Trouble starting Primary confserv after Failover
hi,
i think i messed up my cfg- files again. both ‘confserv’ and ‘confserv_HA’ start up properly. but when the confserv_HA becomes primary due to a failover confserv can’t initialize again, afterwards. If I switch off confserv_HA primary, then confserv is able to initialize again. I’m not sure about the naming convention in the Cfg- file concerning Backup Config Server. Following Message is put out in Log:
Std 04502 Cannot connect to ConfigurationServer ‘’ at host ‘test1.domain.de’, port 2020, reason ‘CFGServerNotFound’ on dbsync_violated executed when server is not fully loaded
Topology
test0 test1
cfg_dbserver cfg_dbserver_HA
confserv confserv_HA
confserv.cfg@test0:
[confserv]
port =2020
management-port =2021
server = dbserver
encryption = false
encoding = utf-8
[history-log]
all=histlog
expiration=30
client-expiration=1
max-records=1000
active=true
failsafe-store-processing=true
[log]
verbose = all
standard = network
all = D:\var\log\genesys\confserv\confserv
time_format=ISO8601
buffering = false
expire = 10
segement = 10000
[hca]
schema = none
record-vag = true
[soap]
port = 2022
debug = true
client_lifespan = 600
[dbserver]
host =test0
port =4040
dbengine =oracle
dbserver =testawd
username =genconfig
password =***
server = dbserver_HA
reconnect-timeout = 10
response-timeout = 600
[dbserver_HA]
host =test1
port =4040
dbengine =oracle
dbserver =testawd
username =genconfig
password =***
server = dbserver
confserv.cfg@test1:
[confserv_HA]
port=2020
management-port=2021
server=dbserver
encryption=false
encoding=utf-8
force-reconnect-reload=true
[history-log]
all=histlog
expiration=30
client-expiration=1
max-records=1000
active=true
[log]
verbose=all
standard=network
all=D:\var\log\genesys\confserv_HA\confserv_HA
buffering=false
expire=10
segment=50000
time_format=ISO8601
[hca]
schema = none
[soap]
port=2022
debug=true
client_lifespan=600
[dbserver]
host=test0
port=4040
dbengine=oracle
dbserver=testawd
username=genconfig
password=***
server=dbserver_HA
reconnect-timeout=10
response-timeout=600
[dbserver_HA]
host=test1
port=4040
dbengine = oracle
dbserver = testawd
username = genconfig
password = ***
server = dbserver
What is my error in reasoning? Hope somebody can help.
Cheers
Phil
provide log files from you promary conf. server immediately after it restart.
Here’s the log from primary confserv when it fails to initialize as backup after abnormal termination:
Build information :
Description : (Content freeze)
Timestamp : Feb 3 2010 09:07:14
Components :
Configuration library v.7.6.000.05
Common library v.7.5.000.41 C2
Service library v.7.5.000.04 MT
Message library v.7.5.000.01
Log library v.7.6.000.00 MT
LCA library v.7.5.000.06
Thread library v.7.6.000.00
DBServer library v.7.5.000.02
Genesys License library v.7.5.000.00 MT
License library v.FLEXLm 8.3c
Stat Script library v.7.5.000.00
Application name: confserv
Application type: ConfigurationServer (21)
Command line: confserv.exe -service ConfigServerST -c confserv.cfg -app confserv -host test1.domain.de -port 2020 -sstart
Host name: test0
DST: TZ = 1, timeb = 0
Time zone: -3600, W. Europe Standard Time, W. Europe Daylight Time
UTC time: 2010-03-23T12:42:37.416
Local time: 2010-03-23T13:42:37.416
Start time (UTC): 2010-03-23T12:42:37
Running time: 0:00:00:00
Host info: Windows 5.2.3790, 2, Service Pack 2, 2.0, 0110, 3
File: (1) D:\var\log\genesys\confserv\confserv.20100323_134237_417.log
2010-03-23T13:42:37.416 Trc 04112 The Log Output of type ‘D:\var\log\genesys\confserv\confserv’ has been created and opened
2010-03-23T13:42:37.416 Std 22110 Encoding [utf-8] is set successfully.
2010-03-23T13:42:37.416 Std 05060 Application started
2010-03-23T13:42:37.416 Std 22100 Genesys Configuration Server. Version 7.6.000.57
2010-03-23T13:42:37.416 Std 22101 Copyright (c) 1997-2009 Genesys Telecommunications Laboratories, Inc.
2010-03-23T13:42:37.416 Std 22102 Server application name is set to [confserv]
2010-03-23T13:42:37.416 Std 22915 Server mode is set to [PRIMARY]
2010-03-23T13:42:37.416 Std 22900 Objectset [main-cfgset] is being loaded …
2010-03-23T13:42:37.603 Std 22901 Objectset [main-cfgset] : XML schema is loaded
13:42:37.681 dbserver_manager with alias main-dbserver has being registered for the socket 248, reference counter 3
2010-03-23T13:42:37.681 Trc 04500 Connecting to DBServer ‘’ at host ‘test0’, port 4040
2010-03-23T13:42:37.697 Std 04503 Connected to DBServer ‘’ at host ‘test0’, port 4040
2010-03-23T13:42:37.697 Trc 24400 Trying to open database [testawd] ,SQL server [testawd]
2010-03-23T13:42:37.775 Std 07001 Database ‘testawd’ opened
13:42:37.775 dbserver_manager with alias dbcontroller_alias has being registered for the socket 292, reference counter 3
13:42:37.775 cfg_refresh DB server connection connecting
13:42:37.775 cfg_refresh DB server connection established
2010-03-23T13:42:37.853 Std 22913 Configuration database version is [7.5]
2010-03-23T13:42:37.853 Std 22918 Configuration tenancy model is: [SINGLE-TENANT]
Database schema is reading … done
2010-03-23T13:42:37.900 Std 22910 Database schema [dbschema.xml] is loaded
MAXDBIE request is about to be sent
MAXDBID read responce received
2010-03-23T13:42:37.916 Std 22500 LCA is connected at [test0.domain.de:4999]
2010-03-23T13:42:37.916 Std 22911 Backup server [confserv_HA] on [test1.domain.de:2020] is set up in the configuration
2010-03-23T13:42:37.916 Trc 04500 Connecting to ConfigurationServer ‘’ at host ‘test1.domain.de’, port 2020
addp-trace off
(addp_xconfig) local OFF, remote OFF, trace off
2010-03-23T13:42:39.056 Std 04502 Cannot connect to ConfigurationServer ‘’ at host ‘test1.domain.de’, port 2020, reason ‘CFGServerNotFound’
2010-03-23T13:42:39.056 Std 22906 Objectset [main-cfgset] : data is cleaned up. Source : [DBServer]
2010-03-23T13:42:39.056 Std 22902 Objectset [main-cfgset] : read requests sent on DBServer
Cluster [principal] is being read …done
Cluster [statistic] is being read …done
Cluster [persons] is being read …done
Cluster [CTI] is being read …done
Cluster [scripts] is being read …done
Cluster [outbound] is being read …done
Cluster [gvp] is being read …done
Cluster [service] is being read …2010-03-23T13:42:42.963 Trc 04500 Connecting to ConfigurationServer ‘’ at host ‘test1.domain.de’, port 2020
addp-trace off
2010-03-23T13:42:43.884 Std 04502 Cannot connect to ConfigurationServer ‘’ at host ‘test1.domain.de’, port 2020, reason ‘CFGServerNotFound’
on_dbsync_violated executed when server is not fully loaded
2010-03-23T13:42:43.884 Std 22300 Another Configuration Server is detected
2010-03-23T13:42:43.884 Std 22905 Objectset [main-cfgset] failed to load
refresh stopped because of unhandled violation of access to cfg_refresh table
Main loop has ended
2010-03-23T13:42:43.884 Std 05063 Normal termination
13:42:43.963 dbserver_manager with alias main-dbserver is about to unregister form socket 248, reference counter 2 (reason - disconnect)
2010-03-23T13:42:43.963 Std 04505 Disconnected from DBServer ‘’
13:42:43.963 dbserver_manager with alias dbcontroller_alias is about to unregister form socket 292, reference counter 2 (reason - disconnect)
13:42:43.963 cfg_refresh DB server disconnected
2010-03-23T13:42:43.963 Std 22501 LCA is disconnected
ConnCleanup: 7.5.000.41 C2
0) fd=228 SERVER: 0.0.0.0:0 connected q–x-r
Timers created 84
Timers deleted 22
Invalid timers 0
Conn created 6
Conn accepted 0
Conn connected 2
Conn exceptions 0
Conn closed 5
Conn deleted 5
Conn balance 1
Errors 0
2010-03-23T13:42:43.963 Trc 04109 Logging service stopped
Hi Phil,
Message in your log is clear - there is another Configuration Server in primary mode running using the same database thus Configuration Server cannot initialize properly.
2010-03-23T13:42:43.884 Std 22300 Another Configuration Server is detected 2010-03-23T13:42:43.884 Std 22905 Objectset [main-cfgset] failed to load refresh stopped because of unhandled violation of access to cfg_refresh table Main loop has ended
It seems to me that your primary Configuration Server is unable to connect to backup CS (by meaning of deployment) so it tries to start in primary mode. Please check that you have configured correctly backup server in CME (application “confserv”, tab “Server Info”) and there is no firewall blocking communication between primary and backup Configuration Servers.
hi rené,
thanks for your feedback.
the backup for the primary is properly configured. the proper failover is confirming this. afaik, the primary has not to be configured as backup for the backup CS.
Firewall is a good hint. Indeed, both hosts are configured in the same subnet, but a telnet shows the port 2020 is blocked. im gonna figure that out. must be kinda local firewall.
Cheers
Phil
everything#s fine now…
i couldnt find any firewall. after restarting confserv_HA while confserv was running the port could be reached. im not really sure what this is supposed to mean, but at least it’s working 100 % proper
thanks for your effort, folks
cheers
phil
hi, i have the same problem as you can you tell what are you done to resolve them.
cdt
thank you in advance
