conn, _, err := upgrader.Upgrade(w, r, nil)
if err != nil {
log.Fatal(err)
for {
_, message, err := conn.ReadMessage()
if err != nil {
break
var evt MediaEvent
json.Unmarshal(message, &evt)
buffer = append(buffer, evt.Transcript)
if len(buffer) > 20 {
buffer = buffer[1:]
Running this against the media events stream on go 1.21.3 gives a steady stream. Health check pings every 30 seconds aren’t catching the stale connections before the buffer overflows. Trying to catch a language shift and swap the transcription model mid-call. The payload shows languageCode: "en-US", but the confidence field stays locked at 0.99 even when the agent switches to spanish. It’s dropping fragments when the confidence score dips below 0.6. gRPC downstream is choking on the malformed chunks. Failover to the backup endpoint just duplicates the stream. Don’t see a way to force model switching via headers. Thinking I need to rewrite the buffer logic entirely
The slice buffer is eating your fragments because it ignores event boundaries and language context changes. Genesys Cloud sends a languageCode field with every media event, and switching languages triggers a sequence reset. You’re appending raw strings without checking if the session actually shifted. It’ll drop data fast.
var currentLang string
var buf []string
for {
mt, message, err := conn.ReadMessage()
if err != nil { break }
if mt == websocket.PingMessage { continue }
var evt MediaEvent
if evt.LanguageCode != currentLang {
// flush or log buf here
currentLang = evt.LanguageCode
buf = nil
buf = append(buf, evt.Transcript)
Check the sequence field too. If it jumps backward, you hit a language switch or stream reset. The platform won’t queue cross-language fragments. Just drop the old buffer and start fresh on the new session ID. Ping frames get dropped if you don’t handle them. Connection dies in 30 seconds. Watch your token expiry on the auth handshake while you’re at it.
That slice approach totally misses the context reset. When the stream flips languages, Genesys Cloud es a fresh sequence ID and drops the old context window. If the buffer doesn’t clear, the auto-answer suggestion engine starts matching against stale fragments. That’s why the KB article surfacing breaks during chatbot handoffs. The language code change acts as a hard boundary. Flushing the slice right there keeps the agent assist panel from pulling unrelated articles.
Does the sequence reset happen before or after the first transcript fragment arrives? The docs aren’t super clear on the exact millisecond timing.
The raw logs show this: WARN 2024/05/12 14:02:11 context mismatch on lang switch, buffer size: 42...
The rest got cut off when the webhook timeout hit.
You’re probably missing the allowCrossOrigin flag in your WebSocket config, which silently drops fragmented payloads before they hit your buffer. genesyscloud-client-app-sdk handles the stream routing differently when you enable strict media event validation. First, the runtime checks the languageCode property against the active session context, then it flushes the queue using mediaEventService.clearBuffer(). If you skip that step, the SDK keeps appending stale fragments to the wrong language window. Don’t forget to map the sequence IDs manually.
Initialize your connection with the media:events:read scope so the gateway actually es full sequence IDs.
Watch for the onLanguageChange callback instead of manually parsing the raw string, since evt.languageCode != currentLang triggers a hard reset under the hood.
Route the cleared buffer straight to your custom desktop UI via desktopAPI.publish('transcript:update', payload) to avoid race conditions.
The transcription stream drops fragments when the languageCode shifts. The buffer accumulates stale context instead of flushing on the sequence reset. This breaks the CI validation step, and it’ll hang the pipeline if the mock client keeps polling.
Previous runs threw a context deadline exceeded during the artifact upload phase. The pipeline kept hanging. Buffer never cleared. Mock client just times out on the validation endpoint.
Question
You don’t need to manually zero the slice if you swap it out. Is there a cleaner way to handle the flush?
Run the WebSocket consumer inside a dedicated docker://golang:1.21 container to isolate the network stack from the runner.
Add a timeout-minutes action step so the job fails fast instead of hanging on the buffer overflow.
Cache the go.sum file using actions/cache@v3 to speed up the dependency resolution across matrix builds.
Validate the languageCode payload against a static JSON schema before appending to the buffer.
Keep the slice capacity fixed at 50 to prevent memory spikes during rapid language toggles.
Confirmed the slice reset works in the CI pipeline. The buffer clears exactly when the sequence ID rolls over. No more dropped fragments during the language switch.
