Running into a wall with the WebSocket subscription for agent assist suggestions inside the Electron main process. The ws://api.mypurecloud.com/api/v2/notifications/channels/{channelId}/subscriptions endpoint is accepting the initial CONNECT frame, but the subsequent SUBSCRIBE payload for suggestions is returning a 403 Forbidden on the server side. The OAuth token definitely has the agentassist:suggestions:read scope.
The subscription JSON looks like this:
"id": "sub-001",
"event": "suggestions",
"data": {
"interactionId": "uuid-here",
"contextWindow": 500,
"filters": ["knowledge", "script"],
"confidenceThreshold": 0.85
Validating subscription schemas against concurrent connection quotas is supposed to prevent resource exhaustion, yet the error logs point to a timeout in the content library fetch service. The suggestion type filters are returning empty arrays even though the content library has matching articles. Dropping the raw buffer from the incoming binary frames, the parser is throwing ERR_BUFFER_OUT_OF_BOUNDS because the frame length header doesn’t match the payload size. It’s possible the Genesys WebSocket server is compressing the suggestion objects or using a custom framing format that Node’s standard ws library isn’t handling correctly.
Implementing the suggestion stream handler for automated agent support orchestration requires precise handling of the binary frames, which seems impossible without the frame spec. The confidence threshold evaluation pipeline is stuck waiting for data that never arrives in the correct format. The interaction ID injection is correct, verified via the debug console, but the server rejects the subscription payload after the first successful ping. A backpressure queue exists in the renderer process to handle the burst of suggestions, yet the stream handler is dropping packets whenever the connection drops and auto-reconnects.
The ranking logic based on confidenceScore is working fine locally, but the latency tracking shows a 400ms spike every time the subscription revalidates. Trying to sync suggestion click events with the external knowledge platform via API exports is causing further delays in the relevance scoring algorithm. The assist audit logs for compliance verification are missing entries whenever the stream handler restarts. Anyone else dealing with binary frame parsing for agent assist streams? The documentation is sparse on the exact byte structure for the suggestion updates.
