Using SIP Proxy for HA GVP
hello eveyone,
i am trying to deploy genesys voice platform using SIP Proxy for HA SIP Server and supporting Resource manager active-active model.
My Lab model as bellow:
  • two SIP Proxys active- active (use sip port 12060 )
  • two SIP Server primary- secondary
  • two RM Servers : active- active
With integrating SIP Proxy - SIP Server : i used “en-SIPS-8.1.1-SIPProxyDeployment-book”, it mentioned using DNS based distribution with ( A record , SRV record) to configure DN of type Voice over IP Service, so i did steps as bellow. Has anyone could help me review my steps and configuration parameter is right or not ?
A Record:
sip-proxy.ipccbdg.com 172.16.1.12
sip-proxy.ipccbdg.com 172.16.1.13
sip-proxy01.ipccbdg.com 172.16.1.12
sip-proxy02.ipccbdg.com 172.16.1.13
SRV Record:
_sip._udp.sip-proxy.ipccbdg.com. 300 IN SRV 0 50 12060 sip-proxy01.ipccbdg.com.
_sip._udp.sip-proxy.ipccbdg.com. 300 IN SRV 0 50 12060 sip-proxy02.ipccbdg.com.
_sip._tcp.sip-proxy.ipccbdg.com. 300 IN SRV 0 50 12060 sip-proxy01.ipccbdg.com.
_sip._tcp.sip-proxy.ipccbdg.com. 300 IN SRV 0 50 12060 sip-proxy02.ipccbdg.com.
And configure DN of Voice over IP service as bellow:
contact sip-proxy.ipccbdg.com
external-contact sip-proxy.ipccbdg.com:12060
oos-check 5
oos-force 5
service-type sip-outbound-proxy
One more, about documents to integare RM with SIP Proxy i can not found on Genesys documentaion,Could anyone Share it ?
Thank you my friends,
has anyone deployed successfully SIP Proxy for HA SIP Server and RM ?
There is no special steps, so just follow the standard guide for MediaServer integration
What kind of problems are you having? Have you tested the basic install of sip proxy. I have done the exact deployment you’re describing 3 years ago and not much has changed in this department. Make sure all of your “contact” or “contact-lists” are specified with sip:ip. Also… I believe the rms have an option for “routefailover”, you may need to adjust that parameter. Lastly, whatever gateway /sbc you’re using is going to need to support a path-check of some kind (monitor the proxies using options messages).
Voip dn config - external contact you’re missing a ‘:’
All of this is coming from memory, if you need more help, start with the basics and post sip log files.
Thanks for your reply,
This is log on Sip server:
SIP Server, Version: 8.1.102.54 Compiled: Dec 2 2016 03:41:39
Genesys Telecommunications Laboratories, Inc., Copyright 1991 - 2016
Build with Genesys SIP Library 8.1.100.51
Application name: hcmsip01
Application type: TServer (1)
Command line: sip_server.exe -service TSrvSIP64 -l 7260@hcmfrw01 -app hcmsip01 -host hcmfrw01 -port 2020 -sstart
Host name: hcmsip01
DST: TZ = 0, timeb = 0
Time zone: -25200, SE Asia Standard Time, SE Asia Daylight Time
UTC time: 2017-05-29T04:04:33.042
Local time: 2017-05-29T11:04:33.042
Start time (UTC): 2017-05-29T04:04:32
Running time: 0:00:00:01
Host info: Windows 6.2.9200, 2, , 0.0, 0190, 3
File: (2) D:\logs\Sip Server\Sip_.20170529_110433_044.log
HA Role: Backup
… (some log)
11:04:58.069: GSDNChecker::GDNS: SRV record unresolved: _sip._udp.ipcchcm.com, status -1 (-1: Host or address not found)
11:04:58.069 Std 52023 GDNSChecker: Can not resolve hostname: _sip._udp.ipcchcm.com as SRV record.
11:04:58.069: GSDNChecker::GDNS: Try to resolve A record _sip._udp.ipcchcm.com:5060 instead
11:04:58.069: GDNS: Can not resolve hostname: _sip._udp.ipcchcm.com, status -1 (-1: Host or address not found)
11:04:58.069 Std 52023 GDNSChecker: Can not resolve hostname: _sip._udp.ipcchcm.com.
Howerver, on server installed Sip server i can use cmd to resolve FQDN SRV _sip._udp.ipcchcm.com ( and tcp) and on GA i saw sipserver, sip_proxy applications is start (green).
_sip._tcp.ipcchcm.com
Server: UnKnown
Address: 172.16.1.35
_sip._tcp.ipcchcm.com SRV service location:
priority = 10
weight = 50
port = 7500
svr hostname = sipproxy02.ipcchcm.com
priority = 10
weight = 50
port = 7500
svr hostname = sipproxy01.ipcchcm.com
sipproxy02.ipcchcm.com internet address = 172.16.1.13
sipproxy01.ipcchcm.com internet address = 172.16.1.12
That’s my problem i having, Have you any suggestion ?
Did you enable gdns features on SIP server level?
Kubig,
actualy i have enabled : TServer/sip-enable-gdns=true
On that server can you ping reverse (-a) by that IP?
