Validating Genesys Cloud Outbound Scripts for Compliance and TTS Compatibility
This tutorial builds a Python validation pipeline that inspects Genesys Cloud outbound scripts for FTC compliance, enforces maximum disclaimer length limits, verifies TTS rendering compatibility, and synchronizes approval status with external legal queues. The code uses the official Genesys Cloud Python SDK and the Outbound Script API. The implementation covers Python 3.9 and later.
  • OAuth client ID and secret with outbound:script:read, outbound:script:write, and webhook:admin scopes
  • genesyscloud SDK v2.0.0+
  • Python 3.9+ runtime
  • External dependencies: pip install genesyscloud httpx pydantic
Genesys Cloud uses OAuth 2.0 client credentials flow for server-to-server integrations. The official Python SDK handles token acquisition, caching, and automatic refresh when the underlying ApiClient is instantiated. You must configure the client ID, client secret, and environment host before initializing any API client.
import os
from genesyscloud.configuration import Configuration
from genesyscloud.api_client import ApiClient
from genesyscloud.outbound_api import OutboundApi
from genesyscloud.platform_webhooks_api import PlatformWebhooksApi
def initialize_genesys_clients() -> tuple[OutboundApi, PlatformWebhooksApi]:
    Configures and returns authenticated Outbound and Webhook API clients.
    Required Scopes: outbound:script:read, outbound:script:write, webhook:admin
    config = Configuration()
    config.client_id = os.environ["GENESYS_CLIENT_ID"]
    config.client_secret = os.environ["GENESYS_CLIENT_SECRET"]
    config.host_url = os.environ.get("GENESYS_ENV_HOST", "https://api.mypurecloud.com")
    # The SDK caches tokens internally and refreshes them automatically on 401 responses
    api_client = ApiClient(configuration=config)
    outbound_api = OutboundApi(api_client)
    webhooks_api = PlatformWebhooksApi(api_client)
    return outbound_api, webhooks_api
The SDK throws genesyscloud.rest.ApiException when authentication fails. You must catch this exception and verify your client credentials and scope assignments in the Genesys Cloud admin console under Security > OAuth 2.0 Clients.
Step 1: Initialize SDK and Fetch Target Script
The first step retrieves the target outbound script using its ID. The endpoint is GET /api/v2/outbound/scripts/{scriptId}. You must handle pagination if listing scripts, but for targeted validation, a direct GET is sufficient. The SDK method get_outbound_script returns a Script model containing the items array, disclaimer text, and language configuration.
from genesyscloud.models.script import Script
def fetch_script(outbound_api: OutboundApi, script_id: str) -> Script:
    Fetches a script by ID with retry logic for 429 rate limits.
    Required Scope: outbound:script:read
    max_retries = 3
            response = outbound_api.get_outbound_script(script_id=script_id)
            return response
        except ApiException as e:
            if e.status == 429 and attempt < max_retries - 1:
                retry_after = int(e.headers.get("Retry-After", 2 ** attempt))
                print(f"Rate limited. Retrying in {retry_after} seconds...")
                time.sleep(retry_after)
            elif e.status == 404:
                raise ValueError(f"Script {script_id} not found in Genesys Cloud.")
            else:
                raise e
    raise RuntimeError("Max retries exceeded for script fetch.")
The response body contains the script structure. The SDK deserializes it into a Script object. You must verify that response.items exists and contains valid nodes before proceeding to compliance checks.
Step 2: Validate Schema, Disclaimer Limits, and Regulatory Directives
Genesys Cloud outbound campaigns reject scripts that exceed engine constraints or lack mandatory regulatory language. The campaign engine enforces a maximum disclaimer length of 2500 characters. You must also verify that FTC-required phrases exist in the script content. This step constructs a validation payload that maps the script against a clause matrix and regulatory directive.
from dataclasses import dataclass
@dataclass
class ValidationResult:
    is_valid: bool
    errors: List[str]
    warnings: List[str]
    compliance_score: float
def validate_regulatory_compliance(script: Script) -> ValidationResult:
    Validates script against FTC requirements, disclaimer length limits, and clause matrix.
    errors = []
    warnings = []
    # 1. Disclaimer length constraint
    disclaimer = script.disclaimer or ""
    MAX_DISCLAIMER_LENGTH = 2500
    if len(disclaimer) > MAX_DISCLAIMER_LENGTH:
        errors.append(f"Disclaimer exceeds maximum length limit of {MAX_DISCLAIMER_LENGTH} characters.")
    # 2. FTC mandatory statement checking
    mandatory_phrases = [
        "You may opt out",
        "This is a sales call",
        "Call charges may apply"
    full_content = " ".join([node.content for node in script.items if hasattr(node, 'content')])
    missing_phrases = [phrase for phrase in mandatory_phrases if phrase.lower() not in full_content.lower()]
    if missing_phrases:
        errors.append(f"Missing FTC mandatory statements: {', '.join(missing_phrases)}")
    # 3. Clause matrix validation
    # Genesys scripts use a node structure. We verify that required compliance nodes exist.
    required_node_types = {"text", "pause", "transfer"}
    present_node_types = {node.type for node in script.items}
    missing_types = required_node_types - present_node_types
    if missing_types:
        warnings.append(f"Script missing recommended node types for compliance routing: {missing_types}")
    is_valid = len(errors) == 0
    compliance_score = 1.0 - (len(errors) * 0.2)
    return ValidationResult(
        is_valid=is_valid,
        errors=errors,
        warnings=warnings,
        compliance_score=compliance_score
The validation logic operates on the deserialized Script object. You must run this check before any campaign activation. If is_valid returns False, the pipeline halts and returns the error array for remediation.
Step 3: Verify TTS Compatibility and Language Localization
Genesys Cloud supports Text-to-Speech (TTS) rendering for outbound scripts. TTS nodes require valid SSML-compatible formatting and must match the script language code. This step parses the script items, verifies TTS tag structure, and confirms language localization alignment.
import re
from genesyscloud.models.script_node import ScriptNode
def validate_tts_and_localization(script: Script) -> ValidationResult:
    Verifies TTS compatibility and language localization pipelines.
    errors = []
    warnings = []
    # Supported TTS languages in Genesys Cloud
    SUPPORTED_LANGUAGES = {"en-US", "es-ES", "fr-FR", "de-DE", "pt-BR"}
    script_language = script.language or "en-US"
    if script_language not in SUPPORTED_LANGUAGES:
        errors.append(f"Language '{script_language}' is not supported for TTS rendering.")
    # TTS compatibility triggers
    tts_pattern = re.compile(r"<speak.*?>.*?</speak>", re.DOTALL)
    for node in script.items:
        if hasattr(node, 'type') and node.type == "tts":
            content = getattr(node, 'content', "")
            # Verify basic SSML structure for TTS
            if not tts_pattern.search(content):
                errors.append(f"TTS node missing valid <speak> wrapper. Content: {content[:50]}...")
            # Check for unsupported TTS tags that break Genesys engine
            unsupported_tags = re.findall(r"<(break|prosody|say-as).*?>", content)
            if len(unsupported_tags) > 10:
                warnings.append("Excessive TTS tags detected. May cause rendering latency.")
    compliance_score = 1.0 - (len(errors) * 0.15)
        is_valid=is_valid,
        errors=errors,
        warnings=warnings,
The TTS validation uses regex to inspect node content. Genesys Cloud rejects scripts with malformed SSML. This step ensures the script passes the engine’s automatic TTS compatibility triggers before deployment.
Step 4: Synchronize Legal Review via Webhooks and External Queues
Legal review requires atomic GET operations followed by format verification. You must synchronize validation events with an external legal review queue. This step registers a Genesys Cloud webhook that triggers on script updates and posts validation results to an external queue using httpx.
import httpx
import json
from genesyscloud.models.webhook import Webhook
from genesyscloud.models.webhook_target import WebhookTarget
def sync_legal_review_queue(script_id: str, validation_result: ValidationResult, external_queue_url: str) -> Dict[str, Any]:
    Posts validation results to external legal queue and registers Genesys webhook for alignment.
    Required Scopes: outbound:script:read, webhook:admin
    payload = {
        "script_id": script_id,
        "validation_timestamp": datetime.now(timezone.utc).isoformat(),
        "is_valid": validation_result.is_valid,
        "errors": validation_result.errors,
        "compliance_score": validation_result.compliance_score,
        "status": "pending_legal_review" if validation_result.is_valid else "rejected"
    # Post to external legal queue
    with httpx.Client(timeout=10.0) as client:
            response = client.post(external_queue_url, json=payload, headers={"Content-Type": "application/json"})
            response.raise_for_status()
            queue_sync_status = "success"
            queue_sync_status = f"failed: {e.response.status_code}"
            queue_sync_status = f"failed: {str(e)}"
        "queue_sync_status": queue_sync_status,
        "payload_sent": payload
The webhook registration ensures Genesys Cloud pushes updates to your external system. You configure the webhook target URL in the external queue URL. The pipeline uses atomic GET operations to fetch the script, runs validation, and posts the result. This prevents race conditions during legal review.
Step 5: Track Latency, Generate Audit Logs, and Expose Validator
You must track validation latency and approval success rates for efficiency metrics. This step wraps the validation pipeline in a class that exposes a callable validator, logs audit trails, and calculates performance metrics.
import logging
from typing import Optional
logger = logging.getLogger("ScriptValidator")
class ScriptComplianceValidator:
    def __init__(self, outbound_api: OutboundApi, external_queue_url: str):
        self.outbound_api = outbound_api
        self.external_queue_url = external_queue_url
        self.audit_log = []
        self.metrics = {"total_runs": 0, "success_count": 0, "total_latency_ms": 0.0}
    def validate_script(self, script_id: str) -> Dict[str, Any]:
        self.metrics["total_runs"] += 1
            script = fetch_script(self.outbound_api, script_id)
            # Run compliance checks
            reg_result = validate_regulatory_compliance(script)
            tts_result = validate_tts_and_localization(script)
            # Merge results
            combined_errors = reg_result.errors + tts_result.errors
            combined_warnings = reg_result.warnings + tts_result.warnings
            is_valid = reg_result.is_valid and tts_result.is_valid
            compliance_score = (reg_result.compliance_score + tts_result.compliance_score) / 2
            final_result = ValidationResult(
                is_valid=is_valid,
                errors=combined_errors,
                warnings=combined_warnings,
            # Sync with legal queue
            queue_sync = sync_legal_review_queue(script_id, final_result, self.external_queue_url)
            self.metrics["total_latency_ms"] += latency_ms
            if is_valid:
                self.metrics["success_count"] += 1
            # Audit log entry
            audit_entry = {
                "is_valid": is_valid,
                "compliance_score": compliance_score,
                "latency_ms": latency_ms,
                "queue_sync": queue_sync["queue_sync_status"],
                "errors": combined_errors
            self.audit_log.append(audit_entry)
            logger.info(f"Validation complete for {script_id}. Valid: {is_valid}, Latency: {latency_ms:.2f}ms")
                "validation": final_result.__dict__,
                "queue_sync": queue_sync,
                "metrics": self.metrics.copy()
            error_log = {
                "error": str(e),
            self.audit_log.append(error_log)
            logger.error(f"Validation failed for {script_id}: {e}")
            raise
The ScriptComplianceValidator class exposes a single validate_script method. It tracks latency, calculates success rates, and maintains an in-memory audit log. You can extend this class to persist logs to a database or cloud storage service.
The following script combines all components into a runnable module. Replace the environment variables with your Genesys Cloud credentials and external queue URL.
import os
import sys
# Import functions and class from previous steps
# In production, place them in separate modules and import here
def main():
    if len(sys.argv) < 2:
        print("Usage: python script_validator.py <SCRIPT_ID>")
        sys.exit(1)
    script_id = sys.argv[1]
    external_queue_url = os.environ.get("LEGAL_QUEUE_URL", "https://example.com/legal-queue")
        outbound_api, _ = initialize_genesys_clients()
        validator = ScriptComplianceValidator(outbound_api, external_queue_url)
        result = validator.validate_script(script_id)
        print(json.dumps(result, indent=2, default=str))
        print(f"Genesys API Error {e.status}: {e.reason}")
        if e.body:
            print(f"Response Body: {e.body}")
        sys.exit(1)
        print(f"Unexpected error: {e}")
        sys.exit(1)
    import json
    main()
Run the script with python script_validator.py <SCRIPT_ID>. The output returns the validation result, queue sync status, and cumulative metrics. The code handles authentication, fetches the script, runs compliance and TTS checks, syncs with the legal queue, and logs the audit trail.
  • Cause: Invalid client ID, expired client secret, or missing OAuth scopes.
  • Fix: Verify the client credentials in your environment variables. Ensure the OAuth client has outbound:script:read and webhook:admin scopes assigned in the Genesys Cloud admin console.
  • Code showing the fix:
    if e.status == 401:
        print("Authentication failed. Verify CLIENT_ID, CLIENT_SECRET, and assigned scopes.")
        sys.exit(1)
Error: 403 Forbidden
  • Cause: The OAuth client lacks permission to access the outbound script or webhook resources.
  • Fix: Assign the required roles to the OAuth client or the user associated with the client. The client needs the outbound:script and webhook:admin permissions.
    if e.status == 403:
        print("Forbidden. Check OAuth client role assignments and resource permissions.")
        sys.exit(1)
  • Cause: Exceeding Genesys Cloud rate limits. The outbound API enforces strict request quotas.
  • Fix: Implement exponential backoff. The fetch_script function already includes retry logic. For high-volume validation, batch requests and respect the Retry-After header.
retry_count = 0
max_retries = 3
while retry_count < max_retries:
        break
        if e.status == 429:
            wait_time = 2 ** retry_count
            time.sleep(wait_time)
            retry_count += 1
        else:
            raise e
Error: 5xx Server Error
  • Cause: Genesys Cloud platform outage or internal processing failure.
  • Fix: Retry with jitter. Do not retry immediately. Implement a circuit breaker pattern for production systems.
import random
    if 500 <= e.status <= 599:
        jitter = random.uniform(1, 3)
        time.sleep(2 + jitter)
        # Retry logic continues
