URS not transfering call to Ready agent
Hi everyone,
i have recently upgraded our genesys framework from 7.6 to 8.1.x. In our implementation, we have a network Switch (SCP), Network TServer (NTS), GVP, SIPProxy server and local Tserver. I’m facing a issue which i’m trying to debug hard but not getting any solution.
Problem description:
Current flow:
  1. Calling 91xxxxxx number, it hits the service number (09000) on SCP switch, then call comes to NTS1 or NTS2 running in loadsharing.
    on URS RP 09000_SCP on we have strategy, which puts the call to GVP_NE switch RP 09000_GVPNE . This RP has epn mapping with external routepoints(external numbers on gateway mapped as ERP) and based on the flow, strategy finds the target ( ready agent)
  2. strategy find the target , and tries to deliver the call, back to SCP switch in order to put the call to avialable agent ( example AgentID:1703, Place_194006, EmployeeID: 546459, VAG_C_BestSelling group).
  3. Call never pass thru this step and gives below error in URS logs:
    18:54:13.674_T_I_02ce02230c64200a [14:32] EventAttachedDataChanged is received for ts ISRV1[GVP_NE] (this dn=09000, refid=1480)
    (No configured access resources are found)
    AttributeErrorMessage ‘No configured access resources are found’
    18:54:13.711_T_E_ [14:0c] EventError is received for ts ISRV1[GVP_NE] - No configured access resources are found
    18:54:13.711_A_E_02ce02230c64200a [14:32] <-----------ERROR
    18:54:13.711 Std 21003 interaction 02ce02230c64200a routing error 1014 No configured access resources are found
  4. Call never comes to a Ready Agent on genesys, which it should.
Does anyone have any info about which “access resources” it is refering to in this URS logs ?
we have access code configured in SCP switch for GVP_NE, but there is no access code on GVP_NE switch for SCP. this is how it was earlier and also running in parallel prod env.
Need more External Routing Points
Check access code cnfiguration for your target switch.
Thanks. it is resolved now. I had few RPs in disabled state and it was targeting them. I deleted those unused RPs and it worked.
