Treatment usage with SelectDN and SuspsendForDN
Dear all,
in my search for Genesys grail, I found myself using SelectDN and SuspendForDN quite a lot. Unfortunately for me, I cannot figure out a way to fine a list of treatments to be used while my call is queued. Using Target object, all I have to do is just specify the treatment and its length and URS will dutifully route the call from one treatment to next until an operator opens up.
With SelectDN/Suspend combination, I found myself using IVR icon, where I define DN to be used and timeout. Timeout does not really mean much, because the strategy keeps on going…
How can I create a combination of treatments compatible with SelectDN and SuspendDN?
I’m looking at a strategy I wrote several months ago, but never actually implemented. It was successful in testing so it might give you some ideas on solving your dilemna.
  • Use SelectDN in a function block to “choose” a target.
  • Insert a Pause 2 function block. This gives the strategy time (in my situation) to transfer the call to the remote Avaya switch that will be playing the treatment music
  • Insert an IVR treatment block with your treatments. I’m only using 1 treatment block and treatment so I don’t know if you can add multiple treatments in the same block, or if you need to add multiple IVR treatment blocks. My block contains a Route Point (an Avaya VDN that simply plays music and hold messaging). The DURATION of the IVR treatment is 1 second.
  • Next insert a SuspendForDN(999) block to wait until a target is Available (for 999 seconds in this case)
  • Follow that step with a target block to your SelectDN/SuspsendForDN variable
I will try to test some multiple treatment scenarios later today if time allows.
