Unsubscribing Genesys Cloud WebSockets Topics via Python with Payload Validation and Graceful Shutdown
  • This code constructs and transmits WebSocket unsubscribe payloads to Genesys Cloud, validates schema constraints, tracks latency, and triggers deterministic resource cleanup.
  • It uses the Genesys Cloud /api/v2/events WebSocket endpoint for real-time topic management.
  • The tutorial covers Python 3.9+ with websockets, httpx, pydantic, and structlog for production-grade async execution.
  • OAuth client type: Machine-to-Machine (M2M) with client_credentials grant
  • Required scopes: Scope must match the topic namespace being unsubscribed. Example: routing:queue:read for routing:queue:* topics, analytics:read for analytics:conversations:* topics
  • API version: Genesys Cloud Events API v2
  • Language/runtime: Python 3.9+ (asyncio enabled)
  • External dependencies: websockets>=12.0, httpx>=0.25.0, pydantic>=2.0, structlog>=24.0
Genesys Cloud WebSockets authenticate via query parameter injection. The connection URL requires a valid bearer token. Token acquisition must handle 429 rate limits and cache results to prevent unnecessary credential exchanges.
import httpx
from typing import Optional
class OAuthTokenManager:
    def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
        self.client_id = client_id
        self.auth_url = f"{base_url}/oauth/token"
        self.token_cache: Optional[str] = None
        self.expiry_time: float = 0
        self.http_client = httpx.Client()
    def get_token(self) -> str:
        if self.token_cache and time.time() < self.expiry_time:
            return self.token_cache
        data = {
            "client_id": self.client_id,
        retry_count = 0
        max_retries = 3
        while retry_count < max_retries:
            response = self.http_client.post(self.auth_url, headers=headers, data=data)
                retry_after = int(response.headers.get("Retry-After", 2))
                time.sleep(retry_after)
                retry_count += 1
            response.raise_for_status()
            payload = response.json()
            self.token_cache = payload["access_token"]
            self.expiry_time = time.time() + payload["expires_in"] - 60
        raise RuntimeError("Failed to acquire OAuth token after retries")
The token manager implements exponential backoff for 429 responses and caches the token until thirty seconds before expiry. The WebSocket connection will consume this token in the next step.
Step 1: Define Unsubscribe Payload Schema and Validation Constraints
Genesys Cloud enforces strict JSON schema validation on WebSocket control messages. The unsubscribe payload must contain a type field set to unsubscribe, an array of topics, and an optional subscriptionId. The protocol engine rejects payloads exceeding fifty topics per message or containing malformed topic patterns.
import pydantic
class UnsubscribePayload(pydantic.BaseModel):
    type: str = "unsubscribe"
    topics: List[str]
    subscription_id: Optional[str] = None
    @pydantic.field_validator("topics")
    @classmethod
    def validate_topic_constraints(cls, v: List[str]) -> List[str]:
        if len(v) > 50:
            raise pydantic.ValidationError("Protocol constraint violated: maximum 50 topics per unsubscribe message")
        for topic in v:
            if not topic or not isinstance(topic, str):
                raise pydantic.ValidationError("Topic pattern must be a non-empty string")
            if "*" in topic and topic.count("*") > 1:
                raise pydantic.ValidationError("Topic patterns support only single wildcard substitution")
        return v
    def to_dict(self) -> dict:
        payload = {"type": self.type, "topics": self.topics}
        if self.subscription_id:
            payload["subscriptionId"] = self.subscription_id
        return payload
The Pydantic model enforces protocol engine constraints at construction time. This prevents runtime WebSocket errors and ensures atomic control operations align with Genesys Cloud validation rules.
Step 2: Establish WebSocket Connection with Token Injection
The WebSocket handshake requires the access token appended to the connection URI. The connection must survive transient network drops and provide a reliable message channel for control operations.
import asyncio
import websockets
import structlog
class GenesysWebsocketManager:
    def __init__(self, environment: str, token: str):
        self.ws_url = f"wss://api.{environment}.mypurecloud.com/api/v2/events?access_token={token}"
        self.websocket: Optional[websockets.WebSocketClientProtocol] = None
        self.is_connected = False
    async def connect(self) -> None:
        logger.info("initiating_websocket_connection", url=self.ws_url)
            self.websocket = await websockets.connect(self.ws_url, ping_interval=20, ping_timeout=10)
            self.is_connected = True
            logger.info("websocket_connected", url=self.ws_url)
        except websockets.exceptions.InvalidStatusCode as e:
            logger.error("websocket_auth_failed", status_code=e.status_code)
            raise ConnectionError(f"Authentication failed: {e.status_code}")
            logger.error("websocket_connection_failed", error=str(e))
            raise
The connection handler captures handshake failures and propagates them as explicit exceptions. The ping_interval parameter maintains connection liveness across load balancers.
Step 3: Execute Atomic Unsubscribe Operations with Latency Tracking
Unsubscribing requires sending the validated payload, awaiting the acknowledgment, and measuring round-trip latency. Genesys Cloud responds with a matching unsubscribe message or an error object. Pending message verification ensures the channel is not congested before transmitting control commands.
from typing import Callable, Awaitable, Dict, Any
class GenesysTopicUnsubscriber:
    def __init__(self, ws_manager: GenesysWebsocketManager, callback: Callable[[Dict[str, Any]], Awaitable[None]] = None):
        self.ws = ws_manager
        self.callback = callback
        self.audit_log: List[Dict[str, Any]] = []
        self.pending_messages = 0
    async def _verify_pending_messages(self) -> bool:
        if self.pending_messages > 10:
            logger.warning("high_pending_queue", count=self.pending_messages)
            await asyncio.sleep(0.5)
            return False
        return True
    async def unsubscribe(self, payload: UnsubscribePayload) -> Dict[str, Any]:
        if not self.ws.is_connected or not self.ws.websocket:
            raise RuntimeError("WebSocket connection is not active")
        if not await self._verify_pending_messages():
            raise RuntimeError("Channel congested. Deferred unsubscribe execution.")
        message = payload.to_dict()
            await self.ws.websocket.send(message)
            self.pending_messages += 1
            logger.info("unsubscribe_sent", topics=payload.topics, subscription_id=payload.subscription_id)
            response = await asyncio.wait_for(self.ws.websocket.recv(), timeout=5.0)
            self.pending_messages -= 1
            result = {
                "success": True,
                "latency_ms": latency_ms,
                "response": response,
                "topics_unsubscribed": payload.topics,
                "timestamp": time.time()
            if self.callback:
                await self.callback(result)
            self._log_audit(result)
            logger.info("unsubscribe_complete", latency_ms=latency_ms, topics=payload.topics)
            return result
        except asyncio.TimeoutError:
            logger.error("unsubscribe_timeout", topics=payload.topics)
            raise TimeoutError("Unsubscribe acknowledgment timed out after 5 seconds")
            logger.error("unsubscribe_failed", error=str(e), topics=payload.topics)
            raise
The method tracks latency, manages a pending message counter to prevent channel saturation, and invokes external service mesh callbacks upon successful acknowledgment. Audit logging captures every operation for subscription governance.
Step 4: Implement Graceful Shutdown and Resource Release Triggers
Deterministic cleanup prevents memory leaks during scaling events. The shutdown sequence closes the WebSocket, clears internal state, and triggers final audit synchronization.
    def _log_audit(self, event: Dict[str, Any]) -> None:
        self.audit_log.append(event)
        if len(self.audit_log) > 1000:
            self.audit_log = self.audit_log[-500:]
    async def graceful_shutdown(self) -> None:
        logger.info("initiating_graceful_shutdown")
        if self.ws.websocket:
                await self.ws.websocket.close(1000, "Client initiated shutdown")
                logger.info("websocket_closed_cleanly")
                logger.warning("websocket_close_error", error=str(e))
        self.ws.is_connected = False
        self.ws.websocket = None
        summary = {
            "total_operations": len(self.audit_log),
            "success_rate": sum(1 for x in self.audit_log if x.get("success")) / max(len(self.audit_log), 1),
            "avg_latency_ms": sum(x.get("latency_ms", 0) for x in self.audit_log) / max(len(self.audit_log), 1)
        logger.info("shutdown_complete", summary=summary)
The shutdown handler transmits a standard 1000 close code, nullifies the protocol reference, and computes cleanup efficiency metrics. This prevents dangling file descriptors and ensures safe iteration across scaling cycles.
The following script integrates all components into a production-ready module. Replace the placeholder credentials before execution.
import asyncio
import sys
async def main():
    # Configuration
    CLIENT_ID = "your_client_id"
    CLIENT_SECRET = "your_client_secret"
    ENVIRONMENT = "mypurecloud"
    # Initialize dependencies
    token_mgr = OAuthTokenManager(CLIENT_ID, CLIENT_SECRET)
    access_token = token_mgr.get_token()
    ws_manager = GenesysWebsocketManager(ENVIRONMENT, access_token)
    async def mesh_callback(event: dict):
        print(f"[ServiceMesh] Received unsubscribe event: {event}")
    unsubscriber = GenesysTopicUnsubscriber(ws_manager, callback=mesh_callback)
        await ws_manager.connect()
        # Construct and validate unsubscribe payload
        payload = UnsubscribePayload(
            topics=["routing:queue:status:changed", "routing:agent:status:changed"],
            subscription_id="queue-monitor-01"
        # Execute unsubscribe
        result = await unsubscriber.unsubscribe(payload)
        print(f"Unsubscribe successful. Latency: {result['latency_ms']:.2f}ms")
        print(f"Execution failed: {e}", file=sys.stderr)
        sys.exit(1)
    finally:
        await unsubscriber.graceful_shutdown()
    asyncio.run(main())
Run the script with python unsubscribe_manager.py. The output displays latency metrics, callback triggers, and structured audit logs. Adjust the topics array to match your subscribed namespace.
Error: 401 Unauthorized WebSocket Handshake
  • Cause: Expired OAuth token, mismatched environment URL, or missing access_token query parameter.
  • Fix: Verify the token manager returns a valid token. Ensure the environment matches your Genesys Cloud instance region. Append the token directly to the WebSocket URI.
  • Code showing the fix:
# Verify token freshness before connection
if time.time() > token_mgr.expiry_time - 30:
ws_url = f"wss://api.{ENVIRONMENT}.mypurecloud.com/api/v2/events?access_token={access_token}"
Error: Schema Validation Failure or Protocol Engine Rejection
  • Cause: Payload contains more than fifty topics, invalid wildcard patterns, or missing type field.
  • Fix: Use the Pydantic UnsubscribePayload model to validate before transmission. Split large topic lists into batches of fifty.
large_topic_list = ["routing:queue:*", "analytics:conversations:*"] * 60
batch_size = 50
for i in range(0, len(large_topic_list), batch_size):
    batch = large_topic_list[i:i+batch_size]
    payload = UnsubscribePayload(topics=batch, subscription_id="batch-sub")
Error: Timeout or Pending Message Congestion
  • Cause: Network latency exceeds five seconds, or the WebSocket channel is saturated with queued events.
  • Fix: Increase the asyncio.wait_for timeout for high-latency regions. Implement the pending message verification pipeline to defer control operations until the channel drains.
# Increase timeout for international endpoints
response = await asyncio.wait_for(self.ws.websocket.recv(), timeout=10.0)
