TypeScript SCIM Group POST Failing with 409 on External ID and Schema Extension
The ADMIN UI handles directory onboarding fine, but pushing a raw TypeScript payload to /api/v2/scim/v2/Groups keeps bombing out with a 409 Conflict when the EXTERNAL ID ATTRIBUTE overlaps or the SCHEMA EXTENSION DIRECTIVE hits the MAX MEMBERSHIP LIMIT. We’ve got the GROUP:MANAGE SCOPE attached and the HIERARCHY CONFIGURATION locked down, yet the atomic POST still drops the member reference arrays and refuses to trigger the HRIS WEBHOOK CALLBACK. Validation logic for role compatibility checking pipelines is supposed to prevent privilege loops, but the response just returns a generic naming uniqueness constraint error instead of tracking the creation latency. I’d much rather configure this through the ADMIN UI than debug broken schema directives, but the automated directory management requirement forces the API route. Here’s the exact payload structure causing the directory conflict:
const groupPayload = {
 schemas: ["urn:ietf:params:scim:schemas:core:2.0:Group", "urn:ietf:params:scim:schemas:extension:genesys:2.0:Group"],
 displayName: "Auto_Routing_Queue_A",
 externalId: "hris_dept_8842",
 members: [{ value: "user_ref_01", "$ref": "/api/v2/scim/v2/Users/u1" }],
 meta: { resourceType: "Group", location: "/api/v2/scim/v2/Groups/g1" }
await fetch("https://{{env}}.mygenesys.com/api/v2/scim/v2/Groups", {
 method: "POST",
 headers: { "Authorization": `Bearer ${token}`, "Content-Type": "application/json" },
 body: JSON.stringify(groupPayload)
// src/routes/api/scim/groups/+server.ts
import { json } from '@sveltejs/kit';
import { platformClient } from '$lib/auth';
export async function POST({ request }) {
 const body = await request.json();
 const { displayName, externalId, members, extensions } = body;
 // 1. Pre-check existence to avoid 409
 const filter = `externalId eq "${externalId}"`;
 const existing = await platformClient.ScimApi().scimGroupsList({ filter });
 if (existing.resources?.length > 0) {
 return json({ error: 'Duplicate externalId detected', status: 409 }, { status: 409 });
 // 2. Validate member limit
 if (members?.length > 1000) {
 return json({ error: 'Exceeds max membership limit', status: 400 }, { status: 400 });
 const payload = {
 schemas: ['urn:ietf:params:scim:schemas:core:2.0:Group'],
 displayName,
 externalId,
 members: members.map(m => ({
 value: m.id,
 $ref: `https://api.mypurecloud.com/api/v2/scim/v2/Users/${m.id}`
 // 3. Handle schema extensions correctly
 if (extensions?.length) {
 payload.schemas.push(...extensions.map(e => e.schema));
 payload.Extensions = extensions.map(e => ({
 schema: e.schema,
 ...e.values
 const result = await platformClient.ScimApi().scimGroupsPost(payload);
 return json({ group: result, status: 201 }, { status: 201 });
 } catch (err) {
 console.error('SCIM POST failed:', err);
 return json({ error: err.message }, { status: 500 });
The 409 Conflict isn’t just a duplicate ID. It’s usually the SCHEMA EXTENSION FORMAT blowing up the payload or the MEMBER REFERENCE ARRAY having broken $ref links. The gateway validates the structure before it checks uniqueness. If your extension block is even slightly off, the request dies. You’re probably passing raw objects where the spec demands strict URIs. The platform doesn’t care about your TypeScript interfaces. It cares about the JSON shape.
Run this through a server route. Keep the OAUTH PROXY PATTERN tight. Hardcoding scopes in the widget is a recipe for disaster.
  1. Check the filter syntax. The SCIM list endpoint is finicky. Use externalId eq "value".
  2. Pre-validate existence. Fetch the group list first. If it exists, abort. Saves the headache of parsing a 409 response.
  3. Structure the extensions. The Extensions array needs the schema URI and the values object merged. Don’t nest them deeper than necessary.
  4. Watch the member count. The MAX MEMBERSHIP LIMIT kills the request if you exceed it. The error code can be misleading.
It’s the schema extension-specifically how it’s being serialized. The 409 isn’t about the external ID, it’s a secondary symptom. It’s getting tripped up when the array of member references exceeds the maximum allowed value, but the error message is masking the real cause. The API isn’t clearly reporting the array size constraint.
The TypeScript serialization layer is probably stripping out the maxMembership attribute from the extension schema during the POST. It’s assuming it’s irrelevant, but it’s critical for the API to understand the constraint. The conflict arises because the API receives an array that exceeds an undefined limit. The server is failing to process the request because it can’t determine the maximum size.
Try explicitly setting the maxMembership within the extensions array during payload construction. It needs to be present, even if it’s just the default. We’ve seen this a lot when automating SCIM provisioning. The platformClient library sometimes gets aggressive with schema pruning!!
 // Ensure maxMembership is explicitly set in the extensions
 const updatedExtensions = [
 ...extensions,
 schema: 'urn:ietf:params:scim:ext:enterprise:2.0:group',
 value: {
 maxMembership: 100 // Or whatever the appropriate limit is
 const response = await platformClient.ScimApi().scimGroupsPost({
 displayName: displayName,
 externalId: externalId,
 members: members,
 extensions: updatedExtensions
 return json(response);
 } catch (error) {
 console.error("SCIM Group POST Error:", error);
 return json({ error: "SCIM Group POST Failed" }, { status: 500 });
It’s also worth verifying the HIERARCHY CONFIGURATION is actually set up in the GC Admin UI correctly. A mismatch between the configured hierarchy and the payload structure can lead to unexpected behavior.
