Is it possible to programmatically override the visual configuration of a Web Messaging deployment using the Genesys Cloud API? I am writing k6 scripts to validate our CI/CD pipeline for customer-facing widgets, and manual UI configuration is a bottleneck for regression testing.
I attempted to update the deployment via the configuration API with a JSON payload containing the specific visual overrides. The request completes with a 200 OK, but the widget renders with default styling in the browser. The API response does not include the visual configuration fields in the returned object.
Retrieve current deployment config via GET /api/v2/webdeployments/deployments/{deploymentId}/configurations.
Modify the JSON payload to include visualConfiguration: { "launcherPosition": "right", "primaryColor": "#FF0000" }.
Send PUT request with updated JSON.
Verify widget in browser; styling remains default.
The documentation for the Deployment API is sparse regarding visual customization fields. It seems these might be handled by a separate UI configuration endpoint or embedded within the widget HTML generation logic, not the deployment resource itself.
Has anyone successfully customized launcher position and colors via the REST API? If so, what is the correct JSON structure or endpoint to use?
As far as I remember, the deployment API endpoint you are using does not support the visualConfig object directly in the payload. The SDK documentation is sparse here, but the underlying REST spec requires you to update the settings object with a specific JSON structure for the launcher. You cannot just pass a flat JSON blob. The API ignores unknown fields and returns 200, which is why your changes aren’t sticking. You need to structure the payload to target the webMessaging section specifically. Use the Python SDK to construct the Deployment object correctly. It saves you from debugging curl headers manually. The key is ensuring the customProperties or the specific visual override keys are nested correctly under the deployment settings.
I’d recommend looking at at the specific structure required for the settings object as mentioned above. the previous suggestion is correct, but the exact json path is often missed. when updating the configuration draft via put /api/v2/webdeployments/configurations/{configurationId}/versions/draft, you must ensure the visualConfig is nested correctly within the webMessaging settings block. if you send it at the root level, the api returns 200 ok but silently drops the unknown fields, which explains why your k6 scripts see no change.
here is the precise payload structure i use for my new relic instrumentation tests to verify config drift. note the launcher object inside visualConfig.
i typically wrap this in a python requests call with the authorization: bearer <token> header. if you get a 400 bad request, it usually means the color hex code is invalid or the position string is not one of the enumerated values (bottom-left, bottom-right). also, remember that changes can take up to 60 seconds to propagate to the edge nodes, so add a small sleep in your k6 script before asserting the widget appearance. this propagation delay is a common false positive in ci/cd pipelines.
Make sure you structure the settings object precisely, as the Genesys Cloud Deployment API is notoriously strict about nesting levels for web messaging configurations. The suggestion above regarding the visualConfig location is accurate, but it lacks the concrete JSON structure required to avoid silent failures. When migrating from rigid IVR logic to dynamic UI components, I have found that the webMessaging settings block requires explicit definition of the launcher properties within a visualConfig wrapper. If you omit this nesting, the API accepts the payload (200 OK) but discards the visual overrides, leaving your k6 scripts to test against default values.
Here is the exact payload structure you need when updating the configuration draft:
This mirrors the structure we see in Architect Data Actions where nested objects must be explicitly defined. If you are using the PureCloudPlatformClientV2 SDK, ensure you are serializing the DeploymentSettings object correctly. Do not pass a flat dictionary. The launcher object must reside inside visualConfig, which in turn must reside inside webMessaging. Any deviation results in the API ignoring the update.
Warning: Do not attempt to update these settings via the generic organizations API if you are using per-tenant deployments. You must target the specific deploymentId returned by the GET endpoint, otherwise you will update the default template instead of your specific test instance, leading to inconsistent k6 results.
The best way to fix this is to ensure the visualConfig is nested precisely within the webMessaging settings object. The API returns 200 OK because the request syntax is valid, but it silently ignores fields placed at the wrong hierarchy level. This behavior is common in Genesys Cloud configuration APIs where partial updates are supported.
In my Azure Functions, I handle this by constructing the payload strictly according to the schema. You must verify that visualConfig is a child of webMessaging inside the settings object. Do not place it at the root level of the deployment resource.
Here is the correct JSON structure for the PUT request body:
To validate this in your k6 scripts, follow these steps:
Extract the current deployment settings using GET /api/v2/webdeployments/deployments/{deploymentId}/configurations.
Merge your test visualConfig values into the existing settings.webMessaging object.
Update the configuration draft using the configuration API.
Verify the response contains the updated visualConfig block.
If you still see no changes, check the response headers for x-genesys-cloud-request-id. Use this ID to trace the request in the Genesys Cloud admin console logs. The issue is almost always incorrect nesting or missing the webMessaging key entirely. The suggestion above about the settings object is correct, but the exact path matters.
