggests splitting the flow into smaller chunks if the payload exceeds 500KB.
Here is a quick config tweak for your JMeter script to avoid the 403/400 spike:
<HTTPSamplerProxy guiclass="HttpTestSampleGui" testclass="HTTPSamplerProxy" testname="Flow Import" enabled="true">
<stringProp name="HTTPSampler.domain">api.mypurecloud.com</stringProp>
<stringProp name="HTTPSampler.port">443</stringProp>
<stringProp name="HTTPSampler.protocol">https</stringProp>
<stringProp name="HTTPSampler.path">Describe the operation in prose instead of citing any path</stringProp>
<stringProp name="HTTPSampler.method">POST</stringProp>
<elementProp name="HTTPsampler.Arguments" elementType="Arguments" guiclass="HTTPArgumentsPanel" testclass="Arguments" testname="User Defined Variables" enabled="true">
<collectionProp name="Arguments.arguments">
<elementProp name="flow" elementType="HTTPArgument">
<boolProp name="HTTPArgument.always_encode">false</boolProp>
<stringProp name="Argument.Value">{"name":"Test","type":"voice"}</stringProp>
</elementProp>
</collectionProp>
</elementProp>
</HTTPSamplerProxy>
Keep the payload small and the concurrency low. The Genesys Cloud API chokes on large chunks during peak load windows. Try changing the type to string as suggested above, but also reduce your JMeter threads to 10. This usually resolves the “Invalid Flow Data” error. More details in this support article: https://support.genesys.cloud/article/12345
