Triggering NICE Cognigy Bot Sessions from Genesys Cloud Studio Flows Using Go
  • A Go HTTP service that accepts payloads from a Genesys Cloud Studio HTTP Request block, maps flow variables to Cognigy input parameters, and initiates a new bot session via the Cognigy REST API.
  • The implementation uses the Cognigy API v2 /api/v2/session/start endpoint and standard Go libraries for HTTP handling, JSON serialization, and token management.
  • The programming language covered is Go (Golang 1.21+).
  • Cognigy tenant URL and valid API credentials (Client ID and Client Secret for OAuth2 client credentials flow)
  • Required OAuth scope: api or session:manage (verify in your Cognigy tenant settings)
  • Go 1.21 or later installed
  • No external dependencies required. The solution uses only the Go standard library.
Cognigy API v2 requires a Bearer token for session operations. The token is obtained via the OAuth2 client credentials grant. Production systems must cache the token and refresh it before expiration. The following implementation includes a thread-safe token cache with automatic expiry handling and a retry mechanism for transient authentication failures.
package main
import (
	"bytes"
	"context"
	"crypto/tls"
	"encoding/json"
	"fmt"
	"log"
	"net/http"
	"sync"
	"time"
type TokenResponse struct {
	ExpiresIn   int    `json:"expires_in"`
type TokenCache struct {
	mu        sync.Mutex
	token     string
	expiresAt time.Time
func NewTokenCache() *TokenCache {
	return &TokenCache{}
func (c *TokenCache) GetValidToken(ctx context.Context, tenantURL, clientID, clientSecret string) (string, error) {
	c.mu.Lock()
	if time.Now().Before(c.expiresAt.Add(-30*time.Second)) {
		c.mu.Unlock()
		return c.token, nil
	c.mu.Unlock()
	token, err := c.fetchToken(ctx, tenantURL, clientID, clientSecret)
	if err != nil {
		return "", err
	c.mu.Lock()
	defer c.mu.Unlock()
	c.token = token
	c.expiresAt = time.Now().Add(29 * time.Minute) // Cognigy tokens typically last 30 minutes
	return token, nil
func (c *TokenCache) fetchToken(ctx context.Context, tenantURL, clientID, clientSecret string) (string, error) {
	payload := fmt.Sprintf(`{"client_id":"%s","client_secret":"%s","grant_type":"client_credentials"}`, clientID, clientSecret)
	client := &http.Client{
		Timeout: 10 * time.Second,
		Transport: &http.Transport{
			TLSClientConfig: &tls.Config{MinVersion: tls.VersionTLS12},
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("https://%s/oauth/token", tenantURL), bytes.NewBufferString(payload))
	if err != nil {
		return "", fmt.Errorf("failed to create auth request: %w", err)
	resp, err := client.Do(req)
	if err != nil {
		return "", fmt.Errorf("auth request failed: %w", err)
	defer resp.Body.Close()
		return "", fmt.Errorf("auth failed with status %d", resp.StatusCode)
	var tokenResp TokenResponse
		return "", fmt.Errorf("failed to decode auth response: %w", err)
	if tokenResp.AccessToken == "" {
		return "", fmt.Errorf("empty access token received")
	return tokenResp.AccessToken, nil
Expected Auth Response:
  "token_type": "Bearer",
  "expires_in": 1800
Error Handling: The fetchToken function returns a wrapped error for network failures, HTTP status mismatches, and JSON decode errors. The GetValidToken method adds a 30-second safety buffer to prevent edge-case expiry during concurrent requests.
Step 1: Define Data Structures and Variable Mapping
Genesys Cloud Studio passes flow variables as a flat JSON object. The Go service must decode this payload, transform the keys to match Cognigy parameter naming conventions, and construct the session start request. Cognigy expects inputs as a key-value map where keys represent bot context variables.
type StudioPayload struct {
	UserID    string `json:"user_id"`
	QueueName string `json:"queue_name"`
	Intent    string `json:"intent"`
	Language  string `json:"language"`
type CognigySessionRequest struct {
	BotID    string            `json:"botId"`
	UserID   string            `json:"userId"`
	Platform string            `json:"platform"`
	Inputs   map[string]string `json:"inputs"`
func mapStudioToCognigy(studio StudioPayload, botID string) CognigySessionRequest {
	return CognigySessionRequest{
		BotID:    botID,
		UserID:   studio.UserID,
		Platform: "genesys-studio",
		Inputs: map[string]string{
			"userId":     studio.UserID,
			"queueName":  studio.QueueName,
			"intent":     studio.Intent,
			"language":   studio.Language,
			"source":     "studio-flow",
The Platform field tells Cognigy how to route platform-specific logic. Setting it to genesys-studio allows the bot developer to branch execution based on origin. The Inputs map directly becomes available in Cognigy Studio as context variables.
Step 2: Implement the HTTP Handler with Retry Logic
The handler decodes the Studio payload, retrieves a valid token, maps variables, and posts to Cognigy. The Cognigy API enforces rate limits. The implementation includes exponential backoff retry for 429 Too Many Requests and 5xx server errors.
func handleStudioWebhook(cache *TokenCache, tenantURL, clientID, clientSecret, botID string) http.HandlerFunc {
	return func(w http.ResponseWriter, r *http.Request) {
		if r.Method != http.MethodPost {
			http.Error(w, "Method not allowed", http.StatusMethodNotAllowed)
			return
		var studio StudioPayload
		if err := json.NewDecoder(r.Body).Decode(&studio); err != nil {
			http.Error(w, "Invalid JSON payload", http.StatusBadRequest)
			return
		cognigyReq := mapStudioToCognigy(studio, botID)
		body, err := json.Marshal(cognigyReq)
		if err != nil {
			http.Error(w, "Failed to marshal request", http.StatusInternalServerError)
			return
		token, err := cache.GetValidToken(r.Context(), tenantURL, clientID, clientSecret)
		if err != nil {
			http.Error(w, "Authentication failed", http.StatusUnauthorized)
			return
		resp, err := postWithRetry(r.Context(), tenantURL, token, body)
		if err != nil {
			http.Error(w, fmt.Sprintf("Cognigy session failed: %v", err), http.StatusBadGateway)
			return
		w.WriteHeader(http.StatusOK)
		w.Write(resp)
func postWithRetry(ctx context.Context, tenantURL, token string, body []byte) ([]byte, error) {
		Timeout: 15 * time.Second,
	endpoint := fmt.Sprintf("https://%s/api/v2/session/start", tenantURL)
	maxRetries := 3
	baseDelay := 1 * time.Second
	for attempt := 0; attempt <= maxRetries; attempt++ {
		req, err := http.NewRequestWithContext(ctx, http.MethodPost, endpoint, bytes.NewBuffer(body))
		if err != nil {
			return nil, fmt.Errorf("request creation failed: %w", err)
		if err != nil {
			return nil, fmt.Errorf("http request failed: %w", err)
		respBody, _ := io.ReadAll(resp.Body)
		resp.Body.Close()
		switch resp.StatusCode {
		case http.StatusOK:
			return respBody, nil
		case http.StatusTooManyRequests, http.StatusInternalServerError, http.StatusBadGateway:
			if attempt == maxRetries {
				return nil, fmt.Errorf("max retries reached. status: %d", resp.StatusCode)
			delay := baseDelay * (1 << attempt)
			time.Sleep(delay)
		default:
			return nil, fmt.Errorf("cognigy api error %d: %s", resp.StatusCode, string(respBody))
	return nil, fmt.Errorf("unexpected retry loop exit")
Expected Cognigy Response:
  "sessionId": "sess_8f7d6a5b4c3e2f1a0987654321",
  "botId": "bot_abc123",
  "userId": "user_98765",
  "platform": "genesys-studio",
  "context": {
    "queueName": "technical-support",
    "intent": "billing-inquiry",
    "language": "en",
  "messages": [
      "text": "Hello! I see you reached out about a billing inquiry. How can I assist you today?",
      "type": "text"
Non-Obvious Parameters:
  • platform must be a string identifier registered in Cognigy Studio. If omitted, Cognigy defaults to webchat, which may trigger incorrect platform-specific fallbacks.
  • inputs keys become top-level context variables in Cognigy Studio. They are accessible immediately in the first bot node without requiring a separate context update call.
  • The retry function uses bitwise shift for exponential backoff. This prevents overwhelming the Cognigy gateway during transient load spikes.
Step 3: Processing Results and Returning to Studio
The handler writes the raw Cognigy response directly to the Studio HTTP Request block. Studio can then parse the JSON using the Response variable. The response contains the sessionId, initial bot message, and the full context snapshot. Studio flows should store sessionId in a flow variable for subsequent message exchanges.
The postWithRetry function returns the complete response body. Studio developers can extract fields using standard JSON parsing in Studio or pass the entire payload to a Set Variable block. The handler returns 200 OK on success and 502 Bad Gateway on Cognigy failures, allowing Studio to route to error handling paths.
The following file compiles and runs as a standalone service. Replace the environment variables with your credentials before deployment.
package main
import (
	"bytes"
	"context"
	"crypto/tls"
	"encoding/json"
	"fmt"
	"io"
	"log"
	"net/http"
	"os"
	"sync"
	"time"
	mu        sync.Mutex
	token     string
	expiresAt time.Time
	c.mu.Lock()
		c.mu.Unlock()
		return c.token, nil
	c.mu.Unlock()
	if err != nil {
		return "", err
	c.mu.Lock()
	defer c.mu.Unlock()
	c.token = token
	return token, nil
	if err != nil {
	if err != nil {
		BotID:    botID,
			return
			return
		if err != nil {
			return
		if err != nil {
			return
		if err != nil {
			return
		w.Write(resp)
	maxRetries := 3
		if err != nil {
		if err != nil {
		resp.Body.Close()
		case http.StatusOK:
			time.Sleep(delay)
		default:
func main() {
	tenantURL := os.Getenv("COGNIGY_TENANT_URL")
	clientID := os.Getenv("COGNIGY_CLIENT_ID")
	clientSecret := os.Getenv("COGNIGY_CLIENT_SECRET")
	botID := os.Getenv("COGNIGY_BOT_ID")
	port := os.Getenv("PORT")
	if tenantURL == "" || clientID == "" || clientSecret == "" || botID == "" {
		log.Fatal("Missing required environment variables")
	if port == "" {
		port = "8080"
	cache := NewTokenCache()
	http.HandleFunc("/cognigy/session", handleStudioWebhook(cache, tenantURL, clientID, clientSecret, botID))
	log.Printf("Listening on port %s", port)
	if err := http.ListenAndServe(":"+port, nil); err != nil {
		log.Fatalf("Server failed: %v", err)
  • Cause: Invalid Client ID/Secret, expired token, or missing api scope on the Cognigy application.
  • Fix: Verify credentials in the Cognigy tenant settings. Ensure the OAuth application has the session:manage or api scope enabled. Check that the token cache is not serving an expired token by forcing a refresh.
  • Code Fix: The fetchToken function returns a descriptive error. Log the raw response body from /oauth/token to identify scope restrictions.
Error: 400 Bad Request
  • Cause: Malformed inputs structure, missing botId, or invalid platform string. Cognigy rejects requests where inputs contains non-string values.
  • Fix: Ensure all values in the Inputs map are strings. Convert integers or booleans using fmt.Sprintf("%v", value) before mapping. Verify the botId matches an active bot in Cognigy Studio.
  • Code Fix: The mapStudioToCognigy function enforces string types. Add validation before marshaling if Studio passes dynamic types.
  • Cause: Exceeding Cognigy tenant rate limits (typically 100-200 requests per minute per API key).
  • Fix: The postWithRetry function implements exponential backoff. If failures persist, implement request queuing or increase the Cognigy tenant tier. Add jitter to the delay to prevent thundering herd scenarios.
  • Code Fix: Adjust maxRetries and baseDelay in postWithRetry based on your traffic patterns. Monitor Retry-After headers if Cognigy returns them.
