Pushed the latest softphone config via Terraform v1.44.2 to mypurecloud.com.au this morning. Console’s showing green, but the WebRTC session tears down exactly when the ACMA recording prompt triggers. Looking at the browser console, the iceConnectionState flips to failed after about 3.2 seconds. SDP negotiation works, but the media path never establishes. Sydney edge latency is sitting around 280ms, which is usually acceptable, but something’s choking on the compliance payload.
Checked the conversation logs. Returns a 408 Request Timeout right after the recording: true flag gets applied in the Architect flow. Flow version is 18. ACMA mandates that timestamp format must match yyyy-MM-ddTHH:mm:ss+10:00 for AEST, but the softphone SDK v3.8.1 doesn’t seem to handle the offset correctly before sending it upstream. Network traces show the STUN bindings working, then silence. Tried forcing turn:turn.sydney.mypurecloud.com.au in the config, still drops. The raw packet capture shows the BYE message arriving before the first RTP frame even leaves the client buffer.
