Transforming Genesys Cloud Knowledge Snippets for Agent Assist with Python SDK
A Python service that constructs, validates, and triggers document transforms for Genesys Cloud Agent Assist, handling chunking, embeddings, webhook synchronization, latency tracking, and audit logging. This tutorial uses the official Genesys Cloud Python SDK to interact with the Knowledge API and Webhooks API. The implementation covers Python 3.9+.
- Genesys Cloud OAuth 2.0 Client Credentials grant type
- Required scopes:
knowledge:document:write,knowledge:document:read,webhook:write genesys-cloud-purecloud-platform-client>=3.0.0python>=3.9- External dependencies:
httpx,pydantic,markdown,uuid,time,logging
The Genesys Cloud Python SDK handles OAuth token acquisition and refresh automatically when initialized with client credentials. Token caching is built into the PureCloudPlatformClientV2 instance.
import os
from genesyscloud.platform.client import PureCloudPlatformClientV2
from genesyscloud.platform.client.auth import OAuthClientCredentialsConfig
def initialize_genesis_client() -> PureCloudPlatformClientV2:
auth_config = OAuthClientCredentialsConfig(
client_id=os.getenv("GENESYS_CLIENT_ID"),
client_secret=os.getenv("GENESYS_CLIENT_SECRET"),
env_name="US_EAST"
client = PureCloudPlatformClientV2(auth_config)
return client
The client maintains an in-memory token cache. The SDK automatically requests a new access token when the current token expires. You do not need to implement manual refresh logic.
Step 1: Construct and Validate Transform Payloads
Genesys Cloud processes knowledge documents using a chunking strategy and an embedding model. The payload must reference a document ID, define a chunking matrix, specify an embedding directive, and respect maximum vector dimension limits. The standard embedding models in Genesys Cloud support a maximum of 1536 dimensions. Exceeding this limit causes a 400 Bad Request.
We use Pydantic to validate the transform schema before submission. This prevents runtime failures and enforces assist engine constraints.
import uuid
from typing import Optional
from pydantic import BaseModel, Field, validator
import markdown
class ChunkingMatrix(BaseModel):
strategy: str = Field(..., description="Chunking strategy: fixed, semantic, or recursive")
max_tokens: int = Field(..., ge=128, le=1024)
overlap_tokens: int = Field(..., ge=0, le=256)
@validator("strategy")
def validate_strategy(cls, v: str) -> str:
allowed = {"fixed", "semantic", "recursive"}
if v not in allowed:
raise ValueError(f"Chunking strategy must be one of {allowed}")
return v
class EmbeddingDirective(BaseModel):
model_id: str = Field(..., description="Embedding model identifier")
max_dimensions: int = Field(default=1536, le=1536)
normalize_vectors: bool = Field(default=True)
class TransformPayload(BaseModel):
document_id: Optional[str] = None
content: str = Field(..., min_length=50)
chunking: ChunkingMatrix
embedding: EmbeddingDirective
metadata: dict = Field(default_factory=dict)
@validator("content")
def validate_markdown_parsing(cls, v: str) -> str:
markdown.markdown(v)
raise ValueError(f"Markdown parsing failed: {str(e)}")
return v
@validator("metadata")
def verify_metadata_preservation(cls, v: dict) -> dict:
required_keys = {"source", "version", "department"}
if not required_keys.issubset(v.keys()):
raise ValueError("Metadata must preserve source, version, and department keys")
return v
def build_transform_payload(content: str, metadata: dict) -> TransformPayload:
chunking_config = ChunkingMatrix(
strategy="semantic",
max_tokens=512,
overlap_tokens=64
embedding_config = EmbeddingDirective(
model_id="genesys-embed-english-v3",
max_dimensions=1536,
normalize_vectors=True
return TransformPayload(
content=content,
chunking=chunking_config,
embedding=embedding_config,
metadata=metadata
The validate_markdown_parsing method ensures the content renders without breaking the assist engine. The verify_metadata_preservation method guarantees context retrieval remains accurate during scaling.
Step 2: Execute Atomic POST Operations with Format Verification
After validation, you submit the document to Genesys Cloud using an atomic POST operation. The Knowledge API accepts the document creation request and returns a document ID. You then trigger processing with the chunking and embedding configuration.
Required scope: knowledge:document:write
import logging
from genesyscloud.knowledge.api import KnowledgeApi
from genesyscloud.knowledge.models import DocumentCreateRequest, DocumentProcessRequest
logger = logging.getLogger("agent_assist_transformer")
def post_knowledge_document_atomic(
client: PureCloudPlatformClientV2,
payload: TransformPayload
) -> str:
knowledge_api = KnowledgeApi(client)
create_request = DocumentCreateRequest(
name=f"assist-snippet-{uuid.uuid4().hex[:8]}",
content=payload.content,
content_type="text/markdown",
metadata=payload.metadata
response = knowledge_api.post_knowledge_document(body=create_request)
logger.info("Document created successfully. ID: %s", response.id)
return response.id
logger.error("Document creation failed: %s", str(e))
raise
def trigger_processing_with_retry(
document_id: str,
payload: TransformPayload,
max_retries: int = 3
) -> None:
process_request = DocumentProcessRequest(
chunking_strategy=payload.chunking.strategy,
chunk_size=payload.chunking.max_tokens,
overlap_size=payload.chunking.overlap_tokens,
embedding_model_id=payload.embedding.model_id
for attempt in range(1, max_retries + 1):
knowledge_api.post_knowledge_document_process(
knowledge_document_id=document_id,
body=process_request
logger.info("Processing triggered for document %s", document_id)
return
if "429" in str(e) and attempt < max_retries:
wait_time = 2 ** attempt
logger.warning("Rate limited (429). Retrying in %s seconds...", wait_time)
time.sleep(wait_time)
else:
logger.error("Processing failed after %s attempts: %s", attempt, str(e))
raise
The post_knowledge_document_atomic function creates the document and captures the ID. The trigger_processing_with_retry function handles 429 rate-limit cascades using exponential backoff. This prevents transform failures during high-volume ingestion.
Step 3: Synchronize Webhooks, Track Metrics, and Generate Audit Logs
Genesys Cloud emits events when chunking completes. You register a webhook to synchronize with an external vector database. The service tracks transforming latency and embedding success rates. Audit logs record every transform event for governance.
Required scope: webhook:write
import httpx
from genesyscloud.webhooks.api import WebhooksApi
from genesyscloud.webhooks.models import WebhookCreateRequest, WebhookRequest
class TransformMetrics:
def __init__(self):
self.latency_samples: list[float] = []
self.success_count: int = 0
self.failure_count: int = 0
def record_latency(self, duration: float) -> None:
self.latency_samples.append(duration)
def record_success(self) -> None:
self.success_count += 1
def record_failure(self) -> None:
self.failure_count += 1
def get_success_rate(self) -> float:
return (self.success_count / total) * 100 if total > 0 else 0.0
def get_avg_latency(self) -> float:
return sum(self.latency_samples) / len(self.latency_samples) if self.latency_samples else 0.0
metrics = TransformMetrics()
audit_log: list[dict] = []
def register_chunk_webhook(client: PureCloudPlatformClientV2, webhook_url: str) -> str:
webhooks_api = WebhooksApi(client)
webhook_request = WebhookRequest(
event_type="knowledge.document.chunk.generated",
target_url=webhook_url,
authentication={
"type": "basic",
"credentials": {
"username": "vector-sync",
"password": "sync-credentials-placeholder"
request_format="json"
create_request = WebhookCreateRequest(
name="agent-assist-chunk-sync",
description="Synchronizes generated chunks to external vector DB",
enabled=True,
request=webhook_request
response = webhooks_api.post_webhook(body=create_request)
logger.info("Webhook registered: %s", response.id)
audit_log.append({
"action": "webhook_registered",
"webhook_id": response.id,
"status": "success"
return response.id
logger.error("Webhook registration failed: %s", str(e))
audit_log.append({
"status": "failed",
"error": str(e)
raise
def simulate_external_sync(chunk_data: dict) -> None:
"""Simulates POST to external vector database with format verification."""
with httpx.Client(timeout=10.0) as http_client:
response = http_client.post(
"https://external-vector-db.example.com/api/chunks",
json=chunk_data,
headers={"Content-Type": "application/json"}
response.raise_for_status()
duration = time.perf_counter() - start_time
metrics.record_latency(duration)
metrics.record_success()
audit_log.append({
"action": "chunk_sync",
"chunk_id": chunk_data.get("id"),
"latency_ms": round(duration * 1000, 2),
"status": "success"
logger.info("Chunk synced successfully in %.2fms", duration * 1000)
metrics.record_failure()
audit_log.append({
"status": "failed",
"error": f"HTTP {e.response.status_code}"
logger.error("External sync failed: %s", str(e))
audit_log.append({
"status": "failed",
"error": str(e)
logger.error("External sync error: %s", str(e))
The TransformMetrics class tracks latency and success rates. The register_chunk_webhook function creates a webhook for the knowledge.document.chunk.generated event. The simulate_external_sync function demonstrates how to handle incoming chunk data, verify formats, and log audit events.
The following script combines all components into a single executable module. Replace the environment variables with your credentials before running.
import os
import sys
import logging
import uuid
import httpx
import markdown
return v
return v
return v
def __init__(self):
env_name="US_EAST"
return PureCloudPlatformClientV2(auth_config)
max_tokens=512,
overlap_tokens=64
content=content,
metadata=metadata
def post_knowledge_document_atomic(client: PureCloudPlatformClientV2, payload: TransformPayload) -> str:
return response.id
raise
def trigger_processing_with_retry(client: PureCloudPlatformClientV2, document_id: str, payload: TransformPayload, max_retries: int = 3) -> None:
return
else:
raise
authentication={
"type": "basic",
"credentials": {
enabled=True,
audit_log.append({
"status": "success"
return response.id
audit_log.append({
"status": "failed",
"error": str(e)
raise
json=chunk_data,
audit_log.append({
"status": "success"
audit_log.append({
"status": "failed",
audit_log.append({
"status": "failed",
"error": str(e)
def run_transform_pipeline() -> None:
client = initialize_genesis_client()
sample_content = """
# Product Configuration Guide
## Authentication Setup
Ensure OAuth credentials are valid. The system validates tokens before processing.
## Chunking Strategy
Semantic chunking preserves context boundaries. Fixed chunking splits by token count.
sample_metadata = {
"source": "internal-wiki",
"version": "2.1.0",
"department": "engineering"
payload = build_transform_payload(sample_content, sample_metadata)
logger.info("Payload validated against assist engine constraints")
document_id = post_knowledge_document_atomic(client, payload)
trigger_processing_with_retry(client, document_id, payload)
webhook_url = "https://webhook-test.example.com/genesys/chunks"
register_chunk_webhook(client, webhook_url)
logger.info("Pipeline complete. Metrics: Success Rate: %.2f%%, Avg Latency: %.2fms",
metrics.get_success_rate(), metrics.get_avg_latency())
with open("transform_audit.log", "w") as log_file:
for entry in audit_log:
log_file.write(f"{entry}\n")
logger.critical("Transform pipeline failed: %s", str(e))
sys.exit(1)
Error: 400 Bad Request (Invalid Chunking Configuration)
- What causes it: The chunking strategy or token limits exceed Genesys Cloud engine constraints. The
max_tokensvalue is outside the 128-1024 range, or the strategy string does not matchfixed,semantic, orrecursive. - How to fix it: Verify the
ChunkingMatrixvalues in the payload. Ensure the strategy matches the supported enum. Adjustmax_tokensandoverlap_tokensto stay within engine limits. - Code showing the fix: The Pydantic
validatorinChunkingMatrixenforces bounds before the API call.
- What causes it: Missing or incorrect OAuth scopes. The client credentials lack
knowledge:document:writeorwebhook:write. - How to fix it: Update the OAuth application in the Genesys Cloud admin console. Add the required scopes. Restart the client to refresh the token.
OAuthClientCredentialsConfiginitialization automatically requests the scopes defined in the application configuration. Verify the application settings in the portal.
- What causes it: Excessive POST operations to
/api/v2/knowledge/documentsor/api/v2/knowledge/documents/{id}/process. Genesys Cloud enforces rate limits per tenant and per endpoint. - How to fix it: Implement exponential backoff. The
trigger_processing_with_retryfunction handles this automatically. - Code showing the fix: The retry loop checks for
429in the exception string and sleeps for2 ** attemptseconds before retrying.
Error: 503 Service Unavailable (Processing Queue Full)
- What causes it: The embedding or chunking engine is under heavy load. Document processing is asynchronous and may queue requests.
- How to fix it: Poll the document status using
GET /api/v2/knowledge/documents/{documentId}until the status changes toprocessed. Implement a polling loop with delays. - Code showing the fix: Add a polling function that calls
knowledge_api.get_knowledge_document(knowledge_document_id=document_id)and checksresponse.processing_status.
