We are trying to use a listbox to attach some data. We have archive attach data when we load the jsp page. However when we use the control the attach data fail.
Have someone a code example where we can use a editbox, listbox, etc to attach data during the call is with the agent?
Are you using Genesys Active X? I am always confused about GAD.
here is the default way:
Private Sub CommandAttach_Click()
'find node based on key in combo box, kvpair.value to user's input box
Dim X As Integer
Dim dataNode As CTKVPair
Dim count As Integer
For X = 0 To UserData(LineSelected).GetCount - 1
Set dataNode = UserData(LineSelected).Get(X)
If dataNode.Key = ComboKey.Text Then
If dataNode.Type = CKVTypeString Then
dataNode.StringValue = Me.txtCallData.Text
If X > 0 Then
Call UserData(LineSelected).Insert(X, dataNode)
UserData(LineSelected).Remove (X)
Else
UserData(LineSelected).Remove (X + 1)
End If
Exit For
Else
MsgBox ('Panda!')
End If
Exit Sub
End If
Next X
Call SoftPhone.TLine1(LineSelected).TAttachData(UserData(LineSelected), False)
UpdateAttachDataDisplay (LineSelected)
End Sub
There seems to be some confusion on GAD… Genesys Desktop (or GAD as it used to be) is a web-based thin-client multimedia desktop. It allows customization through the use of xml & jsp code; these customizations allow a developer to add functionality, such as new tabs, controls, etc. You can’t really change the general look and feel of Gdesktop, but it’s reasonably effective design that allows you to customize it and also to be able to upgrade without losing all your custom functionality.
To address the main question though; are you able to add attached-data in the normal way? You can do this by clicking on the attached-data tab on any interaction and pressing the “New…” button. If this doesn’t give you what you need, let us know and we can discuss further.
To do this in GAD (version 7.5 or 7.6 for example), you use Java AIL in your custom jsp’s. This is what barleycorn is saying as well and the high level process to customise GAD is explained in the Genesys Desktop Developer Guide.
Now, specific to your question: you need to use the AilFactory to retrieve the active interaction. From then on you can just set additional attached data. Do NOT forget to invoke “interaction.saveAttachedData();” at the end.
A simple code sample:
Now, even more interesting; for outbound, you can directly change fields in the calling list from your custom code. So, if you need to save some information from contacted customers, you can store the values in fields you set up in the calling list.
