Tuning NICE CXone Agent Assist Knowledge Base Ranking Weights with C#
A C# service that constructs, validates, and applies ranking weight tuning payloads to a NICE CXone Agent Assist knowledge base. The code adjusts BM25 parameters, enforces maximum boost factor limits, triggers automatic A/B testing, validates click-through rates and false positive thresholds, and logs tuning events for search governance. The tutorial uses the CXone REST API surface with modern .NET 8 patterns.
  • CXone OAuth client credentials with scopes: agentassist:knowledgebase:write, agentassist:knowledgebase:read
  • CXone .NET SDK v2.0+ (optional for base client configuration, primary implementation uses HttpClient for atomic tuning operations)
  • .NET 8 SDK
  • NuGet packages: System.Text.Json, System.Net.Http.Json, Polly (for retry logic)
  • Access to a CXone organization with Agent Assist enabled and at least one knowledge base
CXone uses a standard OAuth 2.0 client_credentials flow. The token endpoint requires your organization ID, client ID, and client secret. Token caching reduces authentication overhead and prevents unnecessary credential exchanges.
using System;
using System.Net.Http;
using System.Text.Json;
using System.Text.Json.Serialization;
using System.Threading;
using System.Threading.Tasks;
public class CxoneAuthClient
    private readonly HttpClient _httpClient;
    private readonly string _orgId;
    private readonly string _clientId;
    private readonly string _clientSecret;
    private string? _accessToken;
    private DateTime? _tokenExpiry;
    public CxoneAuthClient(string orgId, string clientId, string clientSecret)
        _orgId = orgId;
        _clientId = clientId;
        _clientSecret = clientSecret;
        _httpClient = new HttpClient();
        _httpClient.Timeout = TimeSpan.FromSeconds(15);
    public async Task<string> GetAccessTokenAsync()
        if (_accessToken != null && _tokenExpiry.HasValue && _tokenExpiry.Value > DateTime.UtcNow.AddMinutes(2))
            return _accessToken;
        var tokenUrl = $"https://{_orgId}.api.nicecv.com/oauth2/token";
        var content = new FormUrlEncodedContent(new[]
            new KeyValuePair<string, string>("grant_type", "client_credentials"),
            new KeyValuePair<string, string>("client_id", _clientId),
            new KeyValuePair<string, string>("client_secret", _clientSecret),
            new KeyValuePair<string, string>("scope", "agentassist:knowledgebase:write agentassist:knowledgebase:read")
        var response = await _httpClient.PostAsync(tokenUrl, content);
        response.EnsureSuccessStatusCode();
        var json = await response.Content.ReadAsStringAsync();
        var tokenResponse = JsonSerializer.Deserialize<OAuthTokenResponse>(json);
        if (tokenResponse?.Access_Token == null)
            throw new InvalidOperationException("OAuth token response missing access_token.");
        _accessToken = tokenResponse.Access_Token;
        _tokenExpiry = DateTime.UtcNow.AddSeconds(tokenResponse.Expires_In);
    public void Dispose() => _httpClient.Dispose();
public class OAuthTokenResponse
    [JsonPropertyName("access_token")] public string? Access_Token { get; set; }
    [JsonPropertyName("expires_in")] public int Expires_In { get; set; }
    [JsonPropertyName("token_type")] public string? Token_Type { get; set; }
Step 1: Initialize CXone Client and Configure Base HTTP Pipeline
The CXone tuning API requires strict header formatting and atomic request handling. You must attach the bearer token, set Content-Type: application/json, and include the X-Organization-Id header for routing. The pipeline below configures automatic JSON serialization and prepares the client for tuning operations.
using System.Net.Http.Headers;
public class CxoneTuningClient : IDisposable
    private readonly HttpClient _client;
    private readonly CxoneAuthClient _auth;
    private readonly string _baseUrl;
    private readonly JsonSerializerOptions _jsonOptions = new() { PropertyNamingPolicy = JsonNamingPolicy.CamelCase };
    public CxoneTuningClient(CxoneAuthClient auth, string orgId)
        _auth = auth;
        _baseUrl = $"https://{orgId}.api.nicecv.com";
        _client = new HttpClient();
        _client.Timeout = TimeSpan.FromSeconds(30);
        _client.DefaultRequestHeaders.Accept.Add(new MediaTypeWithQualityHeaderValue("application/json"));
    public async Task<HttpResponseMessage> ExecuteTuningPutAsync(string knowledgebaseId, object payload)
        var token = await _auth.GetAccessTokenAsync();
        _client.DefaultRequestHeaders.Authorization = new AuthenticationHeaderValue("Bearer", token);
        var url = $"{_baseUrl}/api/v2/agentassist/knowledgebases/{knowledgebaseId}/tuning";
        var jsonContent = new StringContent(JsonSerializer.Serialize(payload, _jsonOptions), System.Text.Encoding.UTF8, "application/json");
        var request = new HttpRequestMessage(HttpMethod.Put, url) { Content = jsonContent };
        request.Headers.Add("X-Organization-Id", _baseUrl.Split(".")[0].Replace("https://", ""));
        var response = await _client.SendAsync(request);
        LogHttpCycle(request, response);
        return response;
    private void LogHttpCycle(HttpRequestMessage request, HttpResponseMessage response)
        Console.WriteLine($"[HTTP CYCLE] {request.Method} {request.RequestUri}");
        Console.WriteLine($"[HEADERS] Authorization: Bearer *** | Content-Type: application/json");
        Console.WriteLine($"[STATUS] {(int)response.StatusCode} {response.ReasonPhrase}");
        if (!response.IsSuccessStatusCode)
            var body = response.Content.ReadAsStringAsync().Result;
            Console.WriteLine($"[ERROR BODY] {body}");
        _client.Dispose();
        _auth.Dispose();
Step 2: Construct Tuning Payload with Ranking References and Relevance Matrix
CXone expects a structured tuning payload containing rankingReferences, relevanceMatrix, and a calibrateDirective. The relevance matrix defines field weights, BM25 parameters, and boost factors. You must construct this payload explicitly to avoid schema rejection.
public class TuningPayload
    [JsonPropertyName("rankingReferences")]
    public List<RankingReference> RankingReferences { get; set; } = new();
    [JsonPropertyName("relevanceMatrix")]
    public RelevanceMatrix RelevanceMatrix { get; set; } = new();
    [JsonPropertyName("calibrateDirective")]
    public CalibrateDirective CalibrateDirective { get; set; } = new();
public class RankingReference
    [JsonPropertyName("field")] public string Field { get; set; } = string.Empty;
    [JsonPropertyName("type")] public string Type { get; set; } = string.Empty;
    [JsonPropertyName("priority")] public int Priority { get; set; }
public class RelevanceMatrix
    [JsonPropertyName("bm25Parameters")] public Bm25Parameters Bm25Parameters { get; set; } = new();
    [JsonPropertyName("fieldWeights")] public List<FieldWeight> FieldWeights { get; set; } = new();
    [JsonPropertyName("boostFactors")] public List<BoostFactor> BoostFactors { get; set; } = new();
public class Bm25Parameters
    [JsonPropertyName("k1")] public double K1 { get; set; } = 1.2;
    [JsonPropertyName("b")] public double B { get; set; } = 0.75;
public class FieldWeight
    [JsonPropertyName("fieldName")] public string FieldName { get; set; } = string.Empty;
    [JsonPropertyName("weight")] public double Weight { get; set; } = 1.0;
public class BoostFactor
    [JsonPropertyName("condition")] public string Condition { get; set; } = string.Empty;
    [JsonPropertyName("boost")] public double Boost { get; set; } = 1.0;
public class CalibrateDirective
    [JsonPropertyName("mode")] public string Mode { get; set; } = "incremental";
    [JsonPropertyName("validateBeforeApply")] public bool ValidateBeforeApply { get; set; } = true;
    [JsonPropertyName("abTestEnabled")] public bool AbTestEnabled { get; set; } = true;
Step 3: Validate Schema, Enforce Boost Limits, and Apply via Atomic PUT
CXone enforces strict constraints on tuning payloads. Maximum boost factors cannot exceed 10.0. BM25 k1 must fall between 0.5 and 2.0, and b must fall between 0.5 and 1.0. You must validate these constraints before transmission to prevent 400 Bad Request failures. The following validator performs schema checks and prepares the payload for atomic submission.
using System.Collections.Generic;
using System.Linq;
public static class TuningValidator
    public static void ValidatePayload(TuningPayload payload)
        var errors = new List<string>();
        // BM25 parameter validation
        var k1 = payload.RelevanceMatrix.Bm25Parameters.K1;
        var b = payload.RelevanceMatrix.Bm25Parameters.B;
        if (k1 < 0.5 || k1 > 2.0) errors.Add($"BM25 k1 must be between 0.5 and 2.0. Received: {k1}");
        if (b < 0.5 || b > 1.0) errors.Add($"BM25 b must be between 0.5 and 1.0. Received: {b}");
        // Maximum boost factor limit validation
        var maxBoost = payload.RelevanceMatrix.BoostFactors.Max(f => f.Boost);
        if (maxBoost > 10.0) errors.Add($"Maximum boost factor limit is 10.0. Received: {maxBoost}");
        // Field weight normalization
        foreach (var fw in payload.RelevanceMatrix.FieldWeights)
            if (fw.Weight < 0.0 || fw.Weight > 5.0)
                errors.Add($"Field weight for '{fw.FieldName}' must be between 0.0 and 5.0.");
        // Ranking reference integrity
        if (payload.RankingReferences.Count == 0)
            errors.Add("At least one ranking reference is required.");
        if (errors.Count > 0)
            throw new InvalidOperationException($"Tuning payload validation failed:\n" + string.Join("\n", errors));
Step 4: Implement Validation Logic, Tracking, and Audit Logging
Tuning operations require click-through rate (CTR) checking, false positive verification, latency tracking, and audit logging. The following service orchestrates these checks, simulates feedback pipeline validation, and records governance data.
using System.Diagnostics;
using System.IO;
using System.Text;
public class TuningGovernanceService
    private readonly string _auditLogPath;
    private readonly double _minCtThreshold = 0.15;
    private readonly double _maxFalsePositiveRate = 0.05;
    public TuningGovernanceService(string auditLogPath)
        _auditLogPath = auditLogPath;
    public async Task ValidateTuneMetricsAsync(TuningPayload payload, Dictionary<string, double> historicalMetrics)
        var ctr = historicalMetrics.GetValueOrDefault("ctr", 0.0);
        var fpr = historicalMetrics.GetValueOrDefault("false_positive_rate", 0.0);
        if (ctr < _minCtThreshold)
            throw new InvalidOperationException($"CTR {ctr} falls below minimum threshold {_minCtThreshold}. Tune rejected to prevent agent distraction.");
        if (fpr > _maxFalsePositiveRate)
            throw new InvalidOperationException($"False positive rate {fpr} exceeds maximum threshold {_maxFalsePositiveRate}. Tune rejected.");
        await LogAuditAsync(payload, $"Validation passed. CTR: {ctr}, FPR: {fpr}");
    public async Task TrackTuneLatencyAsync(string knowledgebaseId, Func<Task<HttpResponseMessage>> tuneAction)
        var stopwatch = Stopwatch.StartNew();
        try
            var response = await tuneAction();
            stopwatch.Stop();
            var latencyMs = stopwatch.ElapsedMilliseconds;
            Console.WriteLine($"[LATENCY] Tune applied to KB {knowledgebaseId} in {latencyMs}ms");
            await LogAuditAsync(null, $"Tune latency: {latencyMs}ms | Status: {(int)response.StatusCode}");
            return response;
        catch (Exception ex)
            stopwatch.Stop();
            Console.WriteLine($"[LATENCY] Tune failed for KB {knowledgebaseId} after {stopwatch.ElapsedMilliseconds}ms");
            await LogAuditAsync(null, $"Tune failure: {ex.Message} | Latency: {stopwatch.ElapsedMilliseconds}ms");
            throw;
    private async Task LogAuditAsync(TuningPayload? payload, string message)
        var timestamp = DateTime.UtcNow.ToString("o");
        var logEntry = $"[{timestamp}] {message}{Environment.NewLine}";
        if (payload != null)
            logEntry += $"Payload Hash: {GetPayloadHash(payload)}{Environment.NewLine}";
        await File.AppendAllTextAsync(_auditLogPath, logEntry);
    private string GetPayloadHash(TuningPayload payload)
        var json = System.Text.Json.JsonSerializer.Serialize(payload, new System.Text.Json.JsonSerializerOptions { WriteIndented = false });
        using var sha = System.Security.Cryptography.SHA256.Create();
        var bytes = Encoding.UTF8.GetBytes(json);
        var hash = sha.ComputeHash(bytes);
        return Convert.ToHexString(hash);
Step 5: Trigger A/B Testing and Execute Calibrate Directive
After validation, you must trigger the A/B testing split and submit the calibrate directive. CXone returns a 202 Accepted with an async job ID. You poll the job status until completion. The following method handles the A/B trigger, calibrate submission, and webhook synchronization registration.
public class AbTestAndCalibrateClient
    public AbTestAndCalibrateClient(CxoneAuthClient auth, string orgId)
        _auth = auth;
        _client.DefaultRequestHeaders.Accept.Add(new System.Net.Http.Headers.MediaTypeWithQualityHeaderValue("application/json"));
    public async Task<string> TriggerAbTestAsync(string knowledgebaseId, string tuneId)
        _client.DefaultRequestHeaders.Authorization = new System.Net.Http.Headers.AuthenticationHeaderValue("Bearer", token);
        var payload = new
            tuneId = tuneId,
            splitRatio = 0.5,
            durationMinutes = 1440,
            metrics = new[] { "ctr", "resolution_rate", "false_positive_rate" }
        var url = $"{_baseUrl}/api/v2/agentassist/knowledgebases/{knowledgebaseId}/tuning/ab-tests";
        var content = new StringContent(JsonSerializer.Serialize(payload, _jsonOptions), System.Text.Encoding.UTF8, "application/json");
        var response = await _client.PostAsync(url, content);
        var body = await response.Content.ReadAsStringAsync();
        Console.WriteLine($"[AB TEST] Triggered. Response: {body}");
        return body;
    public async Task RegisterWebhookSyncAsync(string knowledgebaseId, string webhookUrl)
        var payload = new
            event = "weight_tuned",
            targetUrl = webhookUrl,
            active = true,
            retryPolicy = new { maxRetries = 3, backoffSeconds = 10 }
        var url = $"{_baseUrl}/api/v2/agentassist/knowledgebases/{knowledgebaseId}/webhooks";
        Console.WriteLine($"[WEBHOOK] Registered weight_tuned sync to {webhookUrl}");
    public void Dispose() => _client.Dispose();
The following console application combines authentication, payload construction, validation, atomic PUT execution, A/B testing, webhook registration, and governance tracking into a single runnable workflow. Replace placeholder credentials and knowledge base IDs before execution.
using System;
class Program
    static async Task Main(string[] args)
        const string OrgId = "your-org-id";
        const string ClientId = "your-client-id";
        const string ClientSecret = "your-client-secret";
        const string KnowledgebaseId = "kb-12345-abcde";
        const string AuditLogPath = "tuning_audit.log";
        const string WebhookUrl = "https://your-webhook-endpoint.com/weight-tuned";
        var auth = new CxoneAuthClient(OrgId, ClientId, ClientSecret);
        var tuningClient = new CxoneTuningClient(auth, OrgId);
        var governance = new TuningGovernanceService(AuditLogPath);
        var abClient = new AbTestAndCalibrateClient(auth, OrgId);
        try
            // Step 1: Construct tuning payload
            var payload = new TuningPayload
                RankingReferences = new List<RankingReference>
                    new() { Field = "title", Type = "text", Priority = 1 },
                    new() { Field = "body", Type = "text", Priority = 2 }
                RelevanceMatrix = new RelevanceMatrix
                    Bm25Parameters = new Bm25Parameters { K1 = 1.5, B = 0.75 },
                    FieldWeights = new List<FieldWeight>
                        new() { FieldName = "title", Weight = 3.0 },
                        new() { FieldName = "body", Weight = 1.0 }
                    BoostFactors = new List<BoostFactor>
                        new() { Condition = "category:urgent", Boost = 5.0 },
                        new() { Condition = "status:verified", Boost = 2.5 }
                CalibrateDirective = new CalibrateDirective
                    Mode = "incremental",
                    ValidateBeforeApply = true,
                    AbTestEnabled = true
            // Step 2: Validate against search engine constraints
            TuningValidator.ValidatePayload(payload);
            // Step 3: Validate historical metrics (CTR & false positive pipeline)
            var historicalMetrics = new Dictionary<string, double>
                { "ctr", 0.22 },
                { "false_positive_rate", 0.03 }
            await governance.ValidateTuneMetricsAsync(payload, historicalMetrics);
            // Step 4: Apply tuning via atomic PUT with latency tracking
            Console.WriteLine("[TUNING] Submitting atomic PUT...");
            var tuneResponse = await governance.TrackTuneLatencyAsync(KnowledgebaseId, async () =>
                var retryPolicy = Polly.Policy.HandleResult<HttpResponseMessage>(r => r.StatusCode == System.Net.HttpStatusCode.TooManyRequests)
                    .WaitAndRetryAsync(3, retryAttempt => TimeSpan.FromSeconds(Math.Pow(2, retryAttempt)));
                return await retryPolicy.ExecuteAsync(async () =>
                    var resp = await tuningClient.ExecuteTuningPutAsync(KnowledgebaseId, payload);
                    resp.EnsureSuccessStatusCode();
                    return resp;
            var tuneId = "tune-" + Guid.NewGuid().ToString("N")[..8]; // Simulated extraction from response
            Console.WriteLine($"[TUNING] Successfully applied. Tune ID: {tuneId}");
            // Step 5: Trigger A/B testing and register webhook sync
            await abClient.TriggerAbTestAsync(KnowledgebaseId, tuneId);
            await abClient.RegisterWebhookSyncAsync(KnowledgebaseId, WebhookUrl);
            Console.WriteLine("[COMPLETE] Ranking tuner workflow finished successfully.");
        catch (HttpRequestException ex)
            Console.WriteLine($"[NETWORK ERROR] {ex.Message}");
        catch (InvalidOperationException ex)
            Console.WriteLine($"[VALIDATION ERROR] {ex.Message}");
            Console.WriteLine($"[UNEXPECTED ERROR] {ex.Message}");
        finally
            tuningClient.Dispose();
            abClient.Dispose();
Error: 400 Bad Request (Invalid Boost Factor or BM25 Range)
  • Cause: The relevance matrix contains a boost factor exceeding 10.0, or BM25 k1/b values fall outside CXone search engine constraints.
  • Fix: Verify TuningValidator.ValidatePayload runs before submission. Adjust boost values to <= 10.0 and constrain k1 to [0.5, 2.0] and b to [0.5, 1.0].
  • Code Fix: The validator explicitly throws InvalidOperationException with the exact constraint violation. Catch this exception and correct the payload before retrying.
Error: 401 Unauthorized (Token Expired or Invalid Scope)
  • Cause: The OAuth token expired during the tuning workflow, or the client lacks agentassist:knowledgebase:write.
  • Fix: Ensure CxoneAuthClient refreshes tokens automatically. Verify the scope string includes both read and write permissions.
  • Code Fix: The GetAccessTokenAsync method caches tokens and adds a 2-minute safety buffer. If the error persists, regenerate client credentials in the CXone developer console.
Error: 429 Too Many Requests (Rate Limit Cascade)
  • Cause: CXone enforces per-organization rate limits on tuning endpoints. Rapid calibration or A/B test triggers exceed the threshold.
  • Fix: Implement exponential backoff. The complete example uses Polly to retry 429 responses with 2^attempt second delays.
  • Code Fix: Wrap ExecuteTuningPutAsync calls in the retryPolicy.ExecuteAsync block shown in the complete example. Monitor Retry-After headers if CXone returns them.
Error: 409 Conflict (Concurrent Tune Modification)
  • Cause: Multiple tuning operations target the same knowledge base simultaneously, causing state conflicts.
  • Fix: Serialize tuning requests per knowledge base. Use application-level locking or queue-based processing.
  • Code Fix: Add a SemaphoreSlim or distributed lock before calling TrackTuneLatencyAsync. Release the lock after receiving 200 OK or 202 Accepted.
