Validating NICE Cognigy.AI Dialog Flow Transitions via REST APIs with Node.js
- A Node.js module that programmatically validates Cognigy.AI dialog flow transitions by analyzing node UUIDs, transition matrices, and intent routing rules.
- Uses Cognigy.AI REST API v1 endpoints for flow retrieval and validation simulation.
- Implemented in JavaScript (Node.js) with async/await and axios.
- Cognigy.AI tenant endpoint and API token with
flow:readandintent:readscopes. - Node.js 18 or later.
npm install axios uuid winston- Cognigy.AI API v1 base URL format:
https://{tenant}.cognigy.ai/api/v1 - Access to a published flow with at least three nodes and two transitions.
Cognigy.AI uses Bearer token authentication. The token must be attached to every request via the Authorization header. Tokens expire after a configurable duration, so you must implement caching and refresh logic to avoid 401 Unauthorized errors during batch validation runs.
import axios from 'axios';
* @typedef {Object} AuthConfig
* @property {string} tenantUrl - Cognigy.AI tenant base URL
* @property {string} apiToken - Bearer token with flow:read scope
class CognigyAuthClient {
* @param {AuthConfig} config
constructor(config) {
this.tenantUrl = config.tenantUrl;
this.token = config.apiToken;
this.client = axios.create({
baseURL: `${this.tenantUrl}/api/v1`,
timeout: 10000,
headers: {
'Authorization': `Bearer ${this.token}`
this._setupRetryInterceptor();
_setupRetryInterceptor() {
this.client.interceptors.response.use(
response => response,
error => {
const retryAfter = error.response.headers['retry-after'] || 2;
console.warn(`Rate limited. Retrying after ${retryAfter}s`);
return new Promise(resolve => setTimeout(resolve, retryAfter * 1000))
.then(() => this.client.request(error.config));
if (error.response?.status === 401) {
throw new Error('Authentication failed. Token expired or invalid scope.');
return Promise.reject(error);
* Refresh token cache if needed
* @returns {string} Valid bearer token
async ensureToken() {
// In production, call your identity provider refresh endpoint here.
// For this tutorial, we assume the token remains valid during the validation run.
return this.token;
Step 1: Fetch Flow Definition and Construct Validation Payload
The Cognigy.AI API returns flow definitions as a single JSON object containing nodes and transitions. You must extract UUID references and build a transition path matrix before validation. The matrix maps source nodes to target nodes with associated routing conditions.
* @typedef {Object} FlowNode
* @property {string} uuid
* @property {string} type - e.g., 'start', 'intent', 'response', 'end'
* @property {string} [intentId]
* @typedef {Object} FlowTransition
* @property {string} sourceUuid
* @property {string} targetUuid
* @property {string} [condition]
async function fetchFlowDefinition(client, flowUuid) {
const response = await client.get(`/flows/${flowUuid}`);
if (!response.data || !response.data.nodes || !response.data.transitions) {
throw new Error('Invalid flow structure returned from Cognigy.AI API');
uuid: flowUuid,
nodes: response.data.nodes,
transitions: response.data.transitions
* Constructs the validation payload with UUID references and path matrices
* @param {Object} flowData
* @returns {Object} Validation payload
function constructValidationPayload(flowData) {
const pathMatrix = new Map();
const errorDirectives = [];
flowData.transitions.forEach(t => {
if (!pathMatrix.has(t.sourceUuid)) {
pathMatrix.set(t.sourceUuid, []);
pathMatrix.get(t.sourceUuid).push({
target: t.targetUuid,
condition: t.condition || 'default',
validated: false
// Validate target existence
const validUuids = new Set(flowData.nodes.map(n => n.uuid));
if (!validUuids.has(t.targetUuid)) {
errorDirectives.push({
type: 'MISSING_TARGET',
source: t.sourceUuid,
severity: 'BLOCKER'
flowUuid: flowData.uuid,
nodeCount: flowData.nodes.length,
transitionCount: flowData.transitions.length,
pathMatrix: Object.fromEntries(pathMatrix),
errorDirectives,
validationTimestamp: new Date().toISOString()
Expected Response Structure
"uuid": "f47ac10b-58cc-4372-a567-0e02b2c3d479",
"nodes": [
{ "uuid": "node-001", "type": "start", "intentId": null },
{ "uuid": "node-002", "type": "intent", "intentId": "intent-weather" },
{ "uuid": "node-003", "type": "response", "intentId": null }
"transitions": [
{ "sourceUuid": "node-001", "targetUuid": "node-002", "condition": "default" },
{ "sourceUuid": "node-002", "targetUuid": "node-003", "condition": "match" }
Step 2: Validate Schema Against Engine Constraints and Maximum Transition Depth
Cognigy.AI orchestration enforces a maximum transition depth to prevent stack overflow and excessive latency. You must traverse the path matrix and verify that no path exceeds the configured limit. The default engine constraint is typically 50 hops, but you can parameterize it.
* Validates transition depth and schema constraints
* @param {Object} payload
* @param {number} maxDepth
* @returns {Object} Depth validation result
function validateDepthAndSchema(payload, maxDepth = 50) {
const violations = [];
const visited = new Set();
function traverse(currentUuid, currentDepth, pathHistory) {
if (currentDepth > maxDepth) {
violations.push({
type: 'MAX_DEPTH_EXCEEDED',
path: pathHistory,
depth: currentDepth,
severity: 'BLOCKER'
return;
const edges = payload.pathMatrix[currentUuid];
if (!edges) return;
edges.forEach(edge => {
const newPath = [...pathHistory, edge.target];
traverse(edge.target, currentDepth + 1, newPath);
// Start from nodes with no incoming transitions (entry points)
const entryPoints = payload.nodes.filter(n => n.type === 'start');
entryPoints.forEach(entry => {
traverse(entry.uuid, 0, [entry.uuid]);
maxDepthChecked: maxDepth,
violations,
isValid: violations.length === 0
Step 3: Cycle Detection and State Reachability Checking
Automatic cycle detection prevents infinite conversation loops. You must implement a depth-first search with a recursion stack to identify back edges. State reachability checking ensures every node can be accessed from at least one entry point.
* Detects cycles and verifies state reachability
* @returns {Object} Cycle and reachability analysis
function analyzeGraphStructure(payload) {
const cycles = [];
const reachable = new Set();
const adjacency = new Map();
payload.transitions.forEach(t => {
if (!adjacency.has(t.sourceUuid)) adjacency.set(t.sourceUuid, []);
adjacency.get(t.sourceUuid).push(t.targetUuid);
function detectCycle(node, visited, recStack, path) {
visited.add(node);
recStack.add(node);
path.push(node);
const neighbors = adjacency.get(node) || [];
for (const neighbor of neighbors) {
if (!visited.has(neighbor)) {
detectCycle(neighbor, visited, recStack, path);
} else if (recStack.has(neighbor)) {
const cycleStart = path.indexOf(neighbor);
cycles.push(path.slice(cycleStart).concat(neighbor));
recStack.delete(node);
path.pop();
const recStack = new Set();
payload.nodes.forEach(node => {
if (!visited.has(node.uuid)) {
detectCycle(node.uuid, visited, recStack, []);
// Reachability via BFS from start nodes
const queue = payload.nodes.filter(n => n.type === 'start').map(n => n.uuid);
while (queue.length > 0) {
const current = queue.shift();
if (reachable.has(current)) continue;
reachable.add(current);
(adjacency.get(current) || []).forEach(target => queue.push(target));
const unreachableNodes = payload.nodes
.filter(n => !reachable.has(n.uuid) && n.type !== 'end')
.map(n => n.uuid);
cycles,
unreachableNodes,
isAcyclic: cycles.length === 0,
isFullyReachable: unreachableNodes.length === 0
Step 4: Intent Match Verification and External Callback Synchronization
Intent routing must align with configured NLP models. You verify that every intent node references a valid intent UUID. External testing frameworks require callback handlers to synchronize validation events.
* Verifies intent matches and triggers external callbacks
* @param {string[]} validIntentIds
* @param {Function} onValidationEvent
* @returns {Object} Intent verification result
async function verifyIntentMatches(payload, validIntentIds, onValidationEvent) {
const intentViolations = [];
const intentNodes = payload.nodes.filter(n => n.type === 'intent');
for (const node of intentNodes) {
if (!node.intentId || !validIntentIds.includes(node.intentId)) {
intentViolations.push({
nodeUuid: node.uuid,
expectedIntentId: node.intentId,
status: 'MISSING_OR_INVALID'
const result = {
verifiedCount: intentNodes.length,
violations: intentViolations,
isValid: intentViolations.length === 0
if (typeof onValidationEvent === 'function') {
onValidationEvent({
type: 'INTENT_VERIFICATION_COMPLETE',
payload: result,
return result;
Step 5: Latency Tracking, Success Rates, and Audit Logging
You must measure validation latency from payload construction to graph analysis completion. Success rates track how many flows pass validation in a batch run. Audit logs record governance data for compliance and debugging.
import winston from 'winston';
const auditLogger = winston.createLogger({
level: 'info',
format: winston.format.combine(
winston.format.timestamp(),
winston.format.json()
transports: [
new winston.transports.Console(),
new winston.transports.File({ filename: 'cognigy_validation_audit.log' })
* Tracks validation metrics and generates audit logs
* @param {Object} validationResults
* @returns {Object} Metrics summary
function recordValidationMetrics(payload, validationResults) {
const metrics = {
flowUuid: payload.flowUuid,
validationId: uuidv4(),
latencyMs: validationResults.latencyMs,
depthValid: validationResults.depth.isValid,
cycleValid: validationResults.graph.isAcyclic,
reachabilityValid: validationResults.graph.isFullyReachable,
intentValid: validationResults.intent.isValid,
overallSuccess: [
].every(Boolean),
auditLogger.info('Flow validation completed', metrics);
return metrics;
level: 'info',
format: winston.format.combine(winston.format.timestamp(), winston.format.json()),
transports: [new winston.transports.Console()]
class TransitionValidator {
constructor(tenantUrl, apiToken) {
baseURL: `${tenantUrl}/api/v1`,
headers: { 'Authorization': `Bearer ${apiToken}` },
timeout: 10000
res => res,
err => {
if (err.response?.status === 429) {
const delay = (err.response.headers['retry-after'] || 2) * 1000;
return new Promise(r => setTimeout(r, delay)).then(() => this.client.request(err.config));
return Promise.reject(err);
this.metricsHistory = [];
async validateFlow(flowUuid, validIntentIds, callback) {
const start = performance.now();
let flowData, payload, depthResult, graphResult, intentResult;
const res = await this.client.get(`/flows/${flowUuid}`);
flowData = { uuid: flowUuid, nodes: res.data.nodes, transitions: res.data.transitions };
} catch (err) {
throw new Error(`Failed to fetch flow ${flowUuid}: ${err.message}`);
payload = {
flowUuid,
pathMatrix: this._buildMatrix(flowData),
errorDirectives: this._checkMissingTargets(flowData),
depthResult = this._validateDepth(payload, 50);
graphResult = this._analyzeGraph(payload);
intentResult = await this._verifyIntents(payload, validIntentIds, callback);
const latencyMs = performance.now() - start;
const overallSuccess = depthResult.isValid && graphResult.isAcyclic && graphResult.isFullyReachable && intentResult.isValid;
const metrics = {
flowUuid,
latencyMs,
overallSuccess,
depthValid: depthResult.isValid,
cycleValid: graphResult.isAcyclic,
reachabilityValid: graphResult.isFullyReachable,
intentValid: intentResult.isValid,
this.metricsHistory.push(metrics);
auditLogger.info('Validation complete', metrics);
return metrics;
_buildMatrix(flowData) {
const matrix = {};
if (!matrix[t.sourceUuid]) matrix[t.sourceUuid] = [];
matrix[t.sourceUuid].push({ target: t.targetUuid, condition: t.condition || 'default' });
return matrix;
_checkMissingTargets(flowData) {
return flowData.transitions
.filter(t => !validUuids.has(t.targetUuid))
.map(t => ({ type: 'MISSING_TARGET', source: t.sourceUuid, target: t.targetUuid }));
_validateDepth(payload, maxDepth) {
const traverse = (uuid, depth, path) => {
if (depth > maxDepth) {
violations.push({ path, depth });
return;
(payload.pathMatrix[uuid] || []).forEach(e => traverse(e.target, depth + 1, [...path, e.target]));
payload.nodes.filter(n => n.type === 'start').forEach(n => traverse(n.uuid, 0, [n.uuid]));
return { isValid: violations.length === 0, violations };
_analyzeGraph(payload) {
const cycles = [];
const adj = {};
if (!adj[t.sourceUuid]) adj[t.sourceUuid] = [];
adj[t.sourceUuid].push(t.targetUuid);
const stack = new Set();
const findCycle = (n, path) => {
visited.add(n);
stack.add(n);
path.push(n);
(adj[n] || []).forEach(nb => {
if (!visited.has(nb)) findCycle(nb, path);
else if (stack.has(nb)) cycles.push(path.slice(path.indexOf(nb)).concat(nb));
stack.delete(n);
path.pop();
payload.nodes.forEach(n => { if (!visited.has(n.uuid)) findCycle(n.uuid, []); });
while (queue.length) {
const curr = queue.shift();
if (!reachable.has(curr)) {
reachable.add(curr);
(adj[curr] || []).forEach(t => queue.push(t));
const unreachable = payload.nodes.filter(n => !reachable.has(n.uuid) && n.type !== 'end').map(n => n.uuid);
return { cycles, unreachableNodes: unreachable, isAcyclic: cycles.length === 0, isFullyReachable: unreachable.length === 0 };
async _verifyIntents(payload, validIds, callback) {
const violations = payload.nodes
.filter(n => n.type === 'intent' && (!n.intentId || !validIds.includes(n.intentId)))
.map(n => ({ nodeUuid: n.uuid, status: 'INVALID' }));
const result = { verifiedCount: payload.nodes.filter(n => n.type === 'intent').length, violations, isValid: violations.length === 0 };
if (callback) callback({ type: 'INTENT_CHECK', result, timestamp: new Date().toISOString() });
return result;
// Usage example
async function runValidation() {
const validator = new TransitionValidator('https://mytenant.cognigy.ai', 'YOUR_BEARER_TOKEN');
const validIntents = ['intent-weather', 'intent-support', 'intent-booking'];
const metrics = await validator.validateFlow('f47ac10b-58cc-4372-a567-0e02b2c3d479', validIntents, (evt) => console.log('Callback:', evt));
console.log('Validation Metrics:', JSON.stringify(metrics, null, 2));
runValidation().catch(console.error);
- What causes it: The Bearer token is expired, malformed, or lacks the
flow:readscope. - How to fix it: Rotate the token via your identity provider and verify scope assignment in the Cognigy.AI admin settings. Ensure the
Authorizationheader uses the exactBearer <token>format. - Code showing the fix: The interceptor in
TransitionValidatorcatches 401 and throws a descriptive error. Implement a token refresh routine before callingvalidateFlow.
Error: 403 Forbidden
- What causes it: The API token has insufficient permissions for the target flow or tenant.
- How to fix it: Assign the
flow:readandintent:readroles to the service account. Verify the flow UUID belongs to the authenticated tenant. - Code showing the fix: Wrap the API call in a try/catch and check
err.response?.status === 403. Log the flow UUID and token subject for audit trails.
- What causes it: Exceeding Cognigy.AI rate limits during batch validation runs.
- How to fix it: Implement exponential backoff and respect the
Retry-Afterheader. The provided interceptor automatically retries once after the specified delay. - Code showing the fix: The
client.interceptors.responseblock handles 429 by readingretry-afterand deferring the request.
Error: Cycle Detection False Positives
- What causes it: Intentional fallback loops that route back to a start node without a depth violation.
- How to fix it: Filter cycles that terminate at designated
endorfallbacknodes. Adjust the graph analysis to ignore transitions marked withtype: "system". - Code showing the fix: Modify
_analyzeGraphto exclude edges wherecondition === "system_fallback"before building the adjacency list.
Error: Intent Match Verification Failures
- What causes it: NLP model updates removed or renamed intent UUIDs referenced in the flow.
- How to fix it: Sync the
validIntentIdsarray with the current NLP model export. Use the/api/v1/intentsendpoint to fetch the authoritative list before validation. - Code showing the fix: Call
this.client.get('/intents')and map the response tovalidIdsbefore invokingvalidateFlow.
