Validating and Managing Genesys Cloud Web Messaging Origin Headers with Python SDK
- A Python module that validates, formats, and securely updates iframe origin headers for the Genesys Cloud Web Messaging Guest API.
- The module uses the
genesyscloudPython SDK andhttpxto enforce CORS constraints, verify SSL certificates, and prevent wildcard abuse. - Python 3.9+ is covered with production-grade error handling, retry logic, webhook synchronization, and audit logging.
- OAuth Client Credentials flow with scopes:
webmessaging:view,webmessaging:admin,webhooks:admin - Genesys Cloud Python SDK version 2.10.0+ (
pip install genesyscloud) - Python 3.9+ runtime with
httpxandpydantic(pip install httpx pydantic) - Environment variables:
GENESYS_CLOUD_ENV,GENESYS_CLOUD_CLIENT_ID,GENESYS_CLOUD_CLIENT_SECRET,WAF_WEBHOOK_URL
The Genesys Cloud Python SDK handles OAuth token acquisition and automatic refresh. Initialize the SDK before executing any API calls.
import os
import genesyscloud
from genesyscloud.environment import Environment
def init_genesys_sdk() -> genesyscloud.platform.client.PureCloudPlatformClientV2:
env = os.getenv("GENESYS_CLOUD_ENV", "mypurecloud.com")
client_id = os.getenv("GENESYS_CLOUD_CLIENT_ID")
client_secret = os.getenv("GENESYS_CLOUD_CLIENT_SECRET")
raise ValueError("GENESYS_CLOUD_CLIENT_ID and GENESYS_CLOUD_CLIENT_SECRET must be set.")
genesyscloud.init(
environment=env,
client_id=client_id,
client_secret=client_secret
return genesyscloud.platform.client.PureCloudPlatformClientV2()
The SDK caches the access token in memory and automatically requests a new token using the refresh token when the current token expires. No manual token management is required.
Step 1: Retrieve Existing Web Messaging Configuration
Fetch the active Web Messaging configuration to inspect current allowed_origins. The endpoint is GET /api/v2/webmessaging/webmessagingconfigurations. The required scope is webmessaging:view.
import logging
from genesyscloud.webmessaging import WebMessagingApi
from genesyscloud.platform.client.exceptions import ApiException
def fetch_webmessaging_config(client: genesyscloud.platform.client.PureCloudPlatformClientV2, config_id: str) -> dict:
api = WebMessagingApi(client)
response = api.get_webmessaging_webmessaging_configuration(config_id)
logger.info("Retrieved Web Messaging configuration: %s", config_id)
return response.to_dict()
except ApiException as e:
if e.status == 404:
raise ValueError(f"Web Messaging configuration {config_id} not found.")
elif e.status in (401, 403):
raise PermissionError(f"Authentication or authorization failed: {e.body}")
else:
raise
Expected Response Body:
"name": "Production Web Messaging",
"enabled": true,
"allowed_origins": ["https://app.example.com", "https://secure.example.com"],
"enable_guest_user_creation": true,
"cors_origins": ["https://app.example.com"]
Step 2: Construct Validation Payloads and Execute Origin Verification
Build a validation pipeline that checks protocol format, wildcard placement, subdomain matching, and SSL certificate validity. The pipeline uses an origin_ref dictionary, a header_matrix rule set, and a verify_directive flag to control execution flow.
import re
import httpx
from typing import List, Dict, Tuple
MAX_ORIGIN_LIMIT = 50
WILDCARD_PATTERN = re.compile(r"^https://\*\.[a-zA-Z0-9]([a-zA-Z0-9-]{0,61}[a-zA-Z0-9])?(\.[a-zA-Z]{2,})+$")
STANDARD_PATTERN = re.compile(r"^https://[a-zA-Z0-9]([a-zA-Z0-9-]{0,61}[a-zA-Z0-9])?(\.[a-zA-Z0-9]([a-zA-Z0-9-]{0,61}[a-zA-Z0-9])?)*\.[a-zA-Z]{2,}$")
header_matrix: Dict[str, Dict] = {
"protocol": {"allowed": ["https"], "enforce_tls": True},
"wildcard_position": {"allowed_index": 0, "max_wildcards": 1},
"max_domains": {"limit": MAX_ORIGIN_LIMIT}
def verify_ssl_certificate(origin: str) -> bool:
"""Performs an atomic HTTP GET to verify SSL certificate and format."""
with httpx.Client(timeout=5.0, verify=True) as client:
response = client.get(origin, follow_redirects=False)
return response.status_code < 500
except httpx.SSLError:
return False
except httpx.RequestError:
return False
def validate_origin(origin: str) -> Tuple[bool, str]:
"""Validates a single origin against CORS constraints and header-matrix rules."""
if not origin.startswith("https://"):
return False, "Protocol must be https://"
if WILDCARD_PATTERN.match(origin):
if origin.count("*") > header_matrix["wildcard_position"]["max_wildcards"]:
return False, "Wildcard abuse detected. Only one wildcard allowed in subdomain position."
return True, "Valid wildcard origin"
elif STANDARD_PATTERN.match(origin):
return True, "Valid standard origin"
else:
return False, "Invalid hostname format or unsupported path/query"
def construct_validation_payload(origins: List[str], verify_directive: bool = True) -> Dict:
"""Constructs origin-ref reference and executes verify directive if enabled."""
origin_ref: Dict[str, bool] = {}
invalid_origins: List[str] = []
ssl_verified: List[str] = []
if len(origins) > header_matrix["max_domains"]["limit"]:
raise ValueError(f"Origin list exceeds maximum domain list limit of {header_matrix['max_domains']['limit']}.")
for origin in origins:
is_valid, reason = validate_origin(origin)
if not is_valid:
invalid_origins.append(origin)
origin_ref[origin] = False
if verify_directive:
ssl_ok = verify_ssl_certificate(origin)
if not ssl_ok:
logger.warning("SSL verification failed for %s", origin)
else:
ssl_verified.append(origin)
origin_ref[origin] = True
else:
"origin_ref": origin_ref,
"valid_origins": ssl_verified,
"invalid_origins": invalid_origins,
"verify_directive": verify_directive,
"header_matrix": header_matrix
The verify_directive flag controls whether SSL certificate verification pipelines run. When set to True, the function performs an atomic HTTP GET operation to confirm the certificate chain is valid and the host responds without 5xx errors. This prevents embedding broken or insecure domains.
Step 3: Update Configuration with Retry Logic and Block Triggers
Apply the validated origins to the Web Messaging configuration. The update uses exponential backoff for 429 rate-limit responses and automatic block triggers when invalid origins are detected.
from typing import Optional
def update_webmessaging_origins(
config_id: str,
validated_origins: List[str],
max_retries: int = 3,
base_delay: float = 1.0
) -> dict:
payload = {
"id": config_id,
"allowed_origins": validated_origins,
"enable_guest_user_creation": True
response = api.put_webmessaging_webmessaging_configuration(config_id, body=payload)
logger.info("Successfully updated origins for %s", config_id)
if e.status == 429:
wait_time = base_delay * (2 ** attempt)
logger.warning("Rate limited (429). Retrying in %.1f seconds...", wait_time)
time.sleep(wait_time)
elif e.status == 400:
raise ValueError(f"Bad request payload: {e.body}")
raise PermissionError(f"Authorization failed: {e.body}")
else:
raise
raise RuntimeError("Max retries exceeded for configuration update.")
The put_webmessaging_webmessaging_configuration call maps to PUT /api/v2/webmessaging/webmessagingconfigurations/{webMessagingConfigurationId}. The required scope is webmessaging:admin. The retry loop handles 429 responses automatically. If any origin fails validation in Step 2, the block trigger prevents the API call entirely.
Step 4: Synchronize Validation Events with WAF Webhooks and Track Metrics
Register a Genesys Cloud webhook to synchronize origin validation events with an external WAF. Track latency, success rates, and generate audit logs for web governance.
import json
from genesyscloud.webhooks import WebhooksApi
from genesyscloud.webhooks.models import Webhook
class OriginValidatorMetrics:
def __init__(self):
self.total_validations = 0
self.successful_validations = 0
self.total_latency_ms = 0.0
self.audit_log: List[Dict] = []
def record_attempt(self, origin: str, success: bool, latency_ms: float):
self.total_validations += 1
if success:
self.successful_validations += 1
self.total_latency_ms += latency_ms
self.audit_log.append({
"origin": origin,
"success": success,
"latency_ms": latency_ms,
"event": "origin_verify"
def get_success_rate(self) -> float:
if self.total_validations == 0:
return 0.0
return (self.successful_validations / self.total_validations) * 100
def get_avg_latency(self) -> float:
return 0.0
return self.total_latency_ms / self.total_validations
def register_waf_sync_webhook(
webhook_url: str,
webhook_name: str = "WAF-Origin-Sync"
) -> dict:
api = WebhooksApi(client)
webhook_body = Webhook(
name=webhook_name,
url=webhook_url,
events=["webmessaging.configuration.created", "webmessaging.configuration.updated"],
enabled=True
response = api.post_analytics_events_webhook(body=webhook_body)
logger.info("Registered WAF sync webhook: %s", response.id)
if e.status == 409:
logger.warning("Webhook %s already exists.", webhook_name)
else:
raise
The webhook registers against /api/v2/analytics/events/webhooks with scope webhooks:admin. It triggers on configuration updates, allowing an external WAF to align its allowlists with Genesys Cloud. The OriginValidatorMetrics class tracks latency and success rates, while audit_log stores structured events for compliance.
The following script ties authentication, validation, configuration update, webhook registration, and metric tracking into a single runnable module. Replace placeholder credentials before execution.
import os
import logging
import genesyscloud
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
def main():
# 1. Initialize SDK
genesyscloud.init(
environment=os.getenv("GENESYS_CLOUD_ENV", "mypurecloud.com"),
client_id=os.getenv("GENESYS_CLOUD_CLIENT_ID"),
client_secret=os.getenv("GENESYS_CLOUD_CLIENT_SECRET")
client = genesyscloud.platform.client.PureCloudPlatformClientV2()
config_id = os.getenv("GENESYS_CLOUD_WEBM_CONFIG_ID")
if not config_id:
raise ValueError("GENESYS_CLOUD_WEBM_CONFIG_ID environment variable is required.")
# 2. Define candidate origins
candidate_origins: List[str] = [
"https://secure.example.com",
"https://*.dev.example.com",
"http://insecure.test.com",
"https://invalid..domain.com"
# 3. Validate origins
metrics = OriginValidatorMetrics()
start_time = time.time()
payload = construct_validation_payload(candidate_origins, verify_directive=True)
end_time = time.time()
for origin in candidate_origins:
success = payload["origin_ref"].get(origin, False)
metrics.record_attempt(origin, success, (end_time - start_time) * 1000)
logger.info("Validation complete. Valid: %d, Invalid: %d",
len(payload["valid_origins"]), len(payload["invalid_origins"]))
if not payload["valid_origins"]:
logger.error("Block trigger activated. No valid origins found.")
return
# 4. Update configuration
updated_config = update_webmessaging_origins(client, config_id, payload["valid_origins"])
logger.info("Configuration updated successfully. New origins: %s", updated_config["allowed_origins"])
# 5. Register WAF sync webhook
waf_url = os.getenv("WAF_WEBHOOK_URL")
if waf_url:
register_waf_sync_webhook(client, waf_url)
# 6. Output metrics and audit log
logger.info("Success Rate: %.2f%%", metrics.get_success_rate())
logger.info("Average Latency: %.2f ms", metrics.get_avg_latency())
logger.info("Audit Log: %s", json.dumps(metrics.audit_log, indent=2))
main()
Run the script with python validate_origins.py. The script validates each origin, blocks invalid entries, updates the Genesys Cloud configuration, registers the WAF webhook, and prints governance metrics.
Error: 400 Bad Request
- Cause: The payload contains an origin that violates Genesys Cloud format rules or exceeds the maximum domain list limit.
- Fix: Verify that all origins match
https://and contain no paths, query strings, or fragments. Ensure the total count does not exceed 50. Run theconstruct_validation_payloadfunction locally before calling the API. - Code Fix: The validation pipeline already catches these cases. Check
payload["invalid_origins"]to identify the exact failing entry.
- Cause: Exceeding Genesys Cloud API rate limits during rapid configuration updates or webhook registrations.
- Fix: The
update_webmessaging_originsfunction implements exponential backoff. If the error persists, reduce the frequency of calls or implement a queue-based scheduler. - Code Fix: Increase
max_retriesorbase_delayin the update function. Monitor theRetry-Afterheader if available.
- Cause: Missing OAuth scopes or expired credentials.
- Fix: Ensure the OAuth client has
webmessaging:view,webmessaging:admin, andwebhooks:adminscopes. Verify thatGENESYS_CLOUD_CLIENT_IDandGENESYS_CLOUD_CLIENT_SECRETare correct. - Code Fix: The SDK automatically refreshes tokens. If the error persists, reinitialize the SDK with fresh credentials or rotate the OAuth client secret in the Genesys Cloud admin console.
Error: SSL Verification Failure
- Cause: The target origin uses a self-signed certificate, has an expired certificate, or blocks automated HTTP GET requests.
- Fix: Use production certificates issued by a trusted CA. If testing against internal domains, add them to the system trust store or disable
verify_directivetemporarily for staging environments. - Code Fix: The
verify_ssl_certificatefunction returnsFalseonhttpx.SSLError. Review the audit log to identify which origin failed SSL validation.
