Train NICE CXone AI Skills Programmatically with Python and Asynchronous Job Management
- A Python script that constructs and submits AI skill training payloads containing utterance sets, label definitions, and validation splits.
- Polling logic that tracks asynchronous training jobs, monitors compute resource allocation, and retrieves evaluation metrics.
- A model evaluation module that analyzes confusion matrices, tunes classification thresholds, exports artifacts to external registries, and generates governance audit logs.
- OAuth 2.0 Client Credentials grant with scopes:
ai:skills:read,ai:skills:write,ai:training:read,ai:training:write - CXone API region endpoint (e.g.,
api.us2-01.cxone.com) - Python 3.9+ runtime
- External dependencies:
pip install requests numpy pandas scikit-learn
CXone uses standard OAuth 2.0 client credentials flow. The token endpoint requires your client identifier, client secret, and the exact scopes required for AI skill training. The following implementation includes automatic token caching with a ten-minute TTL to prevent unnecessary authentication requests.
import requests
from typing import Optional
BASE_URL = "https://api.us2-01.cxone.com"
TOKEN_ENDPOINT = f"{BASE_URL}/oauth/token"
class CXoneAuth:
def __init__(self, client_id: str, client_secret: str, scopes: list[str]):
self.client_id = client_id
self.scopes = scopes
self.token_expiry: float = 0
def get_token(self) -> str:
if self.access_token and time.time() < self.token_expiry - 60:
return self.access_token
payload = {
"client_id": self.client_id,
"scope": " ".join(self.scopes)
response = requests.post(TOKEN_ENDPOINT, json=payload, timeout=10)
response.raise_for_status()
data = response.json()
self.access_token = data["access_token"]
self.token_expiry = time.time() + data["expires_in"]
"Authorization": f"Bearer {self.get_token()}",
"Accept": "application/json"
Step 1: Construct and Validate Training Payloads
The CXone AI training API expects a structured JSON payload containing utterance samples, label metadata, and a validation split ratio. Before submission, the payload must pass class balance validation and language constraint checks to prevent model divergence during training.
HTTP Request Cycle
- Method:
POST - Path:
/api/v2/ai/skills/training/jobs - Headers:
Authorization: Bearer {token},Content-Type: application/json - Scopes:
ai:skills:write,ai:training:write
import json
import numpy as np
from collections import Counter
def validate_training_data(utterances: list[dict], labels: list[dict]) -> None:
label_counts = Counter(u["label"] for u in utterances)
languages = set(u.get("language", "en") for u in utterances)
if len(languages) > 1:
raise ValueError("Mixed language utterances detected. CXone AI requires monolingual training sets.")
if not label_counts:
raise ValueError("Empty utterance set provided.")
min_count = min(label_counts.values())
max_count = max(label_counts.values())
if max_count / min_count > 3.0:
raise ValueError(f"Class imbalance exceeds 3:1 ratio. Min: {min_count}, Max: {max_count}. Resample or augment minority classes.")
valid_label_ids = {l["id"] for l in labels}
for label_id in label_counts.keys():
if label_id not in valid_label_ids:
raise ValueError(f"Utterance references undefined label: {label_id}")
def build_training_payload(skill_id: str, utterances: list[dict], labels: list[dict]) -> dict:
validate_training_data(utterances, labels)
"skillId": skill_id,
"trainingData": {
"utterances": utterances,
"validationSplit": 0.2,
"language": utterances[0].get("language", "en")
"labels": labels,
"hyperparameters": {
"maxEpochs": 50,
"earlyStopping": True,
"patience": 5
Step 2: Submit Job and Poll Asynchronous Training Status
Training jobs run asynchronously on distributed compute clusters. The API returns a job identifier immediately. You must poll the status endpoint with exponential backoff to respect rate limits and monitor compute unit allocation. The response includes progress metrics, resource utilization, and current pipeline stage.
HTTP Request Cycle
- Method:
GET - Path:
/api/v2/ai/skills/training/jobs/{jobId} - Headers:
Authorization: Bearer {token},Accept: application/json - Scopes:
ai:training:read
from typing import Any
def submit_training_job(auth: CXoneAuth, payload: dict) -> str:
url = f"{BASE_URL}/api/v2/ai/skills/training/jobs"
response = requests.post(url, json=payload, headers=auth.get_headers(), timeout=30)
return response.json()["jobId"]
def poll_training_job(auth: CXoneAuth, job_id: str, max_retries: int = 60) -> dict:
url = f"{BASE_URL}/api/v2/ai/skills/training/jobs/{job_id}"
backoff = 2
response = requests.get(url, headers=auth.get_headers(), timeout=10)
retry_after = int(response.headers.get("Retry-After", backoff))
print(f"Rate limited. Waiting {retry_after}s before retry.")
time.sleep(retry_after)
backoff = min(backoff * 2, 60)
job_data = response.json()
status = job_data["status"]
progress = job_data["progress"]
compute_allocated = job_data.get("computeUnitsAllocated", 0)
compute_used = job_data.get("computeUnitsUsed", 0)
print(f"Status: {status} | Progress: {progress}% | Compute: {compute_used}/{compute_allocated} units")
if status in ["COMPLETED", "FAILED", "CANCELLED"]:
return job_data
time.sleep(backoff)
backoff = min(backoff * 1.5, 30)
print(f"Polling error on attempt {attempt + 1}: {e}")
time.sleep(backoff)
raise TimeoutError("Training job did not complete within maximum polling attempts.")
Step 3: Evaluate Model Metrics and Export Artifacts
Upon completion, the evaluation endpoint returns precision, recall, and a confusion matrix. You must calculate optimal classification thresholds to balance precision and recall for your specific use case. The artifact export endpoint provides signed URLs for downloading model weights and configuration files for external MLOps registry synchronization.
HTTP Request Cycle
- Method:
GET - Path:
/api/v2/ai/skills/training/jobs/{jobId}/evaluation - Headers:
ai:training:read
import pandas as pd
from sklearn.metrics import precision_score, recall_score, confusion_matrix
def evaluate_model_metrics(evaluation_data: dict) -> dict:
labels = evaluation_data["labels"]
predictions = evaluation_data["predictions"]
actuals = evaluation_data["actuals"]
label_map = {l["id"]: i for i, l in enumerate(labels)}
y_true = [label_map[a] for a in actuals]
y_pred = [label_map[p] for p in predictions]
cm = confusion_matrix(y_true, y_pred)
precision = precision_score(y_true, y_pred, average="macro", zero_division=0)
recall = recall_score(y_true, y_pred, average="macro", zero_division=0)
print(f"Confusion Matrix:\n{cm}")
print(f"Macro Precision: {precision:.4f} | Macro Recall: {recall:.4f}")
threshold_tuning = optimize_threshold(predictions, actuals, labels)
"confusionMatrix": cm.tolist(),
"precision": precision,
"recall": recall,
"thresholdRecommendation": threshold_tuning,
"trainingDurationSeconds": evaluation_data.get("trainingDurationSeconds", 0)
def optimize_threshold(predictions: list, actuals: list, labels: list) -> dict:
thresholds = np.arange(0.3, 0.9, 0.05)
best_threshold = 0.5
max_f1 = 0
for t in thresholds:
adjusted_preds = [p if p["score"] >= t else "unknown" for p in predictions]
# Simplified F1 calculation for threshold tuning demonstration
tp = sum(1 for a, p in zip(actuals, adjusted_preds) if a == p and a != "unknown")
fp = sum(1 for a, p in zip(actuals, adjusted_preds) if a != p and p != "unknown")
fn = sum(1 for a, p in zip(actuals, adjusted_preds) if a != p and p == "unknown")
prec = tp / (tp + fp) if (tp + fp) > 0 else 0
rec = tp / (tp + fn) if (tp + fn) > 0 else 0
f1 = 2 * (prec * rec) / (prec + rec) if (prec + rec) > 0 else 0
if f1 > max_f1:
max_f1 = f1
best_threshold = t
return {"optimalThreshold": round(best_threshold, 2), "f1Score": round(max_f1, 4)}
def export_artifacts(auth: CXoneAuth, job_id: str) -> dict:
url = f"{BASE_URL}/api/v2/ai/skills/training/jobs/{job_id}/artifacts/export"
response = requests.get(url, headers=auth.get_headers(), timeout=15)
export_data = response.json()
model_url = export_data["artifacts"]["modelWeightsUrl"]
config_url = export_data["artifacts"]["configUrl"]
"modelExportUrl": model_url,
"configExportUrl": config_url,
"expiresAt": export_data["expiresAt"],
"registrySyncReady": True
def generate_audit_log(job_id: str, metrics: dict, export_info: dict) -> dict:
import datetime
"auditTimestamp": datetime.datetime.utcnow().isoformat(),
"jobId": job_id,
"modelMetrics": metrics,
"artifactExport": export_info,
"complianceFlags": {
"dataValidationPassed": True,
"classBalanceChecked": True,
"languageConstraintEnforced": True
"exportedForRegistry": True
The following script combines authentication, payload construction, asynchronous polling, evaluation, and artifact export into a single executable module. Replace the credential placeholders with your CXone client configuration before execution.
import requests
import json
import numpy as np
class CXoneAuth:
payload = {
if max(label_counts.values()) / min(label_counts.values()) > 3.0:
raise ValueError("Class imbalance exceeds 3:1 ratio. Resample or augment minority classes.")
"trainingData": {
"labels": labels,
"hyperparameters": {"maxEpochs": 50, "earlyStopping": True, "patience": 5}
def poll_training_job(auth: CXoneAuth, job_id: str, max_retries: int = 30) -> dict:
backoff = 2
time.sleep(int(response.headers.get("Retry-After", backoff)))
print(f"Status: {job_data['status']} | Progress: {job_data['progress']}% | Compute: {job_data.get('computeUnitsUsed', 0)}/{job_data.get('computeUnitsAllocated', 0)}")
if job_data["status"] in ["COMPLETED", "FAILED", "CANCELLED"]:
return job_data
time.sleep(backoff)
print(f"Polling error: {e}")
time.sleep(backoff)
def evaluate_and_export(auth: CXoneAuth, job_id: str) -> dict:
eval_url = f"{BASE_URL}/api/v2/ai/skills/training/jobs/{job_id}/evaluation"
eval_response = requests.get(eval_url, headers=auth.get_headers(), timeout=15)
eval_response.raise_for_status()
eval_data = eval_response.json()
labels = eval_data["labels"]
predictions = eval_data["predictions"]
actuals = eval_data["actuals"]
export_url = f"{BASE_URL}/api/v2/ai/skills/training/jobs/{job_id}/artifacts/export"
export_response = requests.get(export_url, headers=auth.get_headers(), timeout=15)
export_response.raise_for_status()
export_info = export_response.json()
audit_log = {
"timestamp": time.strftime("%Y-%m-%dT%H:%M:%SZ"),
"jobId": job_id,
"metrics": {"precision": precision, "recall": recall, "confusionMatrix": cm.tolist()},
"artifacts": {"modelUrl": export_info["artifacts"]["modelWeightsUrl"], "configUrl": export_info["artifacts"]["configUrl"]},
"compliance": {"dataValidated": True, "balanceChecked": True, "registrySyncReady": True}
return audit_log
CLIENT_ID = "your_client_id"
CLIENT_SECRET = "your_client_secret"
SKILL_ID = "skill-abc-123"
auth = CXoneAuth(CLIENT_ID, CLIENT_SECRET, ["ai:skills:read", "ai:skills:write", "ai:training:read", "ai:training:write"])
sample_utterances = [
{"text": "I want to cancel my subscription", "label": "cancel_sub", "language": "en"},
{"text": "Please terminate my account", "label": "cancel_sub", "language": "en"},
{"text": "How do I upgrade my plan", "label": "upgrade_plan", "language": "en"},
{"text": "I need a higher tier", "label": "upgrade_plan", "language": "en"},
{"text": "Reset my password", "label": "reset_pwd", "language": "en"},
{"text": "I forgot my login details", "label": "reset_pwd", "language": "en"}
sample_labels = [
{"id": "cancel_sub", "name": "Cancel Subscription", "description": "User requests cancellation"},
{"id": "upgrade_plan", "name": "Upgrade Plan", "description": "User wants higher tier"},
{"id": "reset_pwd", "name": "Reset Password", "description": "User needs credential recovery"}
payload = build_training_payload(SKILL_ID, sample_utterances, sample_labels)
job_id = submit_training_job(auth, payload)
print(f"Job submitted: {job_id}")
job_result = poll_training_job(auth, job_id)
if job_result["status"] != "COMPLETED":
raise RuntimeError(f"Training failed with status: {job_result['status']}")
audit_log = evaluate_and_export(auth, job_id)
print(json.dumps(audit_log, indent=2))
- Cause: OAuth token expired or missing required scopes in the
Authorizationheader. - Fix: Ensure the
CXoneAuthclass refreshes the token before each request. Verify the client credentials grant includesai:training:writeandai:skills:write. The token endpoint returnsexpires_in; subtract sixty seconds from the calculated expiry to avoid edge-case failures during long polling cycles.
Error: 400 Bad Request (Validation Failed)
- Cause: Class imbalance exceeds the three-to-one threshold, mixed language utterances in a single payload, or undefined label references.
- Fix: Run the
validate_training_datafunction before submission. Resample minority classes using synthetic augmentation or stratified splitting. Ensure every utterance object contains alanguagefield matching a single ISO 639-1 code.
- Cause: Polling the job status endpoint faster than the CXone AI rate limit allows, typically during rapid progress updates.
- Fix: Implement exponential backoff with
Retry-Afterheader parsing. The polling function in the complete example caps backoff at thirty seconds and doubles the interval on consecutive rate limits. Never poll faster than every two seconds during active training stages.
Error: 500 Internal Server Error or 503 Service Unavailable
- Cause: CXone AI training cluster is under heavy load or the submitted payload triggers a known model architecture limitation.
- Fix: Retry the submission after a thirty-second delay. If the error persists, reduce
maxEpochsin the hyperparameters or decrease the utterance count to test payload structure. Check thecomputeUnitsAllocatedfield in the job response to confirm cluster capacity.
