VB .NET Help
Hi guys,
This question is not exactly about Genesys API but related to a Softphone requirement.
I usually develop on VB6 but now I’m trying to make a parallel version of my App on Vb.Net, i’m just starting to learn about it.
I want my application to capture keyboard combinations so it allows the agents to put themselves Ready/NotReady more fast.
On VB6 this is my code:
Private Declare Function GetAsyncKeyState Lib “User32” _
(ByVal vKey As KeyCodeConstants) As Long
Private Function KeyDown(ByVal vKey As KeyCodeConstants) As Boolean
KeyDown = GetAsyncKeyState(vKey) And &H8000
End Function
And a timer that keeps reading the users input:
Private Sub Timer1_Timer()
If KeyDown(vbKeyControl) And KeyDown(vbKeyF11) Then 'Ready
    TExtension1.TReady
    Exit Sub
End If
End Sub
On VB.Net i tried this:
Private Declare Function GetAsyncKeyState Lib “User32” (ByVal vKey As Keys) As Long
Private Function KeyDown1(ByVal vKey As Keys) As Boolean
KeyDown1 = GetAsyncKeyState(vKey) And &H8000
End Function
But doesn’t work
Any help please as many users here have more experience on Vb.Net
Thanks a lot
Please take a look at the following article http://www.codeproject.com/csharp/globalhook.asp. It is written in C# but can be easily used in VB .Net. Solution provided by this library will create system level shortcuts - no matter which application is active.
Regards
Paul
Hi cavagnaro,
If you don’t need global/system level shortcuts then most of the graphical components (Form, TextBox etc.) do support the event “KeyPressed”. You can assign your own handler to that Event and check which keys were pressed.
René
Well the main idea is that agent can be on any application (CRM, email, internet, etc) and change it status without going to CTI Application itself.
It seems i’ll have to learn C# now, no VB.Net library of this? Seems .NET is still very young then.
Yay! It works!
Public Declare Function GetAsyncKeyState Lib "user32" (ByVal vKey As Keys) As Long
Private Function KeyDownStatus(ByVal vKey As Keys) As Boolean
    KeyDownStatus = GetAsyncKeyState(vKey) And &H8000
End Function
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
    If KeyDownStatus(Keys.ControlKey) And KeyDownStatus(Keys.F10) Then
        Debug.Print("ok")
    End If
End Sub</blockquote>
Not sure why now but it works like a charm :smiley: Marvelous Google Code Search
In .NET You can use C# libraries under VB.NET and vice versa - that how .NET works :slight_smile: - for example Genesys .NET libraries are written in C# but can be easily used under VB
Uh..how? I have found an excellent idea (deskbank) and would like to implement that on my application but all code is on C#.
Is there a Tool or something to import directly from C# to Vb.Net?
Thanks a lot
It works like this - You must create C# project of type “Class library” or “Windows Control library” with code You need. Compile it. You will receive dll. Then You just need to add this dll to references of Your VB application and You can access class or controls stored in this dll. If You need help with creating this file feel free to send this C# code to convert into library.
Paul
HI guys,
I found this:
http://www.codeproject.com/csharp/BandObjects20.asp
It’s very cool.
I have tried to make it VB.Net compatible but without any success.
Can anybody please try to do a very simple thing on Vb.Net with it?
Thanks in advance for any help ;D
Hi
In attached file You will find modified project from CodeProject with sample VB.Net application - I hope it helps. Important thing is to set minimum and maximum size to values other then 0,0.
Paul
Hi bublepaw,
Thanks a lot for the help.
A question when i build the Lib i get this:
RegAsm : warning RA0000 : No types were registered
What else do i need to modify?
It works now like a charm :smiley:
Thanks a lot! Hope i can return help someday
