Webhook Delivery Failing with 5xx — Implementing a Dead Letter Queue for Retries
- You will build a Python microservice that intercepts Genesys Cloud CX webhook deliveries that result in 5xx server errors, stores the failed payload in a dead letter queue (DLQ) for later inspection or retry, and logs the failure context.
- This tutorial uses the Genesys Cloud CX REST API for webhook configuration and a custom Python Flask application acting as the webhook receiver.
- The programming language used is Python 3.9+.
- OAuth Client Type: Machine-to-Machine (M2M) Application.
- Required Scopes:
webhook:read(to list existing webhooks)webhook:write(to create/update webhooks)integration:read(to verify integration status if needed)
- SDK Version:
genesys-cloud-sdk-pythonv2.0.0 or later. - Runtime Requirements: Python 3.9+.
- External Dependencies:
pip install genesys-cloud-sdk-pythonpip install flaskpip install redis(for the DLQ implementation)pip install requests
Before interacting with the Genesys Cloud CX API, you must obtain an access token using the Client Credentials flow. This token provides the necessary authorization to manage webhooks.
Step 1: Configure Environment Variables
Create a .env file in your project root with the following variables. Replace the placeholder values with your actual Genesys Cloud CX application credentials.
GENESYS_CLIENT_ID=your_client_id
GENESYS_CLIENT_SECRET=your_client_secret
GENESYS_ENVIRONMENT=us-east-1 # e.g., us-east-1, eu-west-1, etc.
REDIS_URL=redis://localhost:6379/0
Step 2: Implement Token Management
The following Python code demonstrates how to initialize the Genesys Cloud SDK and handle authentication. It includes basic token caching to avoid unnecessary re-authentication during development, though in production, you should use a dedicated token manager that handles expiration and refresh.
import os
import requests
from genesyscloud.platform_client_v2 import PlatformClientBuilder
from genesyscloud.webhooks.webhooks_client import WebhooksClient
def get_genesys_webhook_client() -> WebhooksClient:
Initializes and returns a configured Genesys Cloud Webhooks Client.
environment = os.getenv("GENESYS_ENVIRONMENT", "us-east-1")
raise ValueError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET must be set.")
# Construct the base URL based on the environment
if environment == "us-east-1":
base_url = "https://api.mypurecloud.com"
elif environment == "eu-west-1":
base_url = "https://api.eu.purecloud.com"
else:
base_url = f"https://api.{environment}.mypurecloud.com"
# Configure the platform client
builder = PlatformClientBuilder()
builder.set_base_url(base_url)
# Get an access token
token_url = f"{base_url}/oauth/token"
payload = {
"client_id": client_id,
"client_secret": client_secret
response = requests.post(token_url, data=payload)
if response.status_code != 200:
raise Exception(f"Failed to obtain access token: {response.text}")
access_token = response.json().get("access_token")
builder.set_access_token(access_token)
# Build the specific client for webhooks
client = builder.build_webhooks_client()
return client
Step 1: Create a Webhook with Retry Policy
Genesys Cloud CX provides built-in retry mechanisms for transient failures (4xx and 5xx). However, understanding how to configure the webhook correctly is the first step in managing failures. We will create a webhook that points to our local Flask application.
OAuth Scope: webhook:write
from genesyscloud.webhooks.models import Webhook, WebhookDestination, WebhookSubscription
def create_test_webhook(client: WebhooksClient) -> str:
Creates a webhook that subscribes to all conversation events.
Returns the webhook ID.
# Define the destination URL
destination = WebhookDestination(
uri="http://localhost:5000/webhook/genesys"
# Define the subscription
subscription = WebhookSubscription(
event="all",
filter=None # Optional: add filter if needed
# Create the webhook body
webhook_body = Webhook(
name="DLQ Test Webhook",
destinations=[destination],
subscriptions=[subscription],
enabled=True,
version=1
result = client.post_webhooks(body=webhook_body)
print(f"Webhook created with ID: {result.id}")
return result.id
print(f"Error creating webhook: {e}")
raise e
Step 2: Build the Webhook Receiver with DLQ Logic
The core of this tutorial is the Flask application that receives the webhook payload. When the downstream system (simulated here by raising an exception) fails with a 5xx error, we must catch this error, serialize the original payload, and push it to a Redis-based Dead Letter Queue.
Important: Genesys Cloud expects a 2xx response to consider the delivery successful. If you return a 5xx, Genesys will retry according to its internal policy (usually 3-5 times with exponential backoff). If you want to acknowledge receipt but flag it for manual processing, you must return 200 OK and handle the failure internally. This tutorial demonstrates the latter pattern, which is critical for preventing infinite retry loops from Genesys while ensuring no data is lost.
import json
import redis
import logging
from flask import Flask, request, jsonify
app = Flask(__name__)
# Initialize Redis client
redis_client = redis.from_url(os.getenv("REDIS_URL", "redis://localhost:6379/0"))
def push_to_dlq(payload: dict, error_msg: str, status_code: int):
Pushes the failed webhook payload to the Redis DLQ.
dlq_entry = {
"original_payload": payload,
"error_message": error_msg,
"status_code": status_code,
"timestamp": datetime.now().isoformat(),
"retry_count": 0 # Initialize retry counter
# LPUSH adds to the left of the list
redis_client.lpush("genesys_webhook_dlq", json.dumps(dlq_entry))
logger.info(f"Payload pushed to DLQ: {dlq_entry.get('original_payload', {}).get('id', 'unknown')}")
logger.error(f"Failed to push to DLQ: {e}")
@app.route("/webhook/genesys", methods=["POST"])
def receive_webhook():
Receives webhooks from Genesys Cloud.
Simulates a downstream failure and implements DLQ logic.
# 1. Parse the incoming JSON payload
payload = request.get_json()
if not payload:
logger.warning("Received empty payload from Genesys.")
return jsonify({"error": "Empty payload"}), 400
logger.info(f"Received webhook for event: {payload.get('event', 'unknown')}")
# 2. Simulate Downstream Processing Failure
# In a real scenario, this might be a database write or an API call to a third party
simulated_error = True
if simulated_error:
raise Exception("Simulated Database Connection Timeout")
# 3. If processing succeeds
return jsonify({"status": "processed"}), 200
# 4. Handle 5xx-like failures
logger.error(f"Downstream processing failed: {str(e)}")
# Push to DLQ for later retry/inspection
push_to_dlq(
payload=request.get_json(silent=True) or {},
error_msg=str(e),
status_code=500
# 5. Return 200 OK to Genesys to stop retries
# This is crucial: Genesys will not retry if it sees 200 OK.
# The data is safe in the DLQ.
return jsonify({"status": "deferred_to_dlq"}), 200
app.run(port=5000, debug=True)
Step 3: Implement the DLQ Consumer (Retry Logic)
Now that failed payloads are stored in Redis, you need a consumer that attempts to reprocess them. This consumer can run on a schedule or be triggered manually.
import json
import redis
# Assume the same redis_client and processing logic as above
def process_dlq():
Consumes the DLQ and attempts to reprocess failed payloads.
while True:
# BRPOP blocks until an item is available or timeout occurs
item = redis_client.brpop("genesys_webhook_dlq", timeout=1)
if not item:
# item is a tuple: (key, value)
_, json_data = item
entry = json.loads(json_data)
payload = entry["original_payload"]
retry_count = entry.get("retry_count", 0) + 1
logger.info(f"Retrying payload {payload.get('id', 'unknown')} (Attempt {retry_count})")
# Simulate successful reprocessing
# Replace this with your actual business logic
if retry_count < 3:
raise Exception("Still failing...")
logger.info(f"Successfully reprocessed payload {payload.get('id', 'unknown')}")
logger.error(f"Retry failed for payload: {e}")
if retry_count >= 3:
# Move to a permanent failure queue or alert
redis_client.lpush("genesys_webhook_permanent_failures", json.dumps(entry))
logger.warning(f"Payload moved to permanent failure after {retry_count} attempts")
else:
# Re-queue for later retry with updated count
entry["retry_count"] = retry_count
redis_client.rpush("genesys_webhook_dlq", json.dumps(entry))
logger.error(f"DLQ Consumer error: {e}")
time.sleep(5) # Back off on consumer error
process_dlq()
Below is the complete, combined Python script. Save this as genesys_dlq_app.py. Ensure you have Redis running locally on port 6379.
import os
import json
import requests
import redis
import logging
from datetime import datetime
# Configure Logging
logging.basicConfig(level=logging.INFO, format='%(asctime)s - %(levelname)s - %(message)s')
# Global Redis Client
# Flask App
elif environment != "us-east-1":
payload = {
return builder.build_webhooks_client()
destination = WebhookDestination(uri="http://localhost:5000/webhook/genesys")
subscription = WebhookSubscription(event="all")
enabled=True,
version=1
logger.info(f"Webhook created with ID: {result.id}")
return result.id
logger.error(f"Error creating webhook: {e}")
raise e
dlq_entry = {
"retry_count": 0
logger.info(f"Payload pushed to DLQ")
if not payload:
# Simulate a downstream failure
push_to_dlq(
error_msg=str(e),
status_code=500
def process_dlq():
while True:
if not item:
_, json_data = item
logger.info(f"Retrying payload (Attempt {retry_count})")
if retry_count < 3:
logger.info(f"Successfully reprocessed payload")
logger.error(f"Retry failed: {e}")
logger.warning(f"Payload moved to permanent failure")
else:
time.sleep(5)
import threading
# Start DLQ Consumer in a background thread
dlq_thread = threading.Thread(target=process_dlq, daemon=True)
dlq_thread.start()
# Create Webhook
client = get_genesys_webhook_client()
create_test_webhook(client)
logger.error(f"Failed to setup webhook: {e}")
# Start Flask App
Cause: The OAuth token is invalid, expired, or the client credentials are incorrect.
Fix: Verify that GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET are correct. Ensure the application has the webhook:write scope assigned in the Genesys Cloud admin portal under Administration > Platform > Applications.
Code Fix: Check the response from the /oauth/token endpoint. If it returns 401, your credentials are wrong.
# Add this check in get_genesys_webhook_client()
raise Exception("Invalid Client ID or Secret.")
Error: 403 Forbidden
Cause: The OAuth token does not have the required scopes.
Fix: Ensure the M2M application has the webhook:write and webhook:read scopes.
Code Fix: Review the scopes assigned to your application in the Genesys Cloud admin console.
Error: Webhook Not Received
Cause: The webhook URL is not publicly accessible, or the firewall blocks Genesys Cloud IPs.
Fix: Genesys Cloud cannot reach localhost. You must use a tunneling service like ngrok or expose the service on a public IP.
Code Fix: Update the WebhookDestination URI to use your ngrok URL.
destination = WebhookDestination(uri="https://abc123.ngrok.io/webhook/genesys")
Error: DLQ Overflow
Cause: The downstream system is failing consistently, and the retry logic is re-queuing items indefinitely.
Fix: Implement a maximum retry count and move failed items to a permanent failure queue for manual inspection.
Code Fix: The process_dlq function in the complete example already implements a max retry count of 3.
