PureCloudPlatformClientV2 parses the interaction query payload sequentially, so the timestamp range matrices hit the media store constraints first and throw a 400 Bad Request. Step one: construct the retrieval payload with the interactionId references and speakerDiarization directives, then perform a query for interaction analytics while bypassing the automatic text normalization triggers. Step two: validate the transcript.segments array against the maximum segment length limits before the API handles the atomic GET operations. Honestly it’s messy when you skip the format verification step and don’t run the audio quality scoring verification, which breaks the safe retrieval iteration loop and leaves the PII masking application pipelines hanging.
- TypeScript client initialized with
@genesys/cloud-tsv1.2.0 - Payload includes
timeRange.start,timeRange.end, andtranscript.segmentsarray - Webhook callbacks sync retrieval events but drop responses over 3 seconds of retrieval latency
- Manual validation checks audio quality scoring before triggering automatic text normalization
