Transcribing NICE CXone Pure Connect IVR Menus via Speech APIs with Python
  • This tutorial builds a Python service that extracts audio from CXone IVR menu nodes, validates media constraints, submits atomic transcription jobs, and aggregates speech-to-text results with webhook synchronization.
  • It uses the NICE CXone Speech API and the nice_cxone_platform_sdk Python package.
  • The implementation covers Python 3.9+ with strict type hints, production-ready error handling, and automated audit logging.
  • OAuth 2.0 client credentials with scopes: speech:transcriptions:write, speech:transcriptions:read, pureconnect:menus:read
  • CXone API version: v2
  • Python runtime: 3.9 or higher
  • External dependencies: nice_cxone_platform_sdk>=3.0.0, httpx>=0.25.0, pydantic>=2.5.0, python-dotenv>=1.0.0, structlog>=23.0.0
The CXone Python SDK handles token acquisition and refresh automatically when initialized with client credentials. You must configure the environment to point to your CXone deployment region.
import os
from nice_cxone_platform_sdk.client import ApiClient
from nice_cxone_platform_sdk.core import Configuration
def init_cxone_client() -> ApiClient:
    """Initialize the CXone API client with OAuth2 client credentials flow."""
    config = Configuration(
        client_id=os.getenv("CXONE_CLIENT_ID"),
        client_secret=os.getenv("CXONE_CLIENT_SECRET"),
        environment=os.getenv("CXONE_ENVIRONMENT", "mypurecloud.com"),
        scopes=["speech:transcriptions:write", "speech:transcriptions:read", "pureconnect:menus:read"]
    client = ApiClient(config)
    # Force initial token acquisition to catch configuration errors early
    client.get_access_token()
    return client
The SDK caches the access token in memory and automatically requests a new token before expiration. You do not need to implement manual refresh logic. If the token refresh fails, the SDK raises an AuthenticationError that you must handle in your retry pipeline.
Step 1: Validate Media Constraints and Language Codes
Before submitting audio for transcription, you must verify that the file meets CXone media constraints. The Speech API rejects payloads that exceed maximum duration limits, use unsupported sample rates, or specify invalid language codes.
from pydantic import BaseModel, ValidationError, field_validator
import wave
class AudioConstraint(BaseModel):
    """Validates audio metadata against CXone Speech API constraints."""
    max_duration_seconds: int = 1800  # 30 minutes max per job
    allowed_formats: List[str] = ["wav", "mp3", "ogg", "flac"]
    allowed_sample_rates: List[int] = [8000, 16000, 24000, 48000]
    allowed_language_codes: List[str] = ["en-US", "en-GB", "es-ES", "fr-FR", "de-DE"]
    @field_validator("max_duration_seconds")
    @classmethod
    def validate_duration(cls, v: int) -> int:
        if v > 3600:
            raise ValueError("Maximum duration cannot exceed 3600 seconds.")
        return v
def validate_audio_file(filepath: str, language_code: str) -> Dict[str, Any]:
    """Extract and validate audio properties before transcription submission."""
    constraints = AudioConstraint()
    if not filepath.lower().endswith(tuple(constraints.allowed_formats)):
        raise ValueError(f"Unsupported audio format. Allowed: {constraints.allowed_formats}")
    sample_rate = None
    duration_seconds = 0.0
    if filepath.lower().endswith(".wav"):
        with wave.open(filepath, "rb") as wf:
            sample_rate = wf.getframerate()
            duration_seconds = wf.getnframes() / sample_rate
    if sample_rate and sample_rate not in constraints.allowed_sample_rates:
        raise ValueError(f"Unsupported sample rate: {sample_rate} Hz. Allowed: {constraints.allowed_sample_rates}")
    if duration_seconds > constraints.max_duration_seconds:
        raise ValueError(f"Audio duration {duration_seconds:.2f}s exceeds maximum limit of {constraints.max_duration_seconds}s.")
    if language_code not in constraints.allowed_language_codes:
        raise ValueError(f"Invalid language code: {language_code}. Allowed: {constraints.allowed_language_codes}")
        "format": filepath.split(".")[-1].lower(),
        "sample_rate": sample_rate,
        "duration_seconds": duration_seconds,
        "language_code": language_code
Step 2: Construct Transcription Payload with Menu References
The CXone Speech API accepts a structured payload that maps IVR menu nodes to audio segments. You must include a convert directive to trigger automatic audio normalization, and a node_matrix to define how transcription results map back to menu navigation paths.
from nice_cxone_platform_sdk.model.transcription_create_request import TranscriptionCreateRequest
from nice_cxone_platform_sdk.model.transcription_audio import TranscriptionAudio
def build_transcription_payload(
    audio_url: str,
    menu_id: str,
    node_matrix: Dict[str, Any],
    language_code: str,
    webhook_url: str,
    format_info: Dict[str, Any]
) -> dict:
    """Construct the atomic transcription request payload."""
    # CXone SDK model instantiation
    audio_config = TranscriptionAudio(
        source=audio_url,
        format=format_info["format"],
        metadata={
            "menu_id": menu_id,
            "node_matrix": node_matrix,
            "convert": True,  # Triggers automatic audio normalization and segment merge
            "sample_rate": format_info.get("sample_rate"),
            "duration_seconds": format_info.get("duration_seconds")
    payload = {
        "audio": audio_config,
        "language_code": language_code,
        "webhook_url": webhook_url,
        "metadata": {
            "menu_references": {
                "id": menu_id,
                "type": "pureconnect_ivr_menu",
                "version": "v2"
            "processing_directives": {
                "convert": True,
                "merge_segments": True,
                "force_language": language_code
            "audit_trail": {
                "submitted_at": datetime.now(timezone.utc).isoformat(),
                "request_id": f"trn_{menu_id}_{int(datetime.now(timezone.utc).timestamp())}"
    return payload
Step 3: Submit Atomic POST Request with Format Verification
You must submit the payload via an atomic POST operation. The CXone Speech API enforces strict format verification at the request boundary. You must implement retry logic for 429 Too Many Requests and handle 400 Bad Request schema validation failures.
import httpx
import structlog
class TranscriptionSubmitter:
    def __init__(self, client: ApiClient, base_url: str):
        self.client = client
        self.http = httpx.Client(
            headers={"Content-Type": "application/json"},
            timeout=30.0,
            transport=httpx.HTTPTransport(retries=2)
    def submit_transcription(self, payload: dict) -> dict:
        """Submit atomic POST request with 429 retry logic and format verification."""
        url = f"{self.base_url}/api/v2/speech/transcriptions"
        token = self.client.get_access_token()
        headers = {
        max_retries = 3
        retry_delay = 2
            start_time = time.time()
                response = self.http.post(url, headers=headers, json=payload)
                if response.status_code == 201:
                    logger.info(
                        "transcription_submitted",
                        job_id=response.json().get("id"),
                        latency_ms=latency_ms
                    return response.json()
                elif response.status_code == 429:
                    retry_after = int(response.headers.get("Retry-After", retry_delay))
                    logger.warning("rate_limit_hit", retry_after=retry_after, attempt=attempt + 1)
                    time.sleep(retry_after)
                elif response.status_code == 400:
                    logger.error(
                        "format_verification_failed",
                        error_detail=response.json().get("detail"),
                        payload_metadata=payload.get("metadata")
                    raise ValueError(f"Schema validation failed: {response.json().get('detail')}")
                else:
                    response.raise_for_status()
                if e.response.status_code >= 500:
                    logger.warning("server_error_retrying", status=e.response.status_code, attempt=attempt + 1)
                    time.sleep(retry_delay * (attempt + 1))
                else:
                    raise
        raise RuntimeError("Maximum retry attempts exceeded for transcription submission.")
Step 4: Synchronize Events, Track Metrics, and Generate Audit Logs
After submission, you must track latency, calculate convert success rates, and log audit events for media governance. The webhook URL receives asynchronous completion events. You must parse these events to trigger segment merge finalization and update external accessibility tools.
from typing import Optional
@dataclass
class TranscriptionMetrics:
    """Tracks latency and success rates for transcribe efficiency."""
    total_submissions: int = 0
    successful_conversions: int = 0
    failed_validations: int = 0
    total_latency_ms: float = 0.0
    def record_submission(self, success: bool, latency_ms: float) -> None:
        self.total_submissions += 1
        self.total_latency_ms += latency_ms
        if success:
            self.successful_conversions += 1
        else:
            self.failed_validations += 1
    def get_success_rate(self) -> float:
        if self.total_submissions == 0:
            return 0.0
        return (self.successful_conversions / self.total_submissions) * 100.0
    def get_avg_latency(self) -> float:
            return 0.0
        return self.total_latency_ms / self.total_submissions
def process_webhook_event(event_payload: dict, metrics: TranscriptionMetrics) -> dict:
    """Synchronize transcription events with external accessibility tools."""
    status = event_payload.get("status", "")
    job_id = event_payload.get("id", "")
    menu_id = event_payload.get("metadata", {}).get("menu_id", "unknown")
    audit_entry = {
        "event_type": event_payload.get("type", "webhook"),
        "job_id": job_id,
        "menu_id": menu_id,
        "status": status,
        "timestamp": event_payload.get("timestamp", datetime.now(timezone.utc).isoformat()),
        "transcript_segments": event_payload.get("result", {}).get("segments", []),
        "convert_applied": event_payload.get("metadata", {}).get("convert", False)
    if status in ["completed", "success"]:
        metrics.record_submission(success=True, latency_ms=0.0)
        logger.info(
            "transcription_completed",
            job_id=job_id,
            menu_id=menu_id,
            segments_count=len(audit_entry["transcript_segments"]),
            success_rate=metrics.get_success_rate()
        # Trigger automatic segment merge finalization
        if event_payload.get("metadata", {}).get("merge_segments"):
            audit_entry["merge_status"] = "finalized"
    elif status in ["failed", "error"]:
        metrics.record_submission(success=False, latency_ms=0.0)
        logger.error(
            "transcription_failed",
            job_id=job_id,
            error_detail=event_payload.get("error", "Unknown failure")
        audit_entry["governance_flag"] = "requires_review"
    return audit_entry
The following script combines all components into a single executable module. You must set the environment variables before running.
import os
import sys
import json
import httpx
import structlog
# Import helper classes from steps above
# In production, place these in separate modules and import them here.
structlog.configure(
    processors=[
        structlog.processors.TimeStamper(fmt="iso"),
        structlog.processors.JSONRenderer()
    wrapper_class=structlog.make_filtering_bound_logger("INFO"),
    context_class=dict,
    logger_factory=structlog.PrintLoggerFactory(),
    cache_logger_on_first_use=True
def run_menu_transcriber():
    """Execute the complete IVR menu transcription workflow."""
    # 1. Authentication
        scopes=["speech:transcriptions:write", "speech:transcriptions:read"]
    client.get_access_token()  # Validate credentials
    # 2. Configuration
    audio_path = os.getenv("AUDIO_FILE_PATH", "ivr_menu_main.wav")
    language_code = os.getenv("LANGUAGE_CODE", "en-US")
    menu_id = os.getenv("MENU_ID", "menu_001")
    webhook_url = os.getenv("WEBHOOK_URL", "https://your-accessibility-tool.com/webhooks/cxone-transcribe")
    base_url = f"https://{config.environment}"
    metrics = TranscriptionMetrics()
        # 3. Validate constraints
        logger.info("validating_audio_constraints", file=audio_path)
        format_info = validate_audio_file(audio_path, language_code)
        # 4. Upload audio to accessible URL (simulated for this tutorial)
        # In production, use CXone Media API or AWS S3 pre-signed URLs
        audio_url = f"https://secure-storage.example.com/audio/{os.path.basename(audio_path)}"
        # 5. Build payload
        node_matrix = {
            "root": "main_menu",
            "branches": {
                "sales": "node_sales_01",
                "support": "node_support_01",
                "billing": "node_billing_01"
        payload = build_transcription_payload(
            audio_url=audio_url,
            menu_id=menu_id,
            node_matrix=node_matrix,
            language_code=language_code,
            webhook_url=webhook_url,
            format_info=format_info
        # 6. Submit atomic POST
        submitter = TranscriptionSubmitter(client, base_url)
        result = submitter.submit_transcription(payload)
        metrics.record_submission(success=True, latency_ms=latency_ms)
        logger.info(
            "workflow_complete",
            job_id=result.get("id"),
            latency_ms=latency_ms,
            success_rate=metrics.get_success_rate(),
            avg_latency=metrics.get_avg_latency()
        return result
    except ValueError as ve:
        logger.error("validation_error", detail=str(ve))
        sys.exit(1)
        logger.error("workflow_failure", exception=str(e))
        sys.exit(1)
Error: 400 Bad Request - Schema Validation Failed
  • Cause: The audio format does not match the declared format field, or the node_matrix contains invalid keys. The CXone Speech API enforces strict JSON schema validation on the metadata object.
  • Fix: Verify that the format field matches the actual file extension. Ensure node_matrix only contains string keys and values. Remove nested objects that exceed two levels of depth.
  • Code showing the fix:
# Validate payload structure before submission
if not isinstance(payload["audio"]["metadata"]["node_matrix"], dict):
    raise ValueError("node_matrix must be a flat dictionary mapping.")
if payload["audio"]["format"] != audio_path.split(".")[-1].lower():
    raise ValueError("Format field mismatch.")
Error: 429 Too Many Requests - Rate Limit Cascade
  • Cause: Your client ID exceeds the Speech API submission quota (typically 10 requests per second per tenant). Concurrent menu extraction jobs trigger cascading rate limits.
  • Fix: Implement exponential backoff with jitter. The TranscriptionSubmitter class already includes retry logic. Increase the retry_delay multiplier if you submit batches.
import random
# Inside retry loop
retry_after = int(response.headers.get("Retry-After", 2))
jitter = random.uniform(0.1, 0.5)
time.sleep(retry_after + jitter)
Error: 403 Forbidden - Insufficient OAuth Scopes
  • Cause: The client credentials lack speech:transcriptions:write. Pure Connect menu read access requires pureconnect:menus:read if you dynamically fetch menu definitions before transcription.
  • Fix: Regenerate the OAuth client in the CXone Admin Console and append the missing scope to the scopes list in the Configuration object.
    environment=os.getenv("CXONE_ENVIRONMENT"),
Error: Audio Duration Exceeds Maximum Limit
  • Cause: The IVR menu audio file exceeds 30 minutes (1800 seconds). CXone rejects long-form audio in a single transcription job to prevent memory exhaustion on the speech processing cluster.
  • Fix: Split the audio file into segments using pydub or ffmpeg before validation. Submit each segment as an independent job with a shared menu_id and sequential segment_index in the metadata.
# Pre-split logic placeholder
if format_info["duration_seconds"] > 1800:
    raise ValueError("Audio must be split into segments under 1800s before submission.")
