Can we use LDS with StatServers for load balancing. If Yes, How we can setup this?
Abrar
Abrar
I think not and why do you use LDS with StatServer? I guess,that LDS is possible to use only with T-Server or URS
Wouldn’t make sense…and yes…why???
Using LDS with statserver makes only sens if You have WAN and on one side of WAN You have TServer and on another side of WAN You have multiple statservers. If You want to have just multiple statserver in same location as TServer for performance reasons You can connect multiple statserver directly to TServer and no LDS is needed. If You are using URS with LDS (loadbalancing) You don’t need to setup Statserver in same mode.
