when transfer a call, connid same or not?
Hi expert,
As per my understanding..
  1. when agent 1 transfer a call to agent2 (in same site,switch), same conn id should be there (as per my understanding)..but i have seen in application log, different connid for both the call.
    2)if agent 1, transfer a call to agent 2 (different switch).. diff conn id should be generated..i have seen also the same
    3)for conference call..also i have seen new conn id
is it correct?
in which case new connid will be generate ? (in transfer call)..what about for conference call?
Raja
It depends on used PBX type, multi-site configuration on Genesys level and used type of the transfer.
whenever , there is any transfer,conference..(within site and outside), i have seen, new connection id , has been generated? is that correct?
there is one blog, which i read here..which were confusing..so i ask this question..
Raja
It depends on configuration, but in general, for consultation is generated new ConnID. For multi-site calls as well (in almost cases).
I have seen it for conference as well.is that expected?
Hello @raja12398
I’m facing the same issue, can you tell me how did you resolve it ?
Regards.
