Using the Genesys Cloud CX Notification API to Trigger Custom Alerts and Integrations
This guide details the implementation of custom alerting and integration workflows using the Genesys Cloud CX Notification API. The end result is a system capable of triggering external actions – such as sending messages to Slack, posting to webhooks, or escalating to on-call schedules – based on real-time events within Genesys Cloud CX. This provides extended observability and automated responses beyond the standard Genesys Cloud CX alerting capabilities.
- Licensing Tier: Genesys Cloud CX 3.0 or higher. The Notification API functionality is included in all CX 3.0 tiers.
- Permissions: The user account performing the configuration requires the following permissions:
Admin > Integrations > ViewAdmin > Integrations > CreateAdmin > Integrations > EditAdmin > OAuth > ViewAdmin > OAuth > Create
- OAuth Client: An OAuth client must be created and configured with the
notificationscope. - External Dependencies: A destination endpoint for the notifications (e.g., Slack webhook URL, PagerDuty integration key, custom API endpoint). The endpoint must be able to accept a JSON payload via a POST request.
1. Creating an OAuth Client for the Notification API
The Notification API utilizes OAuth 2.0 for authentication. A dedicated OAuth client ensures proper security and auditing.
- Navigate to Admin > Integrations > OAuth Clients.
- Click Add New OAuth Client.
- Name: Provide a descriptive name (e.g., “Notification API Integration”).
- Client Type: Select “Confidential”.
- Scopes: Crucially, select the
notificationscope. This scope grants access to the Notification API endpoints. Without this, all API calls will return unauthorized errors. - Redirect URI: Enter a placeholder URI (e.g.,
https://localhost). This is not used for the Notification API but is required to create a Confidential client. - Click Create.
- Record the Client ID and Client Secret. These values are required for authenticating API requests.
The Trap: Failing to select the notification scope during OAuth client creation. This results in a 403 Forbidden error when calling the Notification API, and troubleshooting can be time-consuming if this simple step is overlooked.
2. Configuring the Notification Integration
The Notification integration serves as the bridge between Genesys Cloud CX events and your custom endpoints.
- Navigate to Admin > Integrations > Integration Settings.
- Click New Integration.
- Integration Type: Select “Notification”.
- Name: Provide a descriptive name (e.g., “Slack Alerting”).
- OAuth Client: Select the OAuth client created in Step 1.
- Event Filters: This is where you define which events will trigger notifications. Select the specific events you are interested in. Common examples include:
conversation.afterWrapUp: Notifies after a conversation is wrapped up.conversation.afterStateChange: Notifies after a conversation’s state changes.queue.overflow: Notifies when a queue exceeds its configured service level target.user.presenceChange: Notifies when a user’s presence status changes.
- Destination URL: Enter the URL of your external endpoint. This is the URL where Genesys Cloud CX will send the notification payload.
- HTTP Method: Select “POST”. The Notification API only supports POST requests.
- HTTP Headers: Add any required HTTP headers for your destination endpoint. Common headers include:
- Click Create.
The Trap: Incorrectly configuring the Event Filters. If the filters are too broad, you’ll receive an overwhelming number of notifications. If they’re too narrow, you’ll miss important events. Start with very specific filters and expand them iteratively as needed. Also, ensure the Event Filters align with the data expected by your destination endpoint.
3. Understanding the Notification Payload
The JSON payload sent to your destination endpoint contains details about the triggering event. The structure of the payload varies depending on the event type.
For example, a conversation.afterWrapUp event payload will contain information about the conversation, agent, queue, and wrap-up code. The event field indicates the type of event.
"event": "conversation.afterWrapUp",
"eventTimestamp": "2024-01-27T14:30:00Z",
"data": {
"conversationId": "1234567890abcdef",
"agentId": "agent123",
"queueId": "queue456",
"wrapUpCode": "Completed"
The data field contains the event-specific information. Refer to the Genesys Cloud Developer Center (link below) for the specific payload structure for each event type.
The Trap: Assuming a consistent payload structure across all event types. The payload format is event-specific. Your integration logic must parse the payload based on the event field and extract the relevant data. Failing to do so will result in integration failures.
Edge Case 1: Destination Endpoint Unreachable
- Failure Condition: The Genesys Cloud CX platform attempts to send a notification, but the destination endpoint is unavailable (e.g., network outage, server down, incorrect URL).
- Root Cause: The destination endpoint is unreachable due to network issues, server downtime, or a misconfigured URL in the integration settings.
- Solution:
- Verify network connectivity between Genesys Cloud CX and the destination endpoint.
- Confirm the destination endpoint is running and accepting POST requests.
- Double-check the URL in the integration settings for typos or errors.
- Review the Genesys Cloud CX integration logs for detailed error messages.
Edge Case 2: Rate Limiting
- Failure Condition: Notifications are being dropped or delayed due to rate limiting on the destination endpoint.
- Root Cause: The destination endpoint has implemented rate limiting to prevent overload. Genesys Cloud CX is exceeding this rate limit.
- Solution:
- Contact the administrator of the destination endpoint to understand the rate limiting policy.
- Implement logic within the destination endpoint to handle rate limiting gracefully (e.g., queue requests, return 429 Too Many Requests).
- Reduce the frequency of events triggering notifications by refining the Event Filters.
Edge Case 3: OAuth Token Expiration
- Failure Condition: Notifications suddenly stop being delivered.
- Root Cause: The OAuth token associated with the integration has expired.
- Solution:
- Revoke the existing OAuth token for the integration.
- Re-authorize the integration by re-authenticating with the OAuth client.
- Ensure your system is configured to automatically refresh the OAuth token if possible.
