WebSocket Channel Subscriptions - Dropped Events After Reconnect
We’re on Genesys Cloud, notification_api, using the WebSocket channel subscription for conversation events - specifically conversations.v2.detail. Been battling the baked-in reconnection issues again. It seems like after a standard WebSocket disconnect/reconnect (which is a whole separate headache, seriously, the retry logic is… something), we’re dropping events for a period - typically around 10-20 seconds.
First tried increasing the heartbeat interval to 15s, no change. Then implemented a more aggressive reconnection strategy - just yeet this into prod, see what happens - still losing events. The logs show a successful reconnection, a new READY event, but then nothing until the existing conversation state is re-published.
Here’s the initial WebSocket handshake - standard stuff.
GET /api/v2/channels/websockets HTTP/1.1
Host: genesyscloud.com
Connection: Upgrade
Sec-WebSocket-Version: 13
Sec-WebSocket-Key: dGhlIHJlYWxseSBjb29sIGtub2NrcyB3ZWIgc29ja2V0cw==
Upgrade: websocket
The expected behavior is that events should continue flowing after reconnect. Is the event stream not reliably buffering during a disconnection, or is something else completely broken? This happens in both dev and staging. It’s not a client-side issue, I’m pretty sure.
PlatformClientV2 handles the subscription state by buffering events internally during a reconnect - think of it like a temporary holding pen. The default buffer is small. Increase the maxEventBuffer property to, say, 60, via the subscription options.
 "channels": ["conversations.v2.detail"],
 "maxEventBuffer": 60
10-20s sounds like the buffer clearing.
Tried bumping maxEventBuffer to 60, then 100, then just threw 200 at it - still losing events, but now it’s intermittent and sometimes duplicates show up after the gap. It’s not a consistent delay anymore, more like a chaotic burst of late data. The reconnect itself is still taking a solid 8-10s, which feels wrong.
