@genesys/cloud-auth handles the OAuth renewal sequence by batching client ID references and refresh token matrices before hitting /api/v2/oauth/token. First, the TypeScript worker constructs the payload with strict scope request directives and runs an atomic POST to bypass concurrent refresh limits, but the platform keeps returning a 429 Too Many Requests even though secure storage tracks the expiry window correctly.
The signature verification pipeline passes locally anyway, yet webhook callbacks to our external IdM don’t sync latency metrics before the privilege checking stage drops the request, which leaves the token refresher exposed and the audit logs empty: {"grant_type": "refresh_token", "client_id": "prod-cx-01", "refresh_token": "{{matrix_ref}}", "scope": "webchat:manage oauth:offline_access"}.
The scope mismatch trips up /api/v2/oauth/token. It’s expecting a clean array. Try restructuring the payload first:
- Strip legacy tags.
- Pass scopes as an exact JSON array.
- Add a retry backoff since the rate limiter catches bursts.
curl -X POST https://api.mypurecloud.com/api/v2/oauth/token -H "Content-Type: application/json" -d '{"grant_type":"refresh_token","refresh_token":"your_token_here","scope":["login","analytics:read"]}'
We route these through a gRPC sidecar instead. Pretty sure the backend just drops malformed strings anyway. The backoff logic usually fixes the 429.
The suggestion above actually cleared the 429 response completely. platform_api_python handles the token renewal differently since it serializes the request body before hitting /api/v2/oauth/token. When you pass the scopes as a comma-separated string instead of a strict JSON array, the OAuth endpoint rejects the payload and triggers the rate limiter. I tested the exact structure you recommended on my staging instance and it finally passed the validation step. You just need to map the scope list to a proper array before the POST request executes, otherwise the platform keeps dropping the renewal and logging unnecessary errors.
platform_api_python requires the exact schema match to avoid the serializer throwing a validation exception. Here is the working payload structure for the renewal call.
oauth_api = platformClient.OAuthApi()
body = PureCloudPlatformClientV2.OAuthTokenRequest(
grant_type="refresh_token",
refresh_token=stored_refresh_token,
scope=["admin:api", "reading:interaction"]
result = oauth_api.post_oauth_token(body=body)
The 429 error vanishes once the array format aligns. You’ll notice the response time drops significantly after fixing the structure. Just make sure your retry backoff doesn’t overlap with the token expiry window. Still waiting on the final webhook trigger.
The 429 usually trips because the auth server rejects the malformed scope structure, and the client retries the bad payload until the rate limiter kicks in. It’s expecting a strict list for the scope parameter. When the payload arrives with a string, the validation layer throws an error. This rejection triggers the rate limiter if the client retries aggressively. My Rails middleware handles token rotation for webhook event ingestion, and the pipeline stalls whenever a scope mismatch occurs. You have to ensure the request body serializes the scopes correctly. The standard OAuth flow requires the scope to be an array in the JSON body. The request structure using Faraday avoids this trap. The code block below shows the correct payload shape. The scope field is a list. Don’t pass a comma-separated string, or the validation fails. You’ll see the error immediately. The content type also matters. The endpoint accepts application/json for the token request. The header must be set. The retry logic needs a backoff too. Sending bursts of bad payloads will lock the account. The suggestion about backoff is solid. Verifying the wire format matches the spec helps. Watch the serialization on the adapter side.
require 'faraday'
require 'json'
client = Faraday.new(url: 'https://api.mypurecloud.com') do |conn|
conn.request :url_encoded
conn.adapter Faraday.default_adapter
end
# The scope must be an array.
# A string here triggers validation failure and subsequent 429 on retry.
payload = {
grant_type: 'refresh_token',
refresh_token: ENV['GENESYS_REFRESH_TOKEN'],
scope: ['admin:platform', 'analytics:report:read']
response = client.post('/api/v2/oauth/token', payload)
