Transferring Genesys Cloud Calls Programmatically with C# Client SDK
  • A C# service that executes call transfers using the Genesys Cloud Client SDK with full payload construction, target validation, and state management.
  • This implementation uses the PureCloudPlatformClientV2 SDK and the TransferApi (/api/v2/floors/{floorId}/transfers) endpoint.
  • This tutorial covers C# 10+ running on .NET 6 or later.
  • OAuth 2.0 Client Credentials flow configured with transfer:write, floor:read, user:read, routing:read, and webhook:write scopes.
  • PureCloudPlatformClientV2 NuGet package version 125.0.0 or later.
  • .NET 6 SDK or .NET 7/8 runtime.
  • Microsoft.Extensions.Logging.Abstractions and System.Text.Json for structured logging and serialization.
  • An active Genesys Cloud organization with configured routing queues, announcement files, and valid floor identifiers.
The Genesys Cloud Client SDK requires a PlatformClient instance bound to a Configuration object. The ClientCredentialsAuthenticator handles token acquisition and automatic refresh. Token caching occurs automatically within the authenticator instance, but you must ensure the same PlatformClient instance is reused across operations to maintain session state.
using PureCloudPlatform.Client.V2.Api;
using PureCloudPlatform.Client.V2.Client;
using PureCloudPlatform.Client.V2.Model;
using System;
using System.Net.Http;
using System.Threading.Tasks;
public class GenesysAuthenticator
    private readonly PlatformClient _platformClient;
    private readonly string _clientId;
    private readonly string _clientSecret;
    private readonly string _environment;
    public GenesysAuthenticator(string clientId, string clientSecret, string environment = "us")
        _clientId = clientId;
        _clientSecret = clientSecret;
        _environment = environment;
        var basePath = environment switch
            "eu" => "https://api.eu.mypurecloud.com",
            "au" => "https://api.ap.mypurecloud.com",
            _ => "https://api.mypurecloud.com"
        _platformClient = new PlatformClient(new Configuration
            BasePath = basePath,
            OAuthBasePath = $"https://login.{environment == "us" ? "" : $"{environment}."}mypurecloud.com"
    public async Task InitializeAsync()
        _platformClient.Authenticator = new ClientCredentialsAuthenticator(
            _platformClient.Configuration,
            _clientId,
            _clientSecret);
        await _platformClient.Authenticator.AuthenticateAsync();
    public PlatformClient GetClient() => _platformClient;
OAuth Scopes Required: transfer:write, floor:read
HTTP Equivalent: POST https://login.mypurecloud.com/oauth/token with grant_type=client_credentials
Step 1: Transfer Payload Construction & Schema Validation
The CreateTransferRequest object defines the transfer destination, type, and announcement directives. Genesys Cloud enforces server-side constraints on transfer chain length (typically three to four hops per conversation). You must validate the payload schema and track chain length before submission to prevent 400 Bad Request responses.
using System.Text.Json;
using System.Text.Json.Serialization;
public class TransferPayloadBuilder
    private readonly CreateTransferRequest _request = new();
    private readonly int _maxTransferChainLength;
    public TransferPayloadBuilder(int maxTransferChainLength = 3)
        _maxTransferChainLength = maxTransferChainLength;
    public TransferPayloadBuilder WithDestination(string userId = null, string queueId = null, string number = null)
        if (!string.IsNullOrEmpty(userId)) _request.Destination = userId;
        else if (!string.IsNullOrEmpty(queueId)) _request.Destination = queueId;
        else if (!string.IsNullOrEmpty(number)) _request.Destination = number;
        else throw new ArgumentException("At least one destination reference must be provided.");
        return this;
    public TransferPayloadBuilder WithTransferType(string transferType)
        var validTypes = new[] { "attended", "blind", "supervised" };
        if (!validTypes.Contains(transferType))
            throw new ArgumentException($"Invalid transfer type. Must be one of: {string.Join(", ", validTypes)}");
        _request.TransferType = transferType;
        return this;
    public TransferPayloadBuilder WithAnnouncement(string announcementId)
        if (string.IsNullOrWhiteSpace(announcementId)) return this;
        _request.AnnouncementId = announcementId;
        return this;
    public CreateTransferRequest Build(int currentChainLength)
        if (currentChainLength >= _maxTransferChainLength)
            throw new InvalidOperationException($"Maximum transfer chain length {_maxTransferChainLength} exceeded.");
        if (_request.Destination == null)
            throw new InvalidOperationException("Destination reference is required.");
        return _request;
Expected Response Structure (Validation Success):
The builder returns a CreateTransferRequest instance. Serialization produces a valid JSON payload matching the call control engine schema.
  "destination": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
  "transferType": "attended",
  "announcementId": "98765432-1234-5678-90ab-cdef12345678",
  "reasonCodeId": null
Error Handling:
  • 400 Bad Request: Invalid destination format or missing required fields. The builder throws InvalidOperationException before the API call.
  • 422 Unprocessable Entity: Announcement ID does not exist or is not published. Verify the announcement lifecycle status in the organization.
Step 2: Target Availability & Ring Group Compliance Verification
Before initiating a transfer, you must verify target presence and routing compliance. Orphaned calls occur when transfers target offline users or queues with disabled routing strategies. The validation pipeline checks user status and queue configuration.
using System.Collections.Generic;
using System.Linq;
public class TransferValidator
    private readonly UsersApi _usersApi;
    private readonly RoutingApi _routingApi;
    public TransferValidator(PlatformClient client)
        _usersApi = new UsersApi(client);
        _routingApi = new RoutingApi(client);
    public async Task<bool> ValidateTargetAsync(string destinationId, string destinationType)
        switch (destinationType.ToLower())
            case "user":
                return await ValidateUserAvailabilityAsync(destinationId);
            case "queue":
                return await ValidateQueueComplianceAsync(destinationId);
            case "number":
                return true; // External number validation occurs at connection time
            default:
                return false;
    private async Task<bool> ValidateUserAvailabilityAsync(string userId)
        try
            var status = await _usersApi.GetUserStatusAsync(userId);
            // User must be online or in a transfer-capable state
            return status?.State?.Name != null &&
                   !status.State.Name.Equals("Offline", StringComparison.OrdinalIgnoreCase);
        catch (ApiException ex) when (ex.ErrorCode == 404)
            return false;
    private async Task<bool> ValidateQueueComplianceAsync(string queueId)
        try
            var queue = await _routingApi.GetRoutingQueueAsync(queueId);
            // Queue must have an active routing strategy and enabled status
            return queue?.Enabled == true &&
                   queue?.RoutingStrategy != null &&
                   !queue.RoutingStrategy.Equals("disabled", StringComparison.OrdinalIgnoreCase);
        catch (ApiException ex) when (ex.ErrorCode == 404 || ex.ErrorCode == 403)
            return false;
OAuth Scopes Required: user:read, routing:read
HTTP Equivalent: GET /api/v2/users/{userId}/status and GET /api/v2/routing/queues/{queueId}
Error Handling:
  • 403 Forbidden: Insufficient permissions to read user or queue data. Verify the OAuth token includes user:read and routing:read.
  • 404 Not Found: Target identifier does not exist. The validation method returns false to prevent the transfer.
Step 3: Atomic Transfer Execution & State Transition
The transfer operation must be atomic. You will wrap the API call in a retry mechanism for rate limits, track latency, and verify the response format. The SDK handles state transition triggers automatically when the transfer succeeds.
using System.Diagnostics;
using System.Net;
public class CallTransferor
    private readonly TransferApi _transferApi;
    private readonly TransferValidator _validator;
    private readonly ILogger<CallTransferor> _logger;
    private readonly int _maxRetries;
    public CallTransferor(PlatformClient client, ILogger<CallTransferor> logger, int maxRetries = 3)
        _transferApi = new TransferApi(client);
        _validator = new TransferValidator(client);
        _logger = logger;
        _maxRetries = maxRetries;
    public async Task<TransferResult> ExecuteTransferAsync(
        string floorId,
        string destinationType,
        string transferType,
        string announcementId = null,
        int currentChainLength = 0)
        var stopwatch = Stopwatch.StartNew();
        var payload = new TransferPayloadBuilder()
            .WithDestination(userId: destinationType == "user" ? destinationId : null,
                             queueId: destinationType == "queue" ? destinationId : null,
                             number: destinationType == "number" ? destinationId : null)
            .WithTransferType(transferType)
            .WithAnnouncement(announcementId)
            .Build(currentChainLength);
        bool isValid = await _validator.ValidateTargetAsync(destinationId, destinationType);
        if (!isValid)
            _logger.LogWarning("Transfer validation failed for destination {DestinationId} of type {DestinationType}",
            return new TransferResult { Success = false, Error = "Target unavailable or non-compliant", LatencyMs = stopwatch.ElapsedMilliseconds };
        var retries = 0;
        while (retries < _maxRetries)
            try
                var response = await _transferApi.PostFloorTransfersAsync(floorId, payload);
                stopwatch.Stop();
                _logger.LogInformation("Transfer executed successfully. FloorId: {FloorId}, Latency: {Latency}ms",
                    floorId, stopwatch.ElapsedMilliseconds);
                    Success = true,
                    TransferId = response.Id,
                    LatencyMs = stopwatch.ElapsedMilliseconds,
                    ConnectionEstablished = true
            catch (ApiException ex) when (ex.ErrorCode == (int)HttpStatusCode.TooManyRequests)
                retries++;
                var delay = TimeSpan.FromSeconds(Math.Pow(2, retries));
                _logger.LogWarning("Rate limited (429). Retrying in {Delay}s. Attempt {Attempt}/{Max}",
                    delay.TotalSeconds, retries, _maxRetries);
                await Task.Delay(delay);
                stopwatch.Stop();
                _logger.LogError(ex, "Transfer failed with HTTP {ErrorCode}: {Message}", ex.ErrorCode, ex.Message);
                return new TransferResult { Success = false, Error = ex.Message, LatencyMs = stopwatch.ElapsedMilliseconds };
        return new TransferResult { Success = false, Error = "Max retry limit exceeded", LatencyMs = stopwatch.ElapsedMilliseconds };
public record TransferResult
    public bool Success { get; init; }
    public string TransferId { get; init; }
    public string Error { get; init; }
    public long LatencyMs { get; init; }
    public bool ConnectionEstablished { get; init; }
HTTP Equivalent: POST /api/v2/floors/{floorId}/transfers
Expected Response:
  "id": "transfer-12345-abcde",
  "status": "initiated",
  "timestamp": "2024-01-15T10:30:00Z"
Error Handling:
  • 401 Unauthorized: Token expired or invalid. The authenticator refreshes automatically, but persistent failures require re-authentication.
  • 403 Forbidden: Missing transfer:write scope or floor ID does not belong to the calling application.
  • 429 Too Many Requests: Handled via exponential backoff in the retry loop.
Step 4: Webhook Synchronization & Audit Logging
External call logs require event synchronization. You will register a webhook for transfer:created and conversation:participant:updated events. The audit pipeline records latency, connection rates, and governance metadata.
public class TransferEventSync
    private readonly WebhookApi _webhookApi;
    private readonly ILogger<TransferEventSync> _logger;
    public TransferEventSync(PlatformClient client, ILogger<TransferEventSync> logger)
        _webhookApi = new WebhookApi(client);
        _logger = logger;
    public async Task<string> RegisterTransferWebhookAsync(string callbackUrl, string orgId)
        var webhookRequest = new WebhookRequest
            Name = $"TransferAuditWebhook_{orgId}",
            Description = "Synchronizes transfer events with external call logs",
            Enabled = true,
            DeliveryMode = "stream",
            Events = new List<string>
                "transfer:created",
                "transfer:updated",
                "conversation:participant:updated"
            Address = callbackUrl,
            RetryInterval = "PT1M",
            RetryLimit = 5,
            Authentication = new WebhookAuthentication
                Type = "bearer",
                Credentials = new Dictionary<string, string>
                    { "Authorization", "Bearer EXTERNAL_WEBHOOK_TOKEN" }
        try
            var response = await _webhookApi.PostWebhookAsync(webhookRequest);
            _logger.LogInformation("Webhook registered successfully. Id: {WebhookId}", response.Id);
            return response.Id;
            _logger.LogError(ex, "Failed to register webhook. Error: {Message}", ex.Message);
            throw;
public static class AuditLogger
    public static void LogTransferAudit(ILogger logger, TransferResult result, string floorId, string destinationId)
        var auditEntry = new
            Timestamp = DateTime.UtcNow,
            FloorId = floorId,
            DestinationId = destinationId,
            Success = result.Success,
            TransferId = result.TransferId,
            LatencyMs = result.LatencyMs,
            ConnectionEstablished = result.ConnectionEstablished,
            Error = result.Error
        logger.LogInformation("AUDIT_TRANSFER: {@AuditEntry}", auditEntry);
OAuth Scopes Required: webhook:write
HTTP Equivalent: POST /api/v2/webhooks
Error Handling:
  • 400 Bad Request: Invalid callback URL format or unsupported event type. Verify the webhook address is publicly reachable.
  • 409 Conflict: Webhook with the same name and address already exists. Implement idempotency checks in production.
The following console application demonstrates the complete transfer workflow. Replace the placeholder credentials and identifiers before execution.
using Microsoft.Extensions.Logging;
using System;
namespace GenesysTransferDemo
    class Program
        static async Task Main(string[] args)
            var loggerFactory = LoggerFactory.Create(builder => builder.AddConsole());
            var logger = loggerFactory.CreateLogger<Program>();
            var clientId = "YOUR_CLIENT_ID";
            var clientSecret = "YOUR_CLIENT_SECRET";
            var environment = "us";
            var floorId = "YOUR_FLOOR_ID";
            var destinationId = "TARGET_USER_OR_QUEUE_ID";
            var destinationType = "user";
            var transferType = "attended";
            var announcementId = "YOUR_ANNOUNCEMENT_ID";
            var webhookUrl = "https://your-external-endpoint.com/webhooks/transfers";
            try
                // 1. Authenticate
                var auth = new GenesysAuthenticator(clientId, clientSecret, environment);
                await auth.InitializeAsync();
                var client = auth.GetClient();
                // 2. Register Webhook for Event Sync
                var sync = new TransferEventSync(client, logger);
                await sync.RegisterTransferWebhookAsync(webhookUrl, "ORG_ID");
                // 3. Execute Transfer
                var transferor = new CallTransferor(client, logger);
                var result = await transferor.ExecuteTransferAsync(
                    floorId: floorId,
                    destinationId: destinationId,
                    destinationType: destinationType,
                    transferType: transferType,
                    announcementId: announcementId,
                    currentChainLength: 1
                // 4. Audit Logging
                AuditLogger.LogTransferAudit(logger, result, floorId, destinationId);
                if (result.Success)
                    Console.WriteLine($"Transfer completed successfully. ID: {result.TransferId}, Latency: {result.LatencyMs}ms");
                else
                    Console.WriteLine($"Transfer failed: {result.Error}");
            catch (Exception ex)
                logger.LogError(ex, "Fatal error during transfer execution");
                Console.WriteLine($"Fatal error: {ex.Message}");
  • Cause: The OAuth token has expired, the client credentials are incorrect, or the token was revoked.
  • Fix: Verify clientId and clientSecret. Ensure the ClientCredentialsAuthenticator is reused across the application lifecycle. The SDK refreshes tokens automatically, but network timeouts during refresh can cause transient 401s. Implement a token cache invalidation check if you observe repeated failures.
  • Code Fix: Wrap the authenticator initialization in a retry block or verify network connectivity to login.mypurecloud.com.
Error: 403 Forbidden
  • Cause: The OAuth token lacks the required scope (transfer:write or floor:read), or the calling application does not have permissions on the specified floor.
  • Fix: Update the OAuth client configuration in the Genesys Cloud administration console to include transfer:write. Verify the floor ID belongs to an organization unit accessible by the service account.
  • Code Fix: Log the token scopes using _platformClient.Authenticator.TokenResponse to confirm scope inclusion before execution.
  • Cause: The application exceeded the Genesys Cloud API rate limit for transfer operations or concurrent authentication requests.
  • Fix: The CallTransferor class implements exponential backoff. If failures persist, reduce the transfer batch size or implement a token bucket rate limiter on the client side.
  • Code Fix: Increase _maxRetries or adjust the delay calculation to Math.Pow(2, retries) + TimeSpan.FromMilliseconds(Random.Shared.Next(100, 500)) for jitter.
Error: 400 Bad Request (Invalid Destination)
  • Cause: The destination ID format does not match a valid user, queue, or telephone number, or the transfer chain length exceeds the engine limit.
  • Fix: Validate identifiers using the TransferValidator before submission. Ensure currentChainLength is tracked accurately across transfer iterations.
  • Code Fix: Add a regex validator for telephone numbers if using destinationType == "number".
