Upload section problem
Hi, guys,
I am having a problem with our Download Section.
I am seeing an upload link, but others don’t (Wyn :o).
Is it something to do with the fact that Wyn is British and SMF founders (probably French) put up an additional layer of protection from everything British or is it a security level problem?
A new sig for you
Victor - Conspiracy Theorist
:wink: :stuck_out_tongue:
Do you mean some of us can’t download attached files - or some of us can’t upload files?
I can see a link to upload and I have downloaded from here previously. Perhaps it’s permissions on the User Account?
…or the French…
Tony
Obviously everything in this world is the fault of the froggies… ;D ;D ;D
Vic and I have swapped screenshots about the upload links - visible in his, not visible in mine. Maybe you have to be an admin to upload?
If this is meant to be next to the Download and Shoutbox links, I dont have it either.
This will most likely be a permissions problem in the forum/portal setup, most likely in Download Manager —> Settings
Sy278,
here are the settings now:
[attachimg=1
Could be that Wyn is not an admin?
Mark, are you seeing it?
Interestingly enough, it is set so that everyone but the guest be able to upload to it.
I am looking it up on SMF forum, but nothing so far.
Sy278 is usually pretty much on a penny when it comes to SMF-related problems…
Sy278 - any ideas?
Vic,
Can you show me the settings for upload tab?
Hi, Sy278,
I have posted it on the previous message in the same thread.
That’s all I could find!
Vic,
That screenshot is only showing Admin and Settings, there is also a tab in the screenshots called upload, can you show me what under that please?
Interestingly enough, nothing …
[attachimg=1]
