WallBoard OpenStat Tenant Resources not found
We are retiring a SQL Server 2005 box so I built ConsoleStats and copied the built files to wallboard server. However when running the executable I am getting these exceptions,
statistic needed for: Stat_num_1
SubscribeToStat:java.rmi.RemoteException: OpenStat Tenant Resources not found
SubscribeToStat:java.rmi.RemoteException: service not allowed
Try to post fragment of your code which covers part where the stat request is built.
BTW: I do not understand, what role for SQL in this case. Wallboard is usually a real-time application.
Hey Kubig,
I appreciate for the quick reply and here is the code snip for service to update wallboard stats DB.
   public bool SaveCallsWaiting(int mCallsWaiting)
        SqlCommand myCommand = new SqlCommand();
        myCommand.Connection = WallboardDB.GetDBConnection();
        myCommand.CommandText = "UPDATE WALLBOARD_STATS SET CallsWaiting = @CallsWaiting";
        SqlParameterCollection collection1 = myCommand.Parameters;
        collection1.AddWithValue("@CallsWaiting", mCallsWaiting);
        collection1 = null;
        myCommand.Connection.Open();
        myCommand.ExecuteNonQuery();
        myCommand.Connection.Close();
        return true;
Any help will be much appreciated,
When I fire up ConsoleStats this is what I get
Today is Tuesday
Logged in with session http://5701-dc.la.cssd.ad:8080/gis/services/SessionServic
e?GISsessionId=ECSSPROD_GIS_LA:SessionService:1441146936530H15
Service subscribed = GIS_STATSERVICE
CurrNumberWaitingCalls
Statistic needed for: Stat_num_1
subscribeToStat: java.rmi.RemoteException: OpenStat: Tenant ‘Resources’ not foun
d
subscribeToStat: java.rmi.RemoteException: stat reference already used
d
Total_Calls_Answered
Statistic needed for: Stat_num_2
d
Total_Time_to_Answer
Statistic needed for: Stat_num_3
d
d
CurrMaxCallWaitingTime
Statistic needed for: Stat_num_4
Only one suggestion - do not use GIS at all.
Lol
Check your StatServer logs
Can you create those views using CCPulse with same StatServer?
Enviado de meu C6602 usando Tapatalk
Do you have a Tenant named ‘Resources’ ?
    public bool loginGetSession(string url)
        try
            //Setup identity and login to GIS. This is followed by tagging on the sid to the GIS URL.
            string url_sid = "";
            port = new SessionServiceService();
            port.Url = "http://" + url + "/gis/services/SessionService";
            Identity id = new Identity();
            id.credentials = "[i]hiding this[/i]";
            id.principal = "board.wall";
            id.tenant = "Resources";
            sid = port.login(id);
            url_sid = "http://" + url + "/gis/services/SessionService" + "?GISsessionId=" + sid;
            port.Url = url_sid;
            Console.WriteLine("Logged in with session " + url_sid);
            return true;
         catch (Exception ex)
             Console.WriteLine(ex.Message);
             return false;
Also in this method
    public bool subscribeToStat(string objectName, string statName, string statCounter)
        try
             //We should be logged in now.   Next,  subscribe services.
            statistic stat = new statistic();
            stat.statisticId = "Stat_num_" + statCounter.ToString();
            objectIdType objectId = new objectIdType();
            objectId.id = objectName;
            objectId.tenantName = "Resources";
            stat.objectId = objectId;
            Console.WriteLine("Statistic needed for: " + stat.statisticId);
            metric metric = new metric();
            statisticType type = new statisticType();
            objectType[] ot = new objectType[] { objectType.GroupQueues };
            type.objectType = ot;
            metric.statisticType = type;
            metric.typeName = statName;
            timeInterval timeInterval = new timeInterval();
            timeInterval.intervalType = timeIntervalType.GrowingWindow;
            metric.interval = timeInterval;
            stat.metric = metric;
            schedule sched = new schedule();
            sched.notificationMode = scheduleMode.ChangesBased;
            stat.schedule = sched;
            // StatServiceService statService = new StatServiceService();
            statService.subscribeStatistic(stat, "ECSSPROD_Stat_Server_CCPulse1", new
                unsolicitedNotification());
            Console.WriteLine("subscribe successful");
            return true;
            Console.WriteLine("subscribeToStat: " + ex.Message);
            return false;
cavagnaro, where is this statServer log?
thanks,
Lol, you should know…how can I know your application configuration. Ask to your Genesys admin
Cavagnado, current prod consolestats was last compiled in 2010 and all old people left. There is not a person acting as Genesys admin at my work.
So…still. How are we supposed to know? Hire a remote support at least. There are many free lancers available, here you will find Adam for example. One of the bests
