Tracking NICE CXone Outbound Campaign Dial Attempts with Python SDK
A Python service that tracks outbound dial attempts in real-time, validates monitoring constraints, handles disposition and retry logic via WebSocket events, synchronizes with external dashboards via webhooks, and generates audit logs for governance. This tutorial uses the NICE CXone Outbound Campaign API and the official Python SDK. The implementation is written in Python 3.9+ using httpx, websockets, and pydantic.
  • OAuth2 client credentials with scopes: outbound:campaign:read, outbound:attempt:read, monitoring:session:create, webhook:read, webhook:write
  • NICE CXone Python SDK version 2.0.0+
  • Python 3.9+ runtime
  • External dependencies: pip install cxone-python-sdk httpx websockets pydantic aiohttp
  • A configured external dashboard endpoint to receive dial reported webhooks
NICE CXone uses OAuth2 client credentials flow. The following code demonstrates token acquisition, caching, and refresh logic using httpx. The token endpoint varies by region. Replace YOUR_REGION with api-us-1, api-eu-1, or api-ap-1.
import httpx
from typing import Optional
class CXoneAuth:
    def __init__(self, client_id: str, client_secret: str, region: str):
        self.client_id = client_id
        self.region = region
        self.token_url = f"https://{region}.cxone.com/oauth/token"
        self.http = httpx.Client()
    def get_token(self) -> str:
        if self.access_token and time.time() < self.token_expiry - 60:
            return self.access_token
        payload = {
            "client_id": self.client_id,
            "scope": "outbound:campaign:read outbound:attempt:read monitoring:session:create webhook:read webhook:write"
        response = self.http.post(self.token_url, data=payload)
        response.raise_for_status()
        data = response.json()
        self.access_token = data["access_token"]
        self.token_expiry = time.time() + data["expires_in"]
            "Authorization": f"Bearer {self.get_token()}",
The get_token method checks expiration before requesting a new token. The sixty-second buffer prevents edge-case 401 errors during token rotation. The get_headers method returns the exact headers required for all CXone API calls.
Step 1: SDK Initialization and Campaign Validation
Initialize the CXone Python SDK and validate the campaign ID against stale-campaign-id constraints. The SDK requires the base URL and authentication headers. We verify the campaign status before proceeding to prevent monitoring inactive or deleted campaigns.
from cxone_python_sdk import PlatformClient
from pydantic import BaseModel, ValidationError
import logging
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
class OutboundConstraints(BaseModel):
    campaign_id: str
    status: str
    max_monitor_window: int  # seconds
    retry_limit: int
    dial_method: str
def validate_campaign(platform_client: PlatformClient, constraints: OutboundConstraints) -> bool:
        campaigns = platform_client.outbound.get_outbound_campaigns(constraints.campaign_id)
        if not campaigns or not campaigns.entities:
            logging.error("Campaign not found or access denied")
            return False
        campaign = campaigns.entities[0]
        if campaign.status not in ("ACTIVE", "PAUSED"):
            logging.warning("Stale campaign ID detected. Status: %s", campaign.status)
            return False
        # Validate outbound-constraints against campaign configuration
        if campaign.dial_method != constraints.dial_method:
            logging.error("Dial method mismatch. Expected: %s, Got: %s", constraints.dial_method, campaign.dial_method)
            return False
        logging.info("Campaign validation passed. ID: %s, Status: %s", campaign.id, campaign.status)
        return True
        logging.error("Campaign validation failed: %s", str(e))
        return False
The validate_campaign function uses the PlatformClient to fetch campaign details. It checks for stale-campaign-id conditions by verifying the status matches ACTIVE or PAUSED. It also validates the outbound-constraints by comparing the configured dial method against the payload expectations.
Step 2: Construct Tracking Payloads and Monitor Directive
Build the tracking payload containing dial-ref, outbound-matrix, and monitor directive. The payload must comply with maximum-monitor-window limits and schema validation rules.
class TrackingPayload(BaseModel):
    dial_ref: str
    outbound_matrix: dict
    monitor_directive: dict
    created_at: datetime
    expires_at: datetime
def construct_tracking_payload(campaign_id: str, contact_id: str, max_window: int) -> TrackingPayload:
    now = datetime.utcnow()
    expires = now + timedelta(seconds=max_window)
    outbound_matrix = {
        "campaignId": campaign_id,
        "contactId": contact_id,
        "dialMethod": "PREDICTIVE",
        "priority": 1,
        "retryCount": 0
    monitor_directive = {
        "action": "MONITOR",
        "timeout": max_window,
        "captureAudio": False,
        "notifyOnDisposition": True
        payload = TrackingPayload(
            dial_ref=f"dial-{campaign_id}-{contact_id}-{int(now.timestamp())}",
            outbound_matrix=outbound_matrix,
            monitor_directive=monitor_directive,
            created_at=now,
            expires_at=expires
        return payload
    except ValidationError as e:
        logging.error("Tracking schema validation failed: %s", str(e))
        raise
The construct_tracking_payload function enforces schema validation using Pydantic. The maximum-monitor-window limit is applied to the expires_at field and the monitor directive timeout. The outbound-matrix contains the core routing parameters. The dial-ref provides a unique identifier for attempt tracking.
Step 3: WebSocket OPEN and Real-Time Disposition/Retry Logic
NICE CXone exposes real-time outbound events via WebSocket. This step handles atomic WebSocket OPEN operations, format verification, and automatic report triggers for safe monitor iteration.
import websockets
import json
import asyncio
class WebSocketMonitor:
    def __init__(self, ws_url: str, auth_headers: dict):
        self.ws_url = ws_url
        self.auth_headers = auth_headers
        self.connected = False
    async def open_and_monitor(self, tracking_payload: TrackingPayload):
        uri = f"{self.ws_url}?token={self.auth_headers['Authorization'].split(' ')[1]}"
            async with websockets.connect(uri) as websocket:
                self.connected = True
                logging.info("WebSocket OPEN successful. Subscribing to dial events.")
                # Send monitor directive subscription
                subscription = {
                    "type": "SUBSCRIBE",
                    "topic": f"outbound/campaigns/{tracking_payload.outbound_matrix['campaignId']}/attempts",
                    "filter": {"dialRef": tracking_payload.dial_ref}
                await websocket.send(json.dumps(subscription))
                async for message in websocket:
                    await self.process_event(message, tracking_payload)
        except websockets.exceptions.ConnectionClosed as e:
            logging.error("WebSocket connection closed: %s", str(e))
            logging.error("WebSocket monitoring error: %s", str(e))
    async def process_event(self, raw_message: str, payload: TrackingPayload):
            event = json.loads(raw_message)
            if event.get("type") != "OUTBOUND_ATTEMPT":
                return
            # Format verification
            if "disposition" not in event or "retryLogic" not in event:
                logging.warning("Invalid event format. Missing disposition or retryLogic.")
                return
            self.evaluate_disposition_and_retry(event, payload)
            logging.info("Event processed. DialRef: %s, Disposition: %s", payload.dial_ref, event["disposition"])
        except json.JSONDecodeError:
            logging.error("Failed to parse WebSocket message.")
            logging.error("Event processing error: %s", str(e))
    def evaluate_disposition_and_retry(self, event: dict, payload: TrackingPayload):
        disposition = event["disposition"]
        retry_logic = event["retryLogic"]
        if disposition in ("ANSWERED", "COMPLETED") and retry_logic.get("shouldRetry", False) is False:
            logging.info("Final disposition reached. Triggering report.")
            self.trigger_report(payload, event)
        elif retry_logic.get("shouldRetry", False) and payload.outbound_matrix["retryCount"] < 3:
            payload.outbound_matrix["retryCount"] += 1
            logging.info("Retry logic evaluated. Scheduling retry attempt %d", payload.outbound_matrix["retryCount"])
            # In production, push retry back to campaign queue via API
The WebSocketMonitor class handles the atomic OPEN operation, subscription routing, and event processing. The evaluate_disposition_and_retry method implements disposition-calculation and retry-logic evaluation. It triggers automatic reports when final dispositions are reached and increments retry counters within safe bounds.
Step 4: Webhook Sync and External Dashboard Alignment
Synchronize tracking events with an external dashboard via dial reported webhooks. This step validates the webhook payload and forwards it using httpx with rate-limit-verification pipelines.
class WebhookSync:
    def __init__(self, dashboard_url: str):
        self.dashboard_url = dashboard_url
        self.http = httpx.AsyncClient()
    async def send_dial_reported_webhook(self, payload: TrackingPayload, event: dict):
        webhook_body = {
            "eventType": "DIAL_REPORTED",
            "dialRef": payload.dial_ref,
            "campaignId": payload.outbound_matrix["campaignId"],
            "contactId": payload.outbound_matrix["contactId"],
            "disposition": event["disposition"],
            "retryCount": payload.outbound_matrix["retryCount"],
            "timestamp": datetime.utcnow().isoformat(),
            "monitorWindowExceeded": datetime.utcnow() > payload.expires_at
        for attempt in range(3):
                response = await self.http.post(
                    self.dashboard_url,
                    json=webhook_body,
                    headers={"Content-Type": "application/json"},
                    timeout=10.0
                    retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
                    logging.warning("Rate limit hit. Waiting %d seconds.", retry_after)
                logging.info("Webhook delivered successfully. Status: %d", response.status_code)
                return True
                logging.error("Webhook delivery failed: %s", str(e))
                return False
                logging.error("Webhook request error: %s", str(e))
                await asyncio.sleep(2 ** attempt)
        logging.error("Webhook delivery failed after retries.")
        return False
The WebhookSync class implements rate-limit-verification by handling HTTP 429 responses with exponential backoff. It synchronizes tracking events with the external dashboard using the DIAL_REPORTED webhook format. The payload includes latency markers and monitor window status for dashboard alignment.
Step 5: Latency Tracking, Success Rates, and Audit Logs
Track tracking latency and monitor success rates for track efficiency. Generate tracking audit logs for outbound governance.
from collections import defaultdict
class DialTracker:
    def __init__(self):
        self.latency_log = defaultdict(list)
        self.success_counts = defaultdict(int)
        self.total_attempts = 0
        self.audit_log = []
    def record_attempt(self, dial_ref: str, start_time: float, success: bool):
        self.total_attempts += 1
        latency = time.time() - start_time
        self.latency_log[dial_ref].append(latency)
        if success:
            self.success_counts[dial_ref] += 1
        self.audit_log.append({
            "dialRef": dial_ref,
            "latencyMs": round(latency * 1000, 2),
            "success": success,
            "governanceTag": "OUTBOUND_TRACKING"
    def get_metrics(self) -> dict:
        if not self.total_attempts:
            return {"error": "No attempts recorded"}
        total_latency = sum(sum(l) for l in self.latency_log.values())
        avg_latency = total_latency / self.total_attempts
        success_rate = sum(self.success_counts.values()) / self.total_attempts
            "totalAttempts": self.total_attempts,
            "averageLatencyMs": round(avg_latency * 1000, 2),
            "successRate": round(success_rate, 4),
            "auditLogEntries": len(self.audit_log)
    def export_audit_log(self) -> list:
        return self.audit_log.copy()
The DialTracker class records latency per dial reference, calculates success rates, and maintains an immutable audit log for outbound governance. The get_metrics method exposes efficiency metrics for automated NICE CXone management.
import asyncio
import sys
async def main():
    # Configuration
    CLIENT_ID = "your_client_id"
    CLIENT_SECRET = "your_client_secret"
    REGION = "api-us-1"
    CAMPAIGN_ID = "your_campaign_id"
    CONTACT_ID = "your_contact_id"
    DASHBOARD_URL = "https://your-dashboard.example.com/webhooks/cxone"
    MAX_WINDOW = 300  # 5 minutes
    # Authentication
    auth = CXoneAuth(CLIENT_ID, CLIENT_SECRET, REGION)
    headers = auth.get_headers()
    # SDK Initialization
    platform_client = PlatformClient(
        base_url=f"https://{REGION}.cxone.com",
        auth_headers=headers
    # Constraints and Validation
    constraints = OutboundConstraints(
        campaign_id=CAMPAIGN_ID,
        status="ACTIVE",
        max_monitor_window=MAX_WINDOW,
        retry_limit=3,
        dial_method="PREDICTIVE"
    if not validate_campaign(platform_client, constraints):
        logging.error("Campaign validation failed. Exiting.")
        sys.exit(1)
    # Payload Construction
    tracking_payload = construct_tracking_payload(CAMPAIGN_ID, CONTACT_ID, MAX_WINDOW)
    tracker = DialTracker()
    webhook_sync = WebhookSync(DASHBOARD_URL)
    # WebSocket Monitoring
    ws_monitor = WebSocketMonitor(
        ws_url=f"wss://{REGION}.cxone.com/api/v2/outbound/events",
    # Attach tracker and webhook to monitor
    original_process = ws_monitor.process_event
    original_trigger = ws_monitor.trigger_report
    async def wrapped_process(msg, payload):
        start = time.time()
        await original_process(msg, payload)
        await webhook_sync.send_dial_reported_webhook(payload, {"disposition": "ANSWERED", "retryLogic": {"shouldRetry": False}})
        tracker.record_attempt(payload.dial_ref, start, success=True)
    ws_monitor.process_event = wrapped_process
    ws_monitor.trigger_report = lambda p, e: logging.info("Report triggered for %s", p.dial_ref)
    logging.info("Starting outbound dial tracking service...")
    await ws_monitor.open_and_monitor(tracking_payload)
    # Output metrics before exit
    metrics = tracker.get_metrics()
    logging.info("Final Metrics: %s", metrics)
    logging.info("Audit Log Export Ready: %d entries", len(tracker.export_audit_log()))
    asyncio.run(main())
The complete script initializes authentication, validates the campaign, constructs the tracking payload, opens the WebSocket connection, synchronizes webhooks, and records metrics. Replace the placeholder credentials and endpoints with your environment values. Run the script with python cxone_dial_tracker.py.
Error: HTTP 401 Unauthorized
  • What causes it: Expired OAuth token, incorrect client credentials, or missing scopes.
  • How to fix it: Verify the client ID and secret. Ensure the token refresh buffer is active. Check that outbound:campaign:read and outbound:attempt:read scopes are included in the token request.
  • Code showing the fix: The CXoneAuth.get_token method handles refresh automatically. If 401 persists, add explicit scope verification before API calls.
  • What causes it: Exceeding CXone API rate limits, typically 100 requests per second per client.
  • How to fix it: Implement exponential backoff. The WebhookSync class demonstrates this pattern. Add similar logic to SDK calls by wrapping them in retry decorators.
async def retry_on_429(func, *args, max_retries=3, **kwargs):
            return await func(*args, **kwargs)
            if e.response.status_code == 429:
                wait = 2 ** attempt
                logging.warning("Rate limited. Waiting %d seconds.", wait)
                await asyncio.sleep(wait)
            else:
                raise
    raise Exception("Max retries exceeded")
Error: HTTP 403 Forbidden
  • What causes it: OAuth client lacks permission to access the campaign or attempt data.
  • How to fix it: Assign the client to a user or group with Outbound Administrator or Campaign Manager role. Verify the campaign ID belongs to the authenticated tenant.
  • Code showing the fix: Add explicit permission checks before API calls. Log the campaign ID and tenant ID for audit trails.
Error: WebSocket Connection Refused or Stale Campaign ID
  • What causes it: Campaign status changed to STOPPED or ARCHIVED during monitoring, or incorrect WebSocket endpoint region.
  • How to fix it: Validate campaign status before opening the WebSocket. Reconnect automatically on ConnectionClosed with a stale-campaign-id check.
  • Code showing the fix: The validate_campaign function runs before WebSocket initialization. Add a periodic status check loop if monitoring exceeds five minutes.
Error: Pydantic ValidationError on Tracking Payload
  • What causes it: Missing required fields in outbound-matrix or invalid monitor directive structure.
  • How to fix it: Ensure all fields match the TrackingPayload schema. Verify maximum-monitor-window is a positive integer.
  • Code showing the fix: The construct_tracking_payload function catches ValidationError and logs the exact field mismatch. Review the traceback to correct payload construction.
