TTS Prompt not played
Hi, Guys,
Nuance speech server and TTS vocalizer work properly.
but TTS prompt not played correctly in IVR App.
below is the GVP_MRCPv1_TTS_Nuance configuration:
[provision]
vrm.client.NoSpeechLanguageHeader=true
vrm.client.PassThruTTSPort=false
vrm.client.resource.name=REALSPEAK
vrm.client.resource.type=TTS
vrm.client.resource.uri=rtsp://10.36.141.193:4900/media/speechsynthesizer
vrm.client.SendLoggingTag=true
vrm.client.SpeechMarkerEncoding=UTF-8
vrm.client.TransportProtocol=MRCPv1
vrm.proxy.ping_interval=30000
The following is some related error msg.
2012-08-14 08:52:34.313 DBUG 00F30102-100032CA-tts-default-4 5660 06100000 VRMClientRequestMgr.C:3241 Timeout value is: 10000
2012-08-14 08:52:34.313 DBUG 00000000-00000000 5660 06100000 VRMCommon.h:107 sdpobjrelref 240c9b50 refcount=3
2012-08-14 08:52:34.325 DBUG 00000000-00000000 752 08400000 RtspStack.cxx:1201 Received SocketData() for 421437232
2012-08-14T08:52:34.325 Std 22605 EROR 00F30102-100032CA-tts-default-4 752 060007D5 No Rtsp Session Id with request
2012-08-14 08:52:34.325 DBUG 00F30102-100032CA-tts-default-4 752 06000000 RtspMrcpTransport.C:1059 Binding the MRCP session to RTSP session
2012-08-14T08:52:34.325 Std 22605 EROR 00F30102-100032CA-tts-default-4 752 060007D5 No Content-Type for SETUP reply nStatusCode[404] content msg[RTSP/1.0 404 Not Found
CSeq: 57
2012-08-14 08:52:34.325 DBUG 00F30102-100032CA-tts-default-4 752 06000000 MrcpStack.C:2240 Received Open Session Notification for Message-ID[109]
2012-08-14 08:52:34.325 DBUG 00F30102-100032CA-tts-default-4 752 06100000 VRMClientStackHandler.C:472 Received OpenSession Notficiation - MsgID: 109 RTSP ID:
2012-08-14 08:52:34.325 DBUG 00000000-00000000 3948 00600000 ReportingClient.cpp:341 sendUpstream(): Queuing upstream message: 1|AppID=0|ST=1344948749055|100665301|00F30102-100032CA|1344948754325|No Rtsp Session Id with request
2012-08-14 08:52:34.325 DBUG 00000000-00000000 3948 00600000 ReportingClient.cpp:341 sendUpstream(): Queuing upstream message: 1|AppID=0|ST=1344948749055|100665301|00F30102-100032CA|1344948754325|No Content-Type for SETUP reply nStatusCode[404] content msg[RTSP/1.0 404 Not Found
CSeq: 57
2012-08-14 08:52:34.325 DBUG 00F30102-100032CA-tts-default-4 5660 06100000 VRMClientRequestMgr.C:1146 Handle Open Session Notification
2012-08-14T08:52:34.325 Std 20003 WARN 00F30102-100032CA-tts-default-4 5660 06100000 Opensession Notification returned error status 406 from 10.36.141.193:4900
2012-08-14 08:52:34.325 DBUG 00000000-00000000 5660 06100000 VRMClientConnectionMgr.C:3407 Updated state for primary server. EngineName[REALSPEAK] IPPort[10.36.141.193:4900] RTSP-URI[rtsp://10.36.141.193:4900/media/speechsynthesizer] to state[2]
2012-08-14 08:52:34.325 DBUG 00000000-00000000 5660 06A00000 MRCPClientAdaptor.C:1669 SRMHealthMonitor: updates Health Info: status
2012-08-14 08:52:34.325 DBUG 00000000-00000000 5660 06A00000 MRCPClientAdaptor.C:1680 SRMHealthMonitor: receives Health Info [10.36.141.193:4900TTSMRCPv1] [Quarantined]
2012-08-14 08:52:34.325 DBUG 00000000-00000000 5660 06100000 VRMClientConnectionMgr.C:3494 Added the server with RTSP-URI[rtsp://10.36.141.193:4900/media/speechsynthesizer] to the quarantined resource list.
2012-08-14 08:52:34.325 DBUG 00F30102-100032CA-tts-default-4 5660 06100000 VRMClientRequestMgr.C:4600 Timeout value is: 10000
2012-08-14T08:52:34.325 Trc 20001 INFO 00F30102-100032CA-tts-default-4 5660 06100000 Opensession Failed with URL rtsp://10.36.141.193:4900/media/speechsynthesizer. The server will be qurantined.
2012-08-14 08:52:34.325 DBUG 00000000-00000000 5660 06100000 VRMCommon.h:100 sdpobjaddref 240c9b50 refcount=4
2012-08-14 08:52:34.325 DBUG 00000000-00000000 5660 06100000 VRMClientConnectionMgr.C:537 Trying a primary EngineName[REALSPEAK] IPPort[10.36.141.193:4900] RTSP-URI[rtsp://10.36.141.193:4900/media/speechsynthesizer] is not available[1] or state is not active[2]
2012-08-14 08:52:34.325 DBUG 00000000-00000000 5660 06100000 VRMClientConnectionMgr.C:593 Cannot find resource using primary engine list
2012-08-14T08:52:34.325 Std 23226 EROR 00F30102-100032CA-tts-default-4 5660 061007DC Unable to re-open a session using engine REALSPEAK - please check configuration (return code: -4)2012-08-14 08:52:34.325 DBUG 00000000-00000000 5660 06100000 VRMCommon.h:107 sdpobjrelref 240c9b50 refcount=3
2012-08-14T08:52:34.325 Std 20003 WARN 00F30102-100032CA-tts-default-4 5660 06100000 RetryOpenSession Failed. message id: 109 failed
2012-08-14T08:52:34.325 Trc 20001 INFO 00F30102-100032CA-tts-default-4 5660 06100000 Unexpected session type received: 26
2012-08-14 08:52:34.325 DBUG 00F30102-100032CA-tts-default-4 5660 06100000 VRMClientRequestMgr.C:1320 Opensession Notification returned 406 as status code from 10.36.141.193:4900
2012-08-14 08:52:34.325 DBUG 00F30102-100032CA-tts-default-4 5660 02500000 VrmManager.cxx:307 VrmManager::VRMClientOpenSessionResponse(TTS) - nStatus=406
2012-08-14 08:52:34.325 DBUG 00F30102-100032CA-tts-default-4 5660 02500000 VrmManager.cxx:690 VrmManager::ReleaseLicense(TTS)
2012-08-14 08:52:34.325 DBUG 00000000-00000000 5660 02400000 GVPLicenseLogger.C:112 Release GVP License:Product=vggateway; Features=tts; Current Use=0; Peak Use=1
2012-08-14 08:52:34.325 DBUG 00F30102-100032CA 5660 01C00000 VRMSessionHandler.C:121 TYPE == 1
