Using the Genesys Cloud CX Python SDK to Paginate and Retrieve Routing Wrap-Up Codes with get_routing_wrapupcodes
This guide demonstrates how to retrieve all routing wrap-up codes within a Genesys Cloud CX organization using the Python SDK. The process includes proper pagination handling, as the API limits the number of results returned per request. The end result is a Python script that outputs a list of all wrap-up codes with their associated details.
- Genesys Cloud CX Professional or Enterprise license.
Routing > Wrap-up Code > Viewpermission is required for the API key used.- Python 3.6 or higher installed.
- The Genesys Cloud CX Python SDK installed (
pip install genesys-cloud-platform-sdk). - A Genesys Cloud CX API key and OAuth credentials configured for Python SDK access. The OAuth application requires the
wrapupcodes:readscope. - Familiarity with Python programming, REST APIs, and the concept of pagination.
1. Authentication and API Client Initialization
The first step involves authenticifying with the Genesys Cloud CX platform and initializing the API client. This requires providing the API key and OAuth credentials to establish a secure connection.
from genesyscloud.client import GenesysCloudClient
from genesyscloud.core.api.wrapupcodes import WrapupcodesApi
API_KEY = "YOUR_API_KEY"
API_URL = "https://api.mypurecloud.com" # or your regional API URL
OAUTH_CLIENT_ID = "YOUR_OAUTH_CLIENT_ID"
OAUTH_CLIENT_SECRET = "YOUR_OAUTH_CLIENT_SECRET"
client = GenesysCloudClient(
api_key=API_KEY,
api_url=API_URL,
oauth_client_id=OAUTH_CLIENT_ID,
oauth_client_secret=OAUTH_CLIENT_SECRET
wrapup_api = WrapupcodesApi(client)
The Trap: Hardcoding API keys and secrets directly into your scripts is a significant security risk. Use environment variables or a secure configuration management system to store these credentials. Never commit these values to source control.
The GenesysCloudClient establishes the connection to the platform. The WrapupCodesApi object provides the methods to interact with the wrap-up code API.
2. Implementing Pagination for get_routing_wrapupcodes
The get_routing_wrapupcodes method does not return all results at once. It utilizes pagination. To retrieve all wrap-up codes, you must iterate through the results until no more pages are available. This requires managing the page_size and page_number parameters.
page_size = 100 # Maximum allowed page size
page_number = 1
all_wrapup_codes = []
while True:
response = wrapup_api.get_routing_wrapupcodes(
page_size=page_size,
page_number=page_number
wrapup_codes = response.entities
if not wrapup_codes:
break # No more results
all_wrapup_codes.extend(wrapup_codes)
page_number += 1
print(f"Error retrieving wrap-up codes: {e}")
break
The Trap: Failing to handle potential exceptions during API calls is a common mistake. The try...except block ensures that the script handles network errors or API issues gracefully. Also, forgetting to increment page_number will result in an infinite loop.
This loop continues to call get_routing_wrapupcodes with increasing page_number until an empty list of wrapup_codes is returned, indicating the end of the result set.
3. Processing and Outputting the Results
Once all wrap-up codes are retrieved, they can be processed and outputted in a desired format. This example prints the ID and name of each wrap-up code.
for wrapup_code in all_wrapup_codes:
print(f"ID: {wrapup_code.id}, Name: {wrapup_code.name}")
This iterates through the all_wrapup_codes list and prints the id and name attributes of each wrap-up code object. You can access other attributes, such as active, externalId, and wrapupType as needed.
Edge Case 1: API Rate Limits
- Failure Condition: The script encounters HTTP 429 errors (Too Many Requests).
- Root Cause: Exceeding the Genesys Cloud CX API rate limits.
- Solution: Implement a delay between API requests using
time.sleep(). Consider using exponential backoff to increase the delay after each failed request. Monitor your API usage in the Genesys Cloud CX resource center.
Edge Case 2: Invalid OAuth Credentials
- Failure Condition: The script fails to authenticate and raises an HTTP 401 error (Unauthorized).
- Root Cause: Incorrect API key, OAuth client ID, OAuth client secret, or incorrect OAuth scope.
- Solution: Double-check the API key and OAuth credentials. Verify that the OAuth application has the
wrapupcodes:readscope. Regenerate the credentials if necessary.
Edge Case 3: Large Number of Wrap-Up Codes
- Failure Condition: The script takes a very long time to complete.
- Root Cause: A large number of wrap-up codes exist, requiring many API calls.
- Solution: While pagination is already implemented, consider optimizing the output method. Instead of printing to the console, write the data to a file or database. Evaluate whether all the wrap-up codes are actually needed.
- Genesys Cloud Resource Center - Wrap-Up Codes
- Genesys Cloud Developer Center - Python SDK
- Genesys Cloud Developer Center - WrapUpCodesApi
- IETF RFC 6570 - The HTTP WebDAV Bindings (Relevant for understanding HTTP status codes like 429)
