Training NICE Cognigy.AI Custom Entities via Webhooks with Python
This tutorial builds a Python automation pipeline that constructs, validates, and submits custom entity training payloads to Cognigy.AI, triggers atomic model fine-tuning with cross-validation, executes overlap and false positive verification, synchronizes with external labeling platforms, and generates governance audit logs. The solution uses Cognigy Webhooks and the REST API to manage the entire training lifecycle programmatically. The implementation is written in Python using httpx and pydantic.
- OAuth2 Client Credentials with scopes:
entity:write nlp:train webhook:execute - Cognigy API v1 base URL format:
https://{environment}.cognigy.ai/api/v1 - Python 3.9 or newer
- Dependencies:
httpx>=0.25.0,pydantic>=2.5.0,uuid,json,logging,time
Cognigy uses standard OAuth2 token exchange. The client must cache the token and handle expiration before issuing training requests. The following client setup demonstrates token retrieval, caching, and automatic retry on 401 Unauthorized responses.
import httpx
import logging
from typing import Optional
class CognigyAuthClient:
def __init__(self, env: str, client_id: str, client_secret: str):
self.base_url = f"https://{env}.cognigy.ai/api/v1"
self.token_url = f"https://{env}.cognigy.ai/oauth/token"
self.client_id = client_id
self.http = httpx.AsyncClient(timeout=30.0, follow_redirects=True)
async def _fetch_token(self) -> dict:
payload = {
"client_id": self.client_id,
"scope": "entity:write nlp:train webhook:execute"
response = await self.http.post(self.token_url, data=payload)
response.raise_for_status()
return response.json()
if self.access_token and time.time() < self.token_expiry - 60:
return self.access_token
token_data = await self._fetch_token()
self.token_expiry = time.time() + token_data["expires_in"]
async def close(self):
await self.http.aclose()
Cognigy.AI enforces strict constraints on training batches. The ML engine rejects payloads exceeding batch limits, containing malformed regex patterns, or lacking validation score directives. The following Pydantic models enforce schema rules before transmission.
from pydantic import BaseModel, field_validator, ConfigDict
import re
MAX_BATCH_SIZE = 5000
MAX_PATTERN_LENGTH = 256
MIN_VALIDATION_SCORE = 0.75
class RegexPattern(BaseModel):
pattern: str
confidence_boost: float
@field_validator("pattern")
@classmethod
def validate_regex(cls, v: str) -> str:
if len(v) > MAX_PATTERN_LENGTH:
raise ValueError(f"Pattern exceeds {MAX_PATTERN_LENGTH} character limit")
re.compile(v)
except re.error as e:
raise ValueError(f"Invalid regex syntax: {e}")
return v
@field_validator("confidence_boost")
@classmethod
def validate_boost(cls, v: float) -> float:
if not (0.0 <= v <= 1.0):
raise ValueError("confidence_boost must be between 0.0 and 1.0")
return v
class TrainPayload(BaseModel):
model_config = ConfigDict(str_strip_whitespace=True)
entity_id: str
annotation_set_id: str
patterns: List[RegexPattern]
validation_score_directive: float = MIN_VALIDATION_SCORE
cross_validation_enabled: bool = True
cross_validation_folds: int = 5
batch_size: int = MAX_BATCH_SIZE
@field_validator("patterns")
@classmethod
def validate_batch_size(cls, v: List[RegexPattern]) -> List[RegexPattern]:
if len(v) > MAX_BATCH_SIZE:
raise ValueError(f"Batch size {len(v)} exceeds ML engine limit of {MAX_BATCH_SIZE}")
return v
@field_validator("validation_score_directive")
@classmethod
def validate_score(cls, v: float) -> float:
if v < MIN_VALIDATION_SCORE:
raise ValueError(f"Validation score directive must be >= {MIN_VALIDATION_SCORE}")
return v
def to_cognigy_json(self) -> Dict[str, Any]:
"entityId": self.entity_id,
"annotationSetId": self.annotation_set_id,
"trainingData": {
"regexPatterns": [p.model_dump() for p in self.patterns],
"validationScoreDirective": self.validation_score_directive,
"batchConfiguration": {
"maxBatchSize": self.batch_size,
"enforceAtomicSubmission": True
"modelOptions": {
"crossValidationEnabled": self.cross_validation_enabled,
"crossValidationFolds": self.cross_validation_folds,
"triggerFineTuning": True
Step 2: Atomic Training POST and Cross-Validation Trigger
The training endpoint accepts an atomic POST request. Cognigy returns 202 Accepted when the job enters the queue, and 200 OK when synchronous validation completes. The following function handles the request cycle, enforces format verification, and captures the training job identifier for polling.
import json
from httpx import HTTPStatusError, RequestError
async def trigger_entity_training(
auth: CognigyAuthClient,
payload: TrainPayload
token = await auth.get_token()
url = f"{auth.base_url}/entities/{payload.entity_id}/train"
headers = {
"X-Cognigy-Environment": "production"
body = payload.to_cognigy_json()
response = await auth.http.post(url, headers=headers, json=body)
except HTTPStatusError as e:
if e.response.status_code == 429:
retry_after = int(e.response.headers.get("Retry-After", 5))
logging.warning(f"Rate limited. Retrying in {retry_after}s")
return await trigger_entity_training(auth, payload)
elif e.response.status_code == 409:
raise RuntimeError("Training conflict: active training job already running for this entity")
else:
logging.error(f"Training POST failed: {e.response.status_code} {e.response.text}")
raise
except RequestError as e:
logging.error(f"Network error during training: {e}")
raise
Step 3: Overlap Detection and False Positive Verification
After training completes, the pipeline must verify extraction precision. Overlap detection checks whether new patterns conflict with existing annotation sets. False positive verification simulates utterances against the updated model to measure precision drift.
import asyncio
from typing import Tuple
async def verify_training_precision(
entity_id: str,
test_utterances: List[str]
) -> Tuple[float, List[str]]:
headers = {
# Step A: Fetch existing patterns for overlap analysis
existing_url = f"{auth.base_url}/entities/{entity_id}/patterns"
existing_resp = await auth.http.get(existing_url, headers=headers)
existing_resp.raise_for_status()
existing_patterns = {p["pattern"] for p in existing_resp.json().get("patterns", [])}
# Step B: Simulate extraction to measure false positives
simulate_url = f"{auth.base_url}/nlp/simulate"
simulation_payload = {
"entityId": entity_id,
"utterances": test_utterances,
"returnConfidence": True
simulation_resp = await auth.http.post(simulate_url, headers=headers, json=simulation_payload)
simulation_resp.raise_for_status()
results = simulation_resp.json().get("results", [])
false_positives = []
total_confidence = 0.0
valid_extractions = 0
for res in results:
confidence = res.get("confidence", 0.0)
extracted = res.get("extractedValue", "")
if extracted and confidence < 0.80:
false_positives.append(res.get("utterance", "unknown"))
if extracted:
total_confidence += confidence
valid_extractions += 1
precision_rate = total_confidence / valid_extractions if valid_extractions > 0 else 0.0
return precision_rate, false_positives
Step 4: Callback Synchronization and Audit Logging
External NLP labeling platforms require webhook callbacks to synchronize annotation states. The following handler processes training completion events, calculates latency, records precision metrics, and writes governance audit logs.
import uuid
class TrainingAuditLogger:
def __init__(self):
self.audit_records: List[Dict[str, Any]] = []
def log_training_event(
self,
entity_id: str,
job_id: str,
start_time: float,
end_time: float,
precision_rate: float,
false_positives: List[str],
callback_url: str
latency_ms = (end_time - start_time) * 1000
audit_entry = {
"auditId": str(uuid.uuid4()),
"jobId": job_id,
"trainingLatencyMs": round(latency_ms, 2),
"entityPrecisionRate": round(precision_rate, 4),
"falsePositiveCount": len(false_positives),
"falsePositiveSamples": false_positives[:5],
"callbackEndpoint": callback_url,
"status": "completed",
"complianceFlags": ["schema_validated", "batch_limited", "cross_validated"]
self.audit_records.append(audit_entry)
logging.info(f"Audit logged: {audit_entry['auditId']} | Precision: {precision_rate:.2%} | Latency: {latency_ms:.0f}ms")
return audit_entry
async def sync_labeling_platform(
callback_url: str,
audit_record: Dict[str, Any]
) -> bool:
headers = {
"X-Cognigy-Webhook-Signature": "verified"
resp = await auth.http.post(callback_url, json=audit_record, headers=headers)
logging.info(f"Callback synchronized to {callback_url}")
return True
logging.error(f"Callback failed: {e.response.status_code} {e.response.text}")
return False
The following script integrates authentication, payload construction, atomic training, verification, callback synchronization, and audit logging into a single executable module. Replace the placeholder credentials and identifiers before execution.
import asyncio
import sys
import httpx
import uuid
import logging
import re
# --- Configuration ---
COGNIFY_ENV = "your-env"
CLIENT_ID = "your-client-id"
CLIENT_SECRET = "your-client-secret"
TARGET_ENTITY_ID = "ent_12345abcde"
ANNOTATION_SET_ID = "as_67890fghij"
LABELING_CALLBACK_URL = "https://external-platform.example.com/webhooks/cognigy-sync"
# --- Models ---
pattern: str
@classmethod
re.compile(v)
return v
@classmethod
return v
entity_id: str
@classmethod
return v
@classmethod
return v
def to_cognigy_json(self) -> dict:
"trainingData": {
"modelOptions": {
# --- Auth & HTTP ---
self.access_token: str | None = None
payload = {
# --- Training & Verification ---
async def trigger_entity_training(auth: CognigyAuthClient, payload: TrainPayload) -> dict:
headers = {
raise RuntimeError("Training conflict: active training job already running")
else:
raise
async def verify_training_precision(auth: CognigyAuthClient, entity_id: str, test_utterances: list) -> tuple:
for res in results:
if extracted:
# --- Audit & Callback ---
def __init__(self):
self.audit_records = []
def log_training_event(self, entity_id: str, job_id: str, start_time: float, end_time: float, precision_rate: float, false_positives: list, callback_url: str) -> dict:
audit_entry = {
"jobId": job_id,
return audit_entry
async def sync_labeling_platform(auth: CognigyAuthClient, callback_url: str, audit_record: dict) -> bool:
headers = {"Content-Type": "application/json", "X-Cognigy-Webhook-Signature": "verified"}
return True
return False
# --- Orchestration ---
async def main():
auth = CognigyAuthClient(COGNIFY_ENV, CLIENT_ID, CLIENT_SECRET)
logger = TrainingAuditLogger()
test_patterns = [
RegexPattern(pattern=r"\b\d{3}-\d{4}-\d{4}\b", confidence_boost=0.9),
RegexPattern(pattern=r"\b[A-Z]{2}\d{6}\b", confidence_boost=0.85),
RegexPattern(pattern=r"\bhttps?://\S+\b", confidence_boost=0.75)
payload = TrainPayload(
entity_id=TARGET_ENTITY_ID,
annotation_set_id=ANNOTATION_SET_ID,
patterns=test_patterns
test_utterances = [
"My order number is 123-456-7890",
"Reference code AB123456 is invalid",
"Visit https://example.com for details",
"I need help with my account"
start_time = time.time()
logging.info("Submitting atomic training payload...")
train_result = await trigger_entity_training(auth, payload)
job_id = train_result.get("jobId", "unknown")
logging.info(f"Training job submitted: {job_id}")
logging.info("Running precision verification pipeline...")
precision_rate, false_positives = await verify_training_precision(auth, TARGET_ENTITY_ID, test_utterances)
end_time = time.time()
audit = logger.log_training_event(
job_id=job_id,
start_time=start_time,
end_time=end_time,
precision_rate=precision_rate,
false_positives=false_positives,
callback_url=LABELING_CALLBACK_URL
logging.info("Syncing with external labeling platform...")
await sync_labeling_platform(auth, LABELING_CALLBACK_URL, audit)
logging.info("Pipeline completed successfully.")
logging.error(f"Pipeline failed: {e}")
sys.exit(1)
finally:
await auth.close()
asyncio.run(main())
Common Errors and Debugging
Error: 400 Bad Request
Cause: The training payload violates Cognigy schema constraints. Common triggers include regex patterns exceeding 256 characters, missing annotationSetId, or validationScoreDirective falling below 0.75.
Fix: Validate the payload against the Pydantic model before transmission. The field_validator methods in TrainPayload catch these violations locally and raise descriptive errors.
Code showing the fix:
payload = TrainPayload(entity_id="ent_xxx", annotation_set_id="as_yyy", patterns=[])
except ValueError as e:
logging.error(f"Schema validation failed: {e}")
Cause: The OAuth token expired or was rejected due to missing scopes.
Fix: Ensure the token fetch includes entity:write nlp:train webhook:execute. The CognigyAuthClient automatically refreshes tokens when time.time() >= token_expiry - 60. If the error persists, verify client credentials in the Cognigy admin console.
Error: 409 Conflict
Cause: An active training job is already running for the target entity. Cognigy enforces atomic training to prevent model corruption.
Fix: Poll the job status endpoint before submitting a new batch, or implement a queueing mechanism. The trigger_entity_training function raises a RuntimeError on 409 to prevent silent failures.
Cause: Rate limiting triggered by rapid training submissions or simulation calls.
Fix: The implementation reads the Retry-After header and sleeps before retrying. For high-volume pipelines, implement exponential backoff with jitter.
