Transforming Genesys Cloud EventBridge Payloads to a Custom Domain Schema Using AWS Lambda and Serverless Framework
You will build a Node.js AWS Lambda function that ingests raw Genesys Cloud EventBridge events, validates them against a custom domain schema, enriches them with Genesys Cloud API data, and forwards the normalized payload to a downstream HTTP endpoint. The solution uses the Serverless Framework for infrastructure provisioning and Node.js 18 for the runtime. The tutorial covers JavaScript.
  • AWS CLI configured with IAM permissions to create Lambda functions, EventBridge rules, and CloudWatch logs
  • Node.js 18 or later installed locally
  • Serverless Framework CLI installed globally (npm install -g serverless)
  • Genesys Cloud organization with an active EventBridge integration configured to publish events to your AWS account and region
  • Genesys Cloud OAuth client credentials (Client ID and Client Secret) stored in AWS Secrets Manager or Parameter Store
  • Required Genesys Cloud OAuth scope for enrichment: view:users
Genesys Cloud EventBridge uses AWS EventBridge native event routing. The Lambda function does not consume OAuth tokens to receive events. EventBridge guarantees delivery and signs requests using AWS Signature Version 4. The Lambda function trusts the event source based on the event.source and event.detail-type fields.
When the Lambda function needs to call Genesys Cloud APIs to enrich the payload, it must authenticate using the OAuth 2.0 Client Credentials flow. You will store the Client ID and Client Secret in AWS Secrets Manager. The Lambda function retrieves these secrets at runtime, requests an access token, caches it, and refreshes it before expiration. This pattern prevents token acquisition latency from impacting event processing throughput.
const { SecretsManagerClient, GetSecretValueCommand } = require('@aws-sdk/client-secrets-manager');
const secretsClient = new SecretsManagerClient({ region: 'us-east-1' });
let cachedToken = null;
let tokenExpiry = 0;
async function getGenesysAccessToken() {
  if (cachedToken && Date.now() < tokenExpiry) {
    return cachedToken;
  const secret = await secretsClient.send(
    new GetSecretValueCommand({ SecretId: 'genesys/oauth-credentials' })
  const credentials = JSON.parse(secret.SecretString);
  const response = await axios.post('https://api.mypurecloud.com/oauth/token', new URLSearchParams({
    client_id: credentials.clientId,
    client_secret: credentials.clientSecret
  cachedToken = response.data.access_token;
  tokenExpiry = Date.now() + (response.data.expires_in * 1000) - 60000;
  return cachedToken;
Step 1: Initialize Serverless Project and Configure EventBridge Trigger
You will use the Serverless Framework to define the Lambda function and the EventBridge trigger. The serverless.yml file configures the Node.js 18 runtime, sets a 10-second timeout, and attaches an EventBridge rule that filters for Genesys Cloud events. The rule uses pattern matching on source and detail-type to ensure only relevant events invoke the function.
service: genesys-event-transformer
provider:
  runtime: nodejs18.x
  region: us-east-1
  memorySize: 256
  timeout: 10
  iamRoleStatements:
    - Effect: Allow
      Action:
        - secretsmanager:GetSecretValue
      Resource: arn:aws:secretsmanager:us-east-1:ACCOUNT_ID:secret:genesys/oauth-credentials-*
functions:
  transformEvent:
    handler: handler.transformEvent
    events:
      - eventBridge:
          eventBus: default
          pattern:
            source:
              - genesys.cloud
            detail-type:
              - Genesys Cloud Event
The iamRoleStatements block grants the Lambda execution role permission to read the OAuth credentials. You will replace ACCOUNT_ID with your actual AWS account identifier. The event pattern ensures the function only processes Genesys Cloud events, reducing cold start waste.
Step 2: Parse Genesys Cloud Event Structure and Extract Domain Data
Genesys Cloud EventBridge payloads follow a standardized AWS EventBridge envelope. The actual Genesys data resides in the detail.data object. You must validate the envelope structure before attempting transformation. This step extracts the core event metadata and the raw Genesys payload while handling malformed inputs gracefully.
const { z } = require('zod');
const EventBridgeEnvelopeSchema = z.object({
  version: z.string(),
  'detail-type': z.string(),
  source: z.string(),
  account: z.string(),
  time: z.string(),
  region: z.string(),
  resources: z.array(z.string()),
  detail: z.object({
    eventType: z.string(),
    data: z.record(z.unknown())
async function parseEvent(event) {
  const result = EventBridgeEnvelopeSchema.safeParse(event);
  if (!result.success) {
    throw new Error(`Invalid EventBridge envelope: ${result.error.message}`);
  const { source, 'detail-type': detailType, time, id } = event;
  const { eventType, data } = event.detail;
    metadata: { source, detailType, time, id, eventType },
    genesysPayload: data
The Zod schema validates the envelope structure at runtime. If the payload deviates from the expected structure, the function throws a structured error that CloudWatch Logs will capture. You will use this parsed structure as the foundation for the transformation logic.
Step 3: Apply Custom Schema Transformation and Validation
You will define a custom domain schema that represents your downstream system requirements. This example normalizes a Genesys Cloud CONVERSATION_CREATED event into a unified interaction schema. The transformation extracts caller information, channel type, and timestamp, then validates the result against the custom schema.
const CustomInteractionSchema = z.object({
  interactionId: z.string(),
  channelId: z.string(),
  externalContact: z.object({
    phone: z.string().optional(),
    email: z.string().optional()
  initiatedAt: z.string().datetime(),
  sourceSystem: z.literal('genesys-cloud')
function transformToCustomSchema(parsedEvent) {
  const { metadata, genesysPayload } = parsedEvent;
  const { interactions, channels } = genesysPayload;
  if (!interactions || interactions.length === 0) {
    throw new Error('Missing interactions array in Genesys payload');
  const primaryInteraction = interactions[0];
  const channel = channels?.find(c => c.id === primaryInteraction.channelId);
  const transformed = {
    interactionId: primaryInteraction.id,
    channelId: primaryInteraction.channelId,
    externalContact: {
      phone: channel?.address?.phone,
      email: channel?.address?.email
    initiatedAt: primaryInteraction.createdTimestamp,
    sourceSystem: 'genesys-cloud'
  const validation = CustomInteractionSchema.safeParse(transformed);
  if (!validation.success) {
    throw new Error(`Custom schema validation failed: ${validation.error.message}`);
  return validation.data;
The transformation logic isolates the primary interaction and resolves the associated channel address. You must handle missing channel data gracefully, which the optional chaining operator accomplishes. The Zod validation ensures the downstream system receives strictly typed data. This prevents schema drift and eliminates runtime type errors in the consumer service.
Step 4: Enrich with Genesys Cloud API and Dispatch to Downstream Service
You will enrich the normalized payload with Genesys Cloud user details by calling the /api/v2/users/{id} endpoint. This call requires the view:users OAuth scope. After enrichment, the function dispatches the payload to a downstream HTTP endpoint. You will implement retry logic for 429 rate limits and explicit error handling for 401, 403, and 5xx responses.
async function enrichAndDispatch(transformedPayload, parsedEvent) {
  const token = await getGenesysAccessToken();
  const { genesysPayload } = parsedEvent;
  const userId = genesysPayload.routing?.queueConversation?.routingData?.assignedToId;
  let enrichedUser = null;
  if (userId) {
      const userResponse = await axios.get(`https://api.mypurecloud.com/api/v2/users/${userId}`, {
        headers: { Authorization: `Bearer ${token}` }
      enrichedUser = {
        email: userResponse.data.email
    } catch (error) {
        const retryAfter = parseInt(error.headers['retry-after'] || '5', 10);
        console.warn(`Rate limited on user enrichment. Retrying after ${retryAfter}s`);
        await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
        const retryResponse = await axios.get(`https://api.mypurecloud.com/api/v2/users/${userId}`, {
        enrichedUser = {
          email: retryResponse.data.email
      } else if (error.response?.status === 401 || error.response?.status === 403) {
        console.error(`OAuth error ${error.response.status}: ${error.message}`);
        throw new Error('Failed to authenticate with Genesys Cloud API');
      } else {
        console.error(`Genesys API error: ${error.message}`);
  const finalPayload = {
    ...transformedPayload,
    assignedAgent: enrichedUser,
    processedAt: new Date().toISOString()
  const downstreamUrl = process.env.DOWNSTREAM_ENDPOINT;
    await axios.post(downstreamUrl, finalPayload, {
      timeout: 5000
  } catch (error) {
      console.warn('Downstream service rate limited. Event queued for retry.');
      throw new Error('Downstream 429: Event deferred');
    } else if (error.response?.status >= 500) {
      console.error(`Downstream 5xx error: ${error.message}`);
      throw new Error('Downstream server error');
    } else {
      console.error(`Downstream request failed: ${error.message}`);
      throw new Error('Downstream dispatch failed');
The enrichment block retrieves the assigned agent details using the view:users scope. The retry logic handles 429 responses by reading the Retry-After header and pausing execution. Authentication failures (401/403) throw immediately because they indicate misconfigured credentials or expired tokens. The dispatch block forwards the final payload to the downstream endpoint and handles transient failures explicitly.
The following files constitute a complete, deployable solution. You will create a new directory, initialize a Node.js project, install dependencies, and paste these files. You will replace ACCOUNT_ID in serverless.yml and configure the DOWNSTREAM_ENDPOINT environment variable in your AWS Lambda console or Serverless secrets configuration.
package.json
  "name": "genesys-event-transformer",
  "version": "1.0.0",
  "dependencies": {
    "@aws-sdk/client-secrets-manager": "^3.450.0",
    "axios": "^1.6.0",
    "zod": "^3.22.4"
  "devDependencies": {
    "serverless": "^3.38.0"
serverless.yml
provider:
  runtime: nodejs18.x
  region: us-east-1
  memorySize: 256
  timeout: 10
  environment:
    DOWNSTREAM_ENDPOINT: ${ssm:/genesys/downstream-endpoint}
  iamRoleStatements:
    - Effect: Allow
      Action:
    - Effect: Allow
      Action:
        - ssm:GetParameter
      Resource: arn:aws:ssm:us-east-1:ACCOUNT_ID:parameter/genesys/downstream-endpoint
functions:
  transformEvent:
    events:
      - eventBridge:
          eventBus: default
          pattern:
            source:
              - genesys.cloud
            detail-type:
handler.js
  source: z.string(),
  time: z.string(),
  region: z.string(),
  detail: z.object({
    return cachedToken;
  return cachedToken;
    externalContact: {
  if (userId) {
      enrichedUser = {
    } catch (error) {
        enrichedUser = {
      } else {
      timeout: 5000
  } catch (error) {
    } else {
exports.transformEvent = async (event, context) => {
    const parsed = await parseEvent(event);
    const transformed = transformToCustomSchema(parsed);
    await enrichAndDispatch(transformed, parsed);
    return { statusCode: 200, body: JSON.stringify({ message: 'Event processed successfully' }) };
  } catch (error) {
    console.error('Transformation pipeline failed:', error);
    return { statusCode: 500, body: JSON.stringify({ error: error.message }) };
Deploy the function by running serverless deploy. The Serverless Framework provisions the IAM role, EventBridge rule, and Lambda function. Test the deployment by publishing a test event from the Genesys Cloud EventBridge integration console or by invoking the Lambda directly with a sample EventBridge payload.
Error: 401 Unauthorized or 403 Forbidden on Genesys Cloud API
  • Cause: The OAuth client credentials stored in Secrets Manager are incorrect, the client lacks the view:users scope, or the token has expired.
  • Fix: Verify the Client ID and Client Secret match a Genesys Cloud OAuth client with the view:users scope. Check CloudWatch Logs for the exact error message. Regenerate the client secret if compromised. Ensure the token caching logic subtracts a buffer period before expiration.
  • Code showing the fix: The getGenesysAccessToken function already implements token caching with a 60-second buffer. If you encounter persistent 401 errors, clear the cachedToken variable in the Lambda execution context or restart the function.
Error: 429 Too Many Requests on Genesys Cloud or Downstream Endpoint
  • Cause: Event volume exceeds the Genesys Cloud API rate limit or the downstream service rate limit.
  • Fix: Implement exponential backoff with jitter instead of fixed retry intervals. The current code uses the Retry-After header for Genesys Cloud calls. For downstream services, you must configure an SQS dead-letter queue in the Serverless Framework to capture failed events and retry them asynchronously.
  • Code showing the fix: Add retry: { retries: 3, backoff: 1000 } to the axios configuration object, or implement a custom backoff function that multiplies the delay by a random factor between 0.5 and 1.5.
Error: Invalid EventBridge envelope or Custom schema validation failed
  • Cause: Genesys Cloud published a payload with a different eventType structure, or the downstream schema requirements changed.
  • Fix: Update the Zod schemas to match the actual Genesys Cloud event structure. Use CloudWatch Logs to inspect the raw event object. Add conditional logic to route different eventType values to separate transformation functions.
  • Code showing the fix: Modify transformToCustomSchema to check parsedEvent.metadata.eventType and delegate to specialized transformation handlers. Log the raw payload structure when validation fails to accelerate debugging.
