Validating and transforming Genesys Cloud EventBridge interaction.started schemas using AWS Glue Schema Registry and a Python Lambda processor
  • A Python AWS Lambda function that receives Genesys Cloud interaction.started events from EventBridge, validates the payload against an AWS Glue Schema Registry schema, and transforms the data into a normalized JSON format for downstream consumption.
  • This uses the AWS Glue Schema Registry API via boto3 and the AWS Lambda runtime.
  • The tutorial covers Python 3.9+ with boto3, jsonschema, and standard AWS SDK patterns.
  • AWS IAM execution role with glue:GetSchema, glue:PutSchemaVersion, logs:CreateLogGroup, and logs:PutLogEvents permissions.
  • Genesys Cloud EventBridge integration configured to push interaction.started events to an AWS EventBridge custom bus.
  • AWS Glue Schema Registry with a registered JSON schema for the Genesys payload.
  • Python 3.9+ runtime with boto3>=1.28.0 and jsonschema>=4.18.0 included in the Lambda deployment package.
  • No external dependencies beyond standard AWS SDK packages.
  • AWS Lambda resolves credentials automatically through the attached IAM execution role. The boto3 client uses the environment variables injected by the Lambda runtime.
  • Genesys Cloud EventBridge pushes events directly to AWS EventBridge using a server-to-server connection. No OAuth tokens are required in the Lambda handler.
  • Code to verify credential resolution and initialize the Glue client:
import os
import boto3
import logging
logger = logging.getLogger()
logger.setLevel(logging.INFO)
# AWS credentials are injected via IAM execution role
# boto3 automatically reads AWS_ACCESS_KEY_ID, AWS_SECRET_ACCESS_KEY, AWS_SESSION_TOKEN
glue_client = boto3.client("glue")
Step 1: Parse EventBridge Payload and Extract Genesys Data
  • EventBridge delivers events with a standard AWS envelope. The Genesys Cloud payload resides in detail.
  • Extract the interaction.started fields and prepare for validation.
import json
def parse_eventbridge_event(event: Dict[str, Any]) -> Dict[str, Any]:
    """Extract Genesys Cloud interaction.started payload from EventBridge envelope."""
    if "detail" not in event:
        raise ValueError("Invalid EventBridge payload: missing 'detail' key")
    detail = event["detail"]
    return detail
Expected EventBridge payload structure:
  "version": "0",
  "id": "a1b2c3d4-5678-90ab-cdef-EXAMPLE11111",
  "detail-type": "interaction.started",
  "source": "genesyscloud",
  "account": "123456789012",
  "time": "2024-01-15T10:30:00Z",
  "region": "us-east-1",
  "resources": ["arn:aws:events:us-east-1:123456789012:rule/GenesysEventRule"],
  "detail": {
    "interaction": {
      "id": "inter-98765432-1234-5678-90ab-cdefEXAMPLE",
      "start_time": "2024-01-15T10:30:00.000Z",
      "channel_type": "voice",
      "routing": {
        "queue_id": "queue-11223344-5566-7788-99aa-bbccddeeff00",
        "queue_name": "Sales Support"
      "customer": {
        "email": "customer@example.com",
        "name": "John Doe"
Step 2: Validate Against AWS Glue Schema Registry
  • Use boto3 to fetch the latest schema version from Glue Schema Registry.
  • Deserialize the schema definition and validate the incoming payload using jsonschema.
  • Handle ClientError for 404 (schema not found), 403 (IAM denied), and 5xx (service unavailable).
  • IAM permission required: glue:GetSchema
import jsonschema
from botocore.exceptions import ClientError, BotoCoreError
SCHEMA_REGISTRY_NAME = "GenesysInteractionRegistry"
SCHEMA_NAME = "InteractionStartedSchema"
def get_schema_definition() -> Dict[str, Any]:
    """Fetch the latest schema definition from AWS Glue Schema Registry."""
        response = glue_client.get_schema(
            RegistryName=SCHEMA_REGISTRY_NAME,
            SchemaName=SCHEMA_NAME
        schema_def = response.get("SchemaDefinition")
        if not schema_def:
            raise ValueError("Schema definition is empty in Glue Registry")
        return json.loads(schema_def)
    except ClientError as e:
        error_code = e.response["Error"]["Code"]
        if error_code == "EntityNotFoundException":
            raise RuntimeError(f"Schema {SCHEMA_NAME} not found in registry {SCHEMA_REGISTRY_NAME}")
        elif error_code == "AccessDeniedException":
            raise RuntimeError("IAM role lacks glue:GetSchema permission")
        else:
            raise
    except BotoCoreError as e:
        raise RuntimeError(f"AWS SDK error during schema retrieval: {e}")
Expected Glue API response structure:
  "SchemaDefinition": "{ \"type\": \"object\", \"properties\": { \"interaction\": { \"type\": \"object\", \"properties\": { \"id\": { \"type\": \"string\" }, \"start_time\": { \"type\": \"string\" }, \"channel_type\": { \"type\": \"string\" }, \"routing\": { \"type\": \"object\" }, \"customer\": { \"type\": \"object\" } }, \"required\": [\"id\", \"start_time\"] } }, \"required\": [\"interaction\"] }",
  "SchemaArn": "arn:aws:glue:us-east-1:123456789012:registry/GenesysInteractionRegistry/schema/InteractionStartedSchema",
  "SchemaVersionId": "v1"
Step 3: Transform Validated Payload
  • Map Genesys Cloud interaction.started fields to a normalized downstream format.
  • Handle missing optional fields gracefully.
  • Return the transformed payload ready for S3, Kinesis, or DynamoDB.
from datetime import datetime
def transform_interaction(payload: Dict[str, Any]) -> Dict[str, Any]:
    """Transform Genesys interaction.started payload to normalized format."""
    interaction = payload.get("interaction", {})
    routing = interaction.get("routing", {})
    normalized = {
        "interaction_id": interaction.get("id"),
        "start_time": interaction.get("start_time"),
        "channel_type": interaction.get("channel_type"),
        "queue_id": routing.get("queue_id"),
        "queue_name": routing.get("queue_name"),
        "customer_email": interaction.get("customer", {}).get("email"),
        "customer_name": interaction.get("customer", {}).get("name"),
        "attributes": interaction.get("attributes", {}),
        "processed_at": datetime.utcnow().isoformat() + "Z"
    # Enforce required fields after transformation
    if not normalized["interaction_id"]:
        raise ValueError("Transformation failed: missing interaction.id")
    return normalized
Step 4: Lambda Handler with Retry and Error Routing
  • Combine parsing, validation, and transformation.
  • Implement structured error handling with Dead Letter Queue (DLQ) routing logic.
  • Return standardized response for EventBridge.
def lambda_handler(event: Dict[str, Any], context: Any) -> Dict[str, Any]:
    """AWS Lambda handler for Genesys Cloud interaction.started events."""
        # Step 1: Parse
        gen_payload = parse_eventbridge_event(event)
        # Step 2: Validate
        schema = get_schema_definition()
        jsonschema.validate(instance=gen_payload, schema=schema)
        # Step 3: Transform
        transformed = transform_interaction(gen_payload)
        logger.info("Successfully processed interaction: %s", transformed["interaction_id"])
            "statusCode": 200,
            "body": json.dumps(transformed)
    except jsonschema.ValidationError as e:
        logger.error("Schema validation failed: %s", e.message)
            "statusCode": 400,
            "body": json.dumps({"error": "Schema validation failed", "details": str(e)})
    except (ValueError, RuntimeError) as e:
        logger.error("Processing failed: %s", str(e))
            "statusCode": 400,
            "body": json.dumps({"error": "Processing failed", "details": str(e)})
        # Retry on throttling or service unavailable
        if error_code in ("ThrottlingException", "ServiceUnavailable"):
            logger.warning("AWS Glue throttled/unavailable. Lambda will retry via EventBridge.")
            return {"statusCode": 500, "body": json.dumps({"error": "AWS Glue service unavailable"})}
        raise
        logger.exception("Unexpected error processing event")
            "statusCode": 500,
            "body": json.dumps({"error": "Internal server error", "details": str(e)})
  • Full, copy-pasteable Lambda module.
  • Ready to deploy with IAM role and Glue Schema Registry configured.
import os
import json
import logging
import boto3
import jsonschema
    return event["detail"]
        if not schema_def:
        else:
            raise
    normalized = {
    return normalized
            "statusCode": 200,
            "statusCode": 400,
            "statusCode": 400,
            logger.warning("AWS Glue throttled/unavailable. EventBridge will retry.")
        raise
            "statusCode": 500,
Error: EntityNotFoundException
  • What causes it: The RegistryName or SchemaName does not match an existing entry in AWS Glue Schema Registry.
  • How to fix it: Verify the exact names in the AWS Console under Glue > Schema Registry. Ensure the Lambda environment variables or hardcoded strings match exactly.
  • Code showing the fix:
import boto3
glue = boto3.client("glue")
    glue.get_schema(RegistryName="GenesysInteractionRegistry", SchemaName="InteractionStartedSchema")
    print("Schema verified successfully")
except glue.exceptions.EntityNotFoundException:
    print("Schema not found. Check RegistryName and SchemaName spelling.")
Error: ThrottlingException on glue:GetSchema
  • What causes it: AWS Glue Schema Registry enforces per-account rate limits. High-volume interaction.started events trigger rapid get_schema calls.
  • How to fix it: Cache the schema definition in Lambda init scope or use an S3-backed schema cache. The Lambda handler already returns 500 to trigger EventBridge retry, but caching prevents the cascade.
_cached_schema: Optional[Dict[str, Any]] = None
def get_schema_definition_cached() -> Dict[str, Any]:
    global _cached_schema
    if _cached_schema is None:
        _cached_schema = get_schema_definition()
    return _cached_schema
Error: jsonschema.ValidationError: Additional properties not allowed
  • What causes it: Genesys Cloud updates the interaction.started payload with new fields (for example interaction.routing.skills), and the Glue schema uses additionalProperties: false.
  • How to fix it: Update the Glue Schema Registry definition to allow additional properties or evolve the schema version. AWS Glue supports schema evolution with compatibility modes (BACKWARD, FORWARD, FULL).
import json
new_schema = json.loads(current_schema_def)
new_schema["additionalProperties"] = True
glue_client.put_schema_version(
    SchemaName=SCHEMA_NAME,
    SchemaDefinition=json.dumps(new_schema)
