Troubleshooting SIP 487 Request Terminated Errors in Genesys Cloud Call Flows When Carrier Early Media Handling Conflicts with Application-Level Call Control Logic
This guide details how to diagnose and resolve SIP 487 signaling failures caused by carrier early media negotiation conflicts in Genesys Cloud CX. You will configure SIP trunk media parameters, adjust Architect flow media control blocks, and implement SDP negotiation guards to align carrier signaling behavior with Genesys Cloud media server state machines. The end result is a stable call path where media routing, prompt playback, and DTMF collection operate without premature dialog termination.
  • Licensing Tier: Genesys Cloud CX 3 or CX 4 (Telephony features included). Bring Your Own Carrier (BAC) or Direct Cloud SIP (DCS) trunk provisioning required.
  • Permission Strings: Telephony > Trunk > Edit, Telephony > SIP > View, Architect > Design > Edit, Reports > Advanced > View, Admin > Organization > View
  • OAuth Scopes: telephony:trunk:write, architect:flow:write, call:center:reports:read, telephony:log:read
  • External Dependencies: SIP carrier account with configurable early media/SDP settings, Wireshark or carrier-side SIP tracing capability, Genesys Cloud SIP message log access, network path validation tooling for RTP port ranges.
1. Isolate Early Media Signaling Mismatches via SIP Tracing & SDP Analysis
The first step requires capturing the exact SIP dialog lifecycle where the 487 occurs. Genesys Cloud returns a 487 Request Terminated when the media server detects a state machine collision between the established signaling path and the expected media path. Early media from the carrier typically arrives in a 180 Ringing or 183 Session Progress response containing an SDP body. If the Genesys Cloud edge node receives this SDP but the Architect flow has not yet accepted the media state, the media server will terminate the dialog to prevent orphaned RTP streams.
Capture the SIP trace using the Genesys Cloud SIP message logger or export carrier-side captures. Filter for INVITE, 180/183, 200 OK, and BYE/CANCEL sequences. Identify whether the carrier attaches an SDP offer before the 200 OK response. Examine the c= and m= lines in the SDP payload. Note the IP addresses, port ranges, and codec attributes. Cross-reference these values with the Genesys Cloud edge node IP and the trunk media port configuration.
The Trap: Assuming the 487 originates from carrier timeout or network packet loss. Engineers frequently trace the error to a missing 200 OK and immediately adjust trunk timeouts or retry logic. The actual failure occurs because the Genesys Cloud media server receives an unsolicited SDP offer, cannot reconcile it with the flow’s media control state, and proactively terminates the request to protect resource allocation. Correcting timeouts without addressing the SDP negotiation mismatch compounds the error rate.
Architectural Reasoning: Genesys Cloud utilizes a centralized, software-defined media server architecture. All media streams must traverse the media server for call flow control, recording, and analytics. Early media bypasses this control plane by establishing a direct RTP path between the carrier and the edge node before the media server registers the dialog in its active session table. When the Architect flow later attempts to inject media or collect input, the media server detects a conflicting RTP stream and issues a 487 to reset the dialog state. Isolating the exact SIP message containing the premature SDP offer allows you to target the configuration layer that governs SDP acceptance.
2. Configure Genesys Cloud SIP Trunk Media Negotiation Parameters
Once the early media SDP is identified, adjust the trunk configuration to enforce strict media negotiation boundaries. Navigate to Admin > Telephony > Trunks > [Target Trunk] > Media tab. Locate the Early Media setting. Set this to Disable or Negotiate on 200 OK. Configure the SDP Offer/Answer behavior to Require Answer on 200 OK. Set the Media Port Range to match your firewall rules and carrier expectations. Ensure Codec Negotiation is set to Strict to prevent fallback to unsupported codecs that trigger renegotiation loops.
Apply the configuration via the Admin UI or programmatically using the Trunk API. The following payload updates the early media handling and SDP negotiation flags for an existing trunk:
PATCH /api/v2/telephony/providers/edge/trunks/{trunkId}
Authorization: Bearer {access_token}
  "media": {
    "earlyMedia": "disabled",
    "sdpNegotiation": "strict",
    "codecs": ["G711u", "G711a", "Opus"],
    "mediaPortRangeStart": 30000,
    "mediaPortRangeEnd": 30500
The Trap: Enabling early media on the trunk while simultaneously allowing the Architect flow to play prompts or collect DTMF immediately after call answer. This configuration creates a race condition where the carrier begins transmitting ringback tones or IVR prompts over RTP while the Genesys Cloud flow attempts to establish its own media path. The media server detects overlapping SDP sessions and terminates the request to prevent audio corruption. Disabling early media on the trunk without updating the carrier side can also cause the carrier to drop the call for failing to acknowledge the 183 SDP, resulting in a 487 from the carrier instead of Genesys.
Architectural Reasoning: The trunk media configuration dictates how the Genesys Cloud edge node handles out-of-band signaling versus in-band media. When early media is disabled, the edge node strips SDP bodies from provisional responses and waits for the 200 OK to establish the media path. This forces the media server to initialize the session table before any RTP packets arrive. Strict SDP negotiation prevents the edge node from accepting codec attributes that differ from the flow’s expected media settings. This alignment ensures the media server can route all audio through its control plane, enabling call recording, speech analytics, and flow-driven media injection without state conflicts.
3. Restructure Architect Flow Media Control to Prevent Premature Dialog Termination
After securing the trunk media parameters, adjust the call flow to handle media state transitions explicitly. Open the flow in Architect. Locate the Make Outbound Call or Answer Inbound Call block. Add a Set Media Settings block immediately after the call establishment block. Configure the Early Media property to Off and the DTMF Detection property to RFC2833 or Inband based on carrier capability. Insert a Wait block with a duration of 500 to 1000 milliseconds before the first Play Prompt or Collect DTMF block. This pause allows the media server to complete the SDP answer exchange and register the RTP stream in the session table.
If the flow requires dynamic prompt playback based on call context, wrap the media blocks in a Try/Catch block. Configure the Catch block to handle MediaServerError exceptions. Log the error code and trigger a fallback path that routes to a voice mail or agent queue without media playback. This prevents the flow from hanging on a failed media negotiation and reduces queue abandonment rates.
The Trap: Placing a Play Prompt or Collect DTMF block directly after the call establishment block without a media state guard. The media server attempts to send a SIP re-INVITE to renegotiate the media path for prompt injection. If the carrier is still transmitting early media RTP, the re-INVITE conflicts with the active stream. The carrier either ignores the re-INVITE or responds with a 488 Not Acceptable Here, causing Genesys Cloud to terminate the dialog with a 487. Removing the wait block or skipping the Set Media Settings block leaves the flow vulnerable to carrier timing variations, especially on high-latency or congested SIP trunks.
Architectural Reasoning: Architect flows execute sequentially, but media server initialization operates asynchronously. The call establishment block completes when the signaling path reaches 200 OK, but the media server requires additional cycles to allocate RTP endpoints, apply codec transcoding rules, and register the session in the media routing table. The Set Media Settings block explicitly informs the media server of the expected media state, preventing automatic renegotiation attempts. The wait block provides a deterministic buffer for the SDP answer to propagate through the network. This sequencing aligns the flow’s execution thread with the media server’s state machine, eliminating race conditions that trigger 487 terminations.
4. Implement Carrier-Side Early Media Suppression or Routing Guards
When trunk and flow configurations cannot fully resolve the conflict, coordinate with the carrier to suppress early media at the network edge. Request the carrier to disable 183 Session Progress with SDP for SIP trunks terminating to Genesys Cloud. If the carrier cannot modify provisioning, implement routing guards within Genesys Cloud. Create a Routing Rule in Telephony > Routing Rules that prefixes outbound calls to problematic destinations with a specific dial plan marker. Route these markers to a secondary trunk configured with Early Media set to Negotiate and a dedicated Call Flow that bypasses media injection until the call reaches the final destination.
Use the Genesys Cloud Reporting API to monitor 487 error rates per trunk and destination. The following query retrieves SIP error metrics for a specific time window:
GET /api/v2/analytics/details/query?reportId=call-center:outbound-campaign-performance
  "timeGroup": "P1D",
  "timeFilter": {
    "from": "2024-01-01T00:00:00.000Z",
    "to": "2024-01-02T00:00:00.000Z"
  "groupings": ["destination", "trunkId"],
  "metrics": ["sipErrors"]
The Trap: Relying on carrier verbal assurances that early media is disabled without validating via SIP tracing. Carriers often inherit legacy PSTN routing behaviors where ringback tones are generated at the carrier proxy before the SIP dialog reaches the cloud PBX. These tones bypass trunk configuration settings and arrive as unsolicited RTP streams. Routing guards without monitoring create blind spots where 487 errors persist on high-volume destinations, degrading agent productivity and increasing re-dial penalties.
Architectural Reasoning: Enterprise SIP networks frequently interoperate with legacy circuit-switched infrastructure that generates early media at the tandem switch level. Genesys Cloud cannot intercept or suppress media generated upstream of the SIP trunk termination point. Routing guards isolate problematic traffic patterns and apply tailored media handling rules per destination. This approach preserves trunk capacity for well-behaved carriers while containing 487 failures to isolated flow paths. Continuous monitoring via the analytics API provides empirical validation of routing guard effectiveness, enabling data-driven adjustments to trunk provisioning and carrier SLAs.
Edge Case 1: Asymmetric SDP Codec Negotiation Causing Silent 487s
  • The Failure Condition: Calls drop with a 487 immediately after 200 OK, but no audio plays and no flow errors log.
  • The Root Cause: The carrier SDP offer lists Opus as the primary codec, but the Genesys Cloud trunk is configured with strict G711 negotiation. The media server rejects the SDP answer, triggers a re-negotiation, and the carrier responds with a 487 to terminate the mismatched dialog.
  • The Solution: Align the trunk codec list with the carrier’s advertised order. Set SDP Negotiation to Relaxed on the trunk to allow codec fallback. Add a Set Media Settings block in the flow to force G711u for media injection. Validate with carrier tracing to confirm the SDP answer matches the offer’s preferred codec.
Edge Case 2: DTMF Collection Interference with Early Media RTP Packets
  • The Failure Condition: DTMF collection blocks timeout or return invalid characters, followed by a 487 termination.
  • The Root Cause: Carrier early media RTP packets contain in-band audio that mimics DTMF tones. The media server’s DTMF detector misinterprets the carrier ringback audio as user input, triggers an unexpected flow branch, and the media server terminates the dialog when the branch lacks a valid media path.
  • The Solution: Disable in-band DTMF detection on trunks experiencing early media conflicts. Enforce RFC2833 DTMF signaling in the Set Media Settings block. Configure the carrier to disable in-band ringback tones. Add a Filter Input block before DTMF collection to validate character sets and reject non-standard inputs.
Edge Case 3: BAC Carrier Proxy Re-INVITE Timing Conflicts
  • The Failure Condition: 487 errors occur intermittently on specific BAC carriers during peak hours.
  • The Root Cause: The carrier proxy sends a mid-call re-INVITE to renegotiate codecs due to network congestion. The Genesys Cloud flow is simultaneously executing a media playback block. The overlapping SIP re-INVITE and flow-driven media control create a state conflict, causing the media server to terminate the request.
  • The Solution: Configure the trunk Media settings to Reject Mid-Call Re-INVITE. Implement a Try/Catch block around all media playback nodes to gracefully handle media server interruptions. Coordinate with the carrier to disable dynamic codec renegotiation on the trunk. Monitor Call Quality reports to identify congestion patterns and route traffic to redundant trunk paths during peak windows.
