Trying to drop a specific participant from a conference using the Node SDK (@genesyscloud/conversations-api-v2). The call works for the initiator but fails for others with a 404.
const resp = await apiInstance.updateConversationParticipant(conversationId, participantId, {
reason: 'agent_initiated'
The participantId is pulled directly from the participants array in the GET call right before this. I’ve verified the ID matches the id field in the JSON payload. Is there a race condition where the participant state changes between the GET and the update? Or is the SDK sending the wrong endpoint?
Checked the network tab and it’s hitting PATCH /api/v2/conversations/calls/{conversationId}/participants/{participantId}. The response body says "message": "participant not found". Weird because the ID exists in the active list.
