Versioning Genesys Cloud Architect Flow Definitions via Java SDK
A Java utility that validates, version-control checks, and commits Architect flow definitions to Genesys Cloud with DAG cycle detection, node limit enforcement, atomic commit logic, and SCM synchronization hooks. This tutorial uses the Genesys Cloud FlowApi and the official Java SDK. The code is written in Java 17.
  • OAuth client credentials with flow:write and flow:read scopes
  • Genesys Cloud Java SDK platform-client version 116.0.0 or higher
  • Java 17 runtime with Maven or Gradle
  • External dependencies: com.fasterxml.jackson.core:jackson-databind for JSON serialization, org.slf4j:slf4j-api for structured logging
  • A target flow ID in Genesys Cloud with write permissions
Genesys Cloud requires OAuth 2.0 Client Credentials flow for server-to-server integrations. The SDK handles token acquisition and refresh automatically when configured correctly. The following block initializes the API client and binds the OAuth provider.
import com.mypurecloud.api.client.ApiClient;
import com.mypurecloud.api.client.Configuration;
import com.mypurecloud.api.client.auth.OAuth;
import com.mypurecloud.api.client.auth.OAuthFlow;
import com.mypurecloud.api.client.api.FlowApi;
import java.util.Arrays;
public class GenesysAuthConfig {
    public static FlowApi initializeFlowApi(String clientId, String clientSecret) {
        ApiClient apiClient = Configuration.getDefaultApiClient();
        apiClient.setBasePath("https://api.mypurecloud.com");
        OAuth oAuth = apiClient.getAuthentication("oauth");
        oAuth.setClientId(clientId);
        oAuth.setClientSecret(clientSecret);
        oAuth.setGrantType("client_credentials");
        oAuth.setScopes(Arrays.asList("flow:write", "flow:read"));
        oAuth.setOAuthFlow(OAuthFlow.CLIENT_CREDENTIALS);
        // SDK automatically fetches and caches tokens.
        // Subsequent calls will trigger refresh before expiration.
        return new FlowApi(apiClient);
The flow:write scope is mandatory for PUT /api/v2/architect/flows/{flowId} operations. The flow:read scope is required for fetching the current flow version before applying updates. The SDK stores the access token in memory and handles 401 Unauthorized responses by automatically requesting a new token.
Step 1: DAG Traversal and Dependency Matrix Construction
Architect flows are Directed Acyclic Graphs. The platform rejects flows with circular transitions. Before sending a payload, you must validate the graph structure client-side to prevent unnecessary API calls. This step builds an adjacency matrix, enforces a maximum node count, and runs a depth-first search to detect cycles.
import java.util.*;
public class FlowGraphValidator {
    private static final int MAX_NODE_COUNT = 500;
    private final ObjectMapper mapper = new ObjectMapper();
    public ValidationResult validateGraph(String flowJson) throws Exception {
        JsonNode root = mapper.readTree(flowJson);
        JsonNode nodes = root.path("nodes");
        JsonNode transitions = root.path("transitions");
        if (nodes.size() > MAX_NODE_COUNT) {
            return ValidationResult.fail("Node count exceeds limit: " + nodes.size());
        // Build adjacency matrix and node registry
        Map<String, String> nodeTypeMap = new HashMap<>();
        List<String> nodeIdList = new ArrayList<>();
        for (JsonNode node : nodes) {
            String id = node.path("id").asText();
            nodeTypeMap.put(id, node.path("type").asText());
            nodeIdList.add(id);
        int size = nodeIdList.size();
        boolean[][] adjacencyMatrix = new boolean[size][size];
        Map<String, List<String>> adjList = new HashMap<>();
        for (JsonNode t : transitions) {
            String from = t.path("fromNode").asText();
            String to = t.path("toNode").asText();
            if (nodeIdList.contains(from) && nodeIdList.contains(to)) {
                int i = nodeIdList.indexOf(from);
                int j = nodeIdList.indexOf(to);
                adjacencyMatrix[i][j] = true;
                adjList.computeIfAbsent(from, k -> new ArrayList<>()).add(to);
        // DFS cycle detection
        Set<String> visited = new HashSet<>();
        Set<String> recursionStack = new HashSet<>();
        for (String node : nodeIdList) {
            if (!visited.contains(node)) {
                if (hasCycle(node, adjList, visited, recursionStack)) {
                    return ValidationResult.fail("Cyclic reference detected starting at node: " + node);
        return ValidationResult.success(adjacencyMatrix, nodeTypeMap);
    private boolean hasCycle(String node, Map<String, List<String>> adjList,
                             Set<String> visited, Set<String> recursionStack) {
        visited.add(node);
        recursionStack.add(node);
        for (String neighbor : adjList.getOrDefault(node, Collections.emptyList())) {
            if (recursionStack.contains(neighbor)) {
                return true;
            if (!visited.contains(neighbor)) {
                if (hasCycle(neighbor, adjList, visited, recursionStack)) {
                    return true;
        recursionStack.remove(node);
        return false;
    public record ValidationResult(boolean success, String message,
                                   boolean[][] matrix, Map<String, String> nodeTypes) {
        public static ValidationResult success(boolean[][] m, Map<String, String> n) {
            return new ValidationResult(true, "Graph valid", m, n);
        public static ValidationResult fail(String msg) {
            return new ValidationResult(false, msg, null, null);
The adjacency matrix supports dependency tracking for rollback scenarios. The DFS algorithm uses a recursion stack to identify back edges, which indicate cycles. Genesys Cloud returns a 422 Unprocessable Entity if a cycle exists, but client-side validation saves API quota and reduces latency.
Step 2: Parameter Signature Checking and Transition State Verification
Flows fail at runtime when transition conditions reference undefined parameters or invalid system variables. This step verifies that every condition expression matches a declared parameter signature and that transition states align with node execution paths.
import java.util.regex.Pattern;
import java.util.regex.Matcher;
public class TransitionVerifier {
    private static final Pattern PARAM_REF = Pattern.compile("\\$\\{([^}]+)\\}");
    private static final Set<String> SYSTEM_VARS = Set.of("system.queue", "system.contact", "system.interaction");
    public VerificationResult verifyTransitions(String flowJson, Map<String, String> nodeTypes) throws Exception {
        JsonNode root = new ObjectMapper().readTree(flowJson);
        JsonNode parameters = root.path("parameters");
        Set<String> validParams = new HashSet<>();
        for (JsonNode p : parameters) {
            validParams.add(p.path("name").asText());
            String condition = t.path("condition").asText();
            String fromNode = t.path("fromNode").asText();
            String toNode = t.path("toNode").asText();
            // Verify deterministic execution path
            String fromType = nodeTypes.get(fromNode);
            if (!"decision".equals(fromType) && !"query".equals(fromType) && !"set-variable".equals(fromType)) {
                return VerificationResult.fail("Invalid transition source type: " + fromType);
            // Parameter signature checking
            Matcher matcher = PARAM_REF.matcher(condition);
            while (matcher.find()) {
                String param = matcher.group(1);
                if (!SYSTEM_VARS.contains(param) && !validParams.contains(param)) {
                    return VerificationResult.fail("Undefined parameter reference: " + param);
        return VerificationResult.success();
    public record VerificationResult(boolean success, String message) {
        public static VerificationResult success() { return new VerificationResult(true, "Transitions valid"); }
        public static VerificationResult fail(String msg) { return new VerificationResult(false, msg); }
This validation pipeline ensures deterministic execution paths. Genesys Cloud evaluates conditions sequentially. If a condition references an unbound variable, the flow enters a deadlock state or throws a runtime error. The regex extraction isolates ${variable} references and cross-references them against the flow’s parameter schema and known system variables.
Step 3: Atomic Commit with Rollback, Latency Tracking, and SCM Webhooks
The commit operation uses optimistic locking via the version field. The SDK sends a PUT /api/v2/architect/flows/{flowId} request with the expected version. If the platform rejects the request due to a version mismatch, the utility triggers a rollback by re-fetching the latest version and re-applying the payload. Latency and success metrics are tracked, and a webhook notifies an external SCM system.
import com.mypurecloud.api.client.ApiException;
import com.mypurecloud.api.client.model.Flow;
import com.mypurecloud.api.client.model.FlowVersion;
import java.net.URI;
import java.time.Instant;
import java.util.concurrent.atomic.AtomicInteger;
import java.util.concurrent.atomic.AtomicLong;
public class FlowVersioner {
    private final FlowApi flowApi;
    private final String webhookUrl;
    private final HttpClient httpClient = HttpClient.newHttpClient();
    private final AtomicLong commitLatencyMs = new AtomicLong(0);
    private final AtomicInteger successCount = new AtomicInteger(0);
    private final AtomicInteger failureCount = new AtomicInteger(0);
    private final ObjectMapper jsonMapper = new ObjectMapper();
    public FlowVersioner(FlowApi flowApi, String webhookUrl) {
        this.flowApi = flowApi;
        this.webhookUrl = webhookUrl;
    public CommitResult commitFlow(String flowId, String flowJson, int expectedVersion) throws Exception {
        Instant start = Instant.now();
        FlowVersioner.CommitResult result = new FlowVersioner.CommitResult();
            // Fetch current version to verify optimistic lock
            FlowVersion currentVersion = flowApi.getFlowVersion(flowId, expectedVersion, null);
            if (currentVersion == null) {
                throw new IllegalStateException("Flow version not found: " + expectedVersion);
            // Construct SDK payload
            Flow flowPayload = jsonMapper.readValue(flowJson, Flow.class);
            flowPayload.setVersion(expectedVersion + 1);
            // Atomic POST/PUT operation
            FlowVersion committed = flowApi.putFlow(flowId, flowPayload, null, null);
            long latency = java.time.Duration.between(start, Instant.now()).toMillis();
            commitLatencyMs.set(latency);
            successCount.incrementAndGet();
            result.success = true;
            result.committedVersion = committed.getVersion();
            result.message = "Successfully committed version " + committed.getVersion();
            // Trigger SCM sync webhook
            triggerScmWebhook(flowId, committed.getVersion(), true, latency);
            return result;
        } catch (ApiException e) {
            failureCount.incrementAndGet();
            if (e.getCode() == 409) {
                // Automatic rollback trigger: re-fetch latest and retry once
                result.message = "Version conflict. Triggering rollback retry.";
                return rollbackAndRetry(flowId, flowJson, expectedVersion);
            } else if (e.getCode() == 422) {
                result.message = "Validation failed by platform: " + e.getMessage();
                triggerScmWebhook(flowId, expectedVersion, false, latency);
                return result;
            } else {
                result.message = "API error: " + e.getMessage();
                return result;
        } catch (Exception e) {
            throw e;
    private CommitResult rollbackAndRetry(String flowId, String flowJson, int baseVersion) throws Exception {
        // Fetch latest version for safe rollback alignment
        FlowVersion latest = flowApi.getFlowVersion(flowId, null, null);
        int newBase = latest.getVersion();
        // Re-validate against latest dependency matrix if needed
        flowPayload.setVersion(newBase + 1);
        CommitResult res = new CommitResult();
        res.success = true;
        res.committedVersion = committed.getVersion();
        res.message = "Rolback successful. Committed version " + committed.getVersion();
        triggerScmWebhook(flowId, committed.getVersion(), true, commitLatencyMs.get());
        return res;
    private void triggerScmWebhook(String flowId, int version, boolean success, long latency) {
            String payload = jsonMapper.writeValueAsString(new SCMEvent(
                flowId, version, success, latency, Instant.now().toString()
                .uri(URI.create(webhookUrl))
                .POST(HttpRequest.BodyPublishers.ofString(payload))
                .build();
            httpClient.send(request, HttpResponse.BodyHandlers.discarding());
            // Log failure but do not interrupt commit flow
            System.err.println("SCM Webhook failed: " + e.getMessage());
    public record CommitResult(boolean success, int committedVersion, String message) {}
    public record SCMEvent(String flowId, int version, boolean success, long latencyMs, String timestamp) {}
    public long getAverageLatency() { return commitLatencyMs.get(); }
    public int getSuccessCount() { return successCount.get(); }
    public int getFailureCount() { return failureCount.get(); }
The PUT /api/v2/architect/flows/{flowId} endpoint requires the version field to increment sequentially. The SDK handles the HTTP serialization. The rollback logic catches 409 Conflict responses, fetches the latest platform version, and re-submits the payload with an updated version number. This prevents manual intervention during concurrent edits. The webhook payload aligns with standard SCM event schemas for external repository synchronization.
The following class combines validation, commit logic, and audit logging into a single executable module. Replace CLIENT_ID, CLIENT_SECRET, FLOW_ID, and WEBHOOK_URL with your environment values.
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import java.io.IOException;
import java.nio.file.Files;
import java.nio.file.Paths;
public class FlowVersioningPipeline {
    private static final Logger logger = LoggerFactory.getLogger(FlowVersioningPipeline.class);
        String clientId = "YOUR_CLIENT_ID";
        String clientSecret = "YOUR_CLIENT_SECRET";
        String flowId = "YOUR_FLOW_ID";
        String webhookUrl = "https://your-scm-endpoint.com/api/genesys/flow-events";
        String flowJsonPath = "/path/to/flow-definition.json";
            // 1. Initialize API
            var flowApi = GenesysAuthConfig.initializeFlowApi(clientId, clientSecret);
            var versioner = new FlowVersioner(flowApi, webhookUrl);
            var graphValidator = new FlowGraphValidator();
            var transitionVerifier = new TransitionVerifier();
            // 2. Load flow definition
            String flowJson = new String(Files.readAllBytes(Paths.get(flowJsonPath)));
            // 3. Validate DAG and constraints
            var graphResult = graphValidator.validateGraph(flowJson);
            if (!graphResult.success()) {
                logger.error("Graph validation failed: {}", graphResult.message());
                System.exit(1);
            // 4. Validate transitions and parameters
            var transResult = transitionVerifier.verifyTransitions(flowJson, graphResult.nodeTypes());
            if (!transResult.success()) {
                logger.error("Transition validation failed: {}", transResult.message());
                System.exit(1);
            // 5. Fetch current version for optimistic locking
            FlowVersion current = flowApi.getFlowVersion(flowId, null, null);
            int expectedVersion = current.getVersion();
            // 6. Execute atomic commit
            var commitResult = versioner.commitFlow(flowId, flowJson, expectedVersion);
            if (commitResult.success()) {
                logger.info("Commit successful: {}", commitResult.message());
                logger.info("Audit Log: Flow={}, Version={}, Latency={}ms, SuccessRate={}/{}",
                    flowId, commitResult.committedVersion(), versioner.getAverageLatency(),
                    versioner.getSuccessCount(), versioner.getSuccessCount() + versioner.getFailureCount());
            } else {
                logger.error("Commit failed: {}", commitResult.message());
            logger.error("Genesys API Error: {} {}", e.getCode(), e.getMessage());
        } catch (IOException | Exception e) {
            logger.error("Pipeline execution failed", e);
This pipeline reads a raw JSON flow definition, enforces graph constraints, verifies parameter signatures, and commits the version with automatic rollback on conflict. The audit log prints commit success rates and latency metrics for governance reporting.
Error: 409 Conflict (Version Mismatch)
  • What causes it: Another process updated the flow between your GET and PUT requests. The version field in your payload does not match the platform’s current version.
  • How to fix it: Implement optimistic locking. Fetch the latest version immediately before the PUT request. The provided rollbackAndRetry method handles this by re-fetching the latest version and incrementing it.
  • Code showing the fix: The commitFlow method catches e.getCode() == 409 and delegates to rollbackAndRetry, which aligns the payload version with the platform state.
Error: 422 Unprocessable Entity (Validation Failure)
  • What causes it: The flow JSON violates Genesys schema constraints. Common causes include missing required node fields, invalid transition targets, or unsupported node types.
  • How to fix it: Validate the payload client-side before submission. Use the FlowGraphValidator and TransitionVerifier classes to catch structural errors. Enable SDK debug logging to inspect the raw platform error body.
  • Code showing the fix: The TransitionVerifier checks parameter references and node types. The FlowGraphValidator enforces DAG acyclicity and node limits.
Error: 429 Too Many Requests (Rate Limit Cascade)
  • What causes it: Exceeding Genesys Cloud API rate limits (typically 100 requests per second per client). Rapid version commits or polling triggers throttling.
  • How to fix it: Implement exponential backoff. The SDK does not automatically retry 429s for PUT operations. Wrap the flowApi.putFlow call in a retry loop with a delay that doubles on each failure.
int maxRetries = 3;
for (int attempt = 0; attempt < maxRetries; attempt++) {
        return flowApi.putFlow(flowId, flowPayload, null, null);
        if (e.getCode() == 429 && attempt < maxRetries - 1) {
            Thread.sleep((long) Math.pow(2, attempt) * 1000);
            continue;
        throw e;
