Web Messaging SDK config for launcher position and colors not applying
We’re trying to customize the Genesys Cloud Web Messaging widget. The goal is to move the launcher to the top-left and change the primary color to match our brand hex #0056b3.
I’ve set up the genesyscloud-webrtc package and initialized the messaging client. Here’s the config object I’m passing:
const config = {
 deploymentId: 'abc-123-def',
 launcherPosition: 'top-left',
 colors: {
 primary: '#0056b3',
 secondary: '#ffffff'
WebMessaging.initialize(config);
The widget loads fine, but it stays in the default bottom-right corner. The color remains the default blue. No errors in the console.
I checked the Web Messaging documentation. It mentions launcherPosition and colors are valid properties. I’m using SDK version 3.2.1.
Is there a specific way to inject these styles? Maybe a CSS override is needed? Or am I missing a step in the initialization flow? The OTel spans show the initialization completes successfully, so the code runs. Just no visual changes.
