Tracking Custom Web Events using the Predictive Engagement SDK
This guide details the architectural implementation of custom web event tracking using the Genesys Cloud Predictive Engagement JavaScript SDK. You will configure the client-side tracking pipeline, structure compliant event payloads, and route those events to Predictive Engagement rules and Journey Builder for real-time conversational routing.
  • Licensing Tier: Genesys Cloud CX 2 or CX 3 (Predictive Engagement is included in CX 2+ tiers. Organizations on CX 1 must purchase the Predictive Engagement add-on bundle).
  • UI Roles: Predictive Engagement Administrator, Journey Builder Administrator, Web Chat Administrator
  • API/OAuth Scopes: webchat:manage, analytics:report:view, predictiveengagement:manage, architect:flow:view
  • External Dependencies: Modern browser environment supporting fetch, IntersectionObserver, and localStorage. NPM package genesyscloud-predictive-engagement-sdk@^1.0.0 or direct CDN script inclusion. Content Security Policy (CSP) configuration permitting https://*.mypurecloud.com and https://*.genesys.cloud endpoints.
1. SDK Initialization & Event Pipeline Configuration
The Predictive Engagement SDK operates as a lightweight client-side agent that serializes user interactions, batches them according to network conditions, and forwards them to the Genesys Cloud event ingestion pipeline. Proper initialization establishes the tenant context, region routing, and event queue behavior before any tracking calls execute.
You must initialize the SDK before the DOM fully renders to capture early navigation events. The configuration object dictates how the SDK handles tenant isolation, region failover, and data retention policies.
import { PredictiveEngagement } from 'genesyscloud-predictive-engagement-sdk';
const PE_CONFIG = {
  organizationId: 'your-organization-id',
  region: 'us-east-1', // Must match your Genesys Cloud deployment region
  environment: 'production',
  enableDebug: false, // Disable in production to prevent console log injection
  eventQueueLimit: 50, // Maximum events buffered before oldest drops
  flushIntervalMs: 2000, // Batch flush interval on idle
  disableTrackingOnBotDetection: true
const peClient = new PredictiveEngagement(PE_CONFIG);
await peClient.initialize().catch((error) => {
  console.error('Predictive Engagement SDK initialization failed:', error);
The Trap: Hardcoding the organizationId and region without environment-aware routing causes tenant isolation breaches during staging-to-production deployments. When a staging environment shares the same script tag but points to a production org ID, the SDK begins ingesting synthetic traffic into live Predictive Engagement scoring models. This corrupts baseline metrics, triggers false-positive engagement rules, and violates data separation compliance requirements.
Architectural Reasoning: We use environment variables injected at build time rather than runtime UI toggles. The SDK maintains an internal state machine that validates the organization ID against the Genesys Cloud tenant discovery endpoint before establishing the WebSocket or HTTP event channel. By enforcing region alignment, you prevent cross-region latency penalties and ensure that event payloads route to the correct data residency boundary. The eventQueueLimit parameter is critical for memory management. If you set this value too high, mobile devices with constrained RAM will experience garbage collection pauses that degrade the main thread. A limit of 50 events balances burst capture with memory safety.
2. Defining the Custom Event Schema & Payload Structure
Genesys Cloud normalizes all incoming web events into a standardized JSON structure before evaluating them against Journey Builder triggers or Architect conditions. The SDK exposes the trackEvent method, which accepts a string event name and a key-value data object. The platform does not accept nested objects, arrays, or functions within the payload.
// Correct payload structure
peClient.trackEvent('product_detail_viewed', {
  sku: 'WIDGET-8842',
  category: 'electronics',
  price: 149.99,
  user_segment: 'returning_visitor',
  page_path: '/products/wireless-headset',
  timestamp: Date.now()
// Incorrect payload structure (will be rejected or silently truncated)
peClient.trackEvent('cart_update', {
  items: [{ id: 1, qty: 2 }, { id: 2, qty: 1 }], // Arrays cause serialization failure
  metadata: { session: { id: 'abc', referrer: 'google' } }, // Nested objects break schema validation
  callback: () => console.log('fired') // Functions are stripped during serialization
The Trap: Sending dynamic arrays or deeply nested JSON objects under the assumption that the backend will flatten them automatically. Genesys Cloud’s event ingestion pipeline enforces a strict flat key-value schema. When the SDK encounters an array or nested object, it either drops the payload entirely or truncates it at the first level of depth. Journey Builder triggers that reference items[0].id will never fire because the property path does not exist in the normalized event store. This results in silent tracking failures that are difficult to diagnose without server-side payload inspection.
Architectural Reasoning: We enforce a flat schema at the client level using a serialization utility before calling trackEvent. This guarantees deterministic payload delivery and aligns with how Genesys Cloud indexes event properties for rule evaluation. Each key must follow a consistent naming convention (snake_case or camelCase, but never mixed). We avoid transmitting PII directly in event payloads. Instead, we transmit a hashed identifier or a session token that maps to a CRM record via a separate secure API call. This design satisfies GDPR and CCPA requirements while preserving the ability to enrich events downstream through Journey Builder’s data connector features. The timestamp field is explicitly set by the client to ensure accurate session replay and funnel analysis, as server-side receipt times introduce network latency variance.
3. Implementing Client-Side Event Tracking Logic
Tracking logic must be attached to DOM events, route changes, or business logic hooks. The SDK is designed to handle high-frequency interactions, but unoptimized event listeners will trigger browser throttling and degrade page performance. You must implement debouncing, intersection observers, and state management to ensure only meaningful interactions generate events.
// Throttled scroll depth tracking using IntersectionObserver
const trackScrollDepth = (() => {
  let lastTrackedDepth = 0;
  const thresholds = [0.25, 0.5, 0.75, 1.0];
  return new IntersectionObserver((entries) => {
    entries.forEach((entry) => {
      const depth = thresholds.indexOf(entry.target.dataset.threshold) + 1;
      if (depth > lastTrackedDepth && entry.isIntersecting) {
        lastTrackedDepth = depth;
        peClient.trackEvent('scroll_depth_reached', {
          depth_percentage: depth * 25,
          page_url: window.location.pathname,
          viewport_height: window.innerHeight
  }, { threshold: thresholds });
// Attach to bottom anchor elements
document.querySelectorAll('.scroll-marker').forEach(marker => trackScrollDepth.observe(marker));
The Trap: Attaching event listeners to click, mousemove, or scroll without debouncing or state guards. The browser fires these events dozens of times per second. When each event triggers a trackEvent call, the SDK queue fills rapidly, memory consumption spikes, and the main thread blocks during batch serialization. Genesys Cloud enforces a per-session rate limit on the ingestion endpoint. Exceeding this limit triggers HTTP 429 responses, causing the SDK to drop subsequent events until the window resets. This creates blind spots in user journey mapping and breaks predictive engagement scoring continuity.
Architectural Reasoning: We use IntersectionObserver for viewport-based tracking because it runs on a separate browser thread and does not block the main execution context. We implement state guards (lastTrackedDepth) to prevent duplicate event firing for the same logical milestone. For click tracking, we attach listeners to parent containers and use event delegation rather than binding to individual elements. This reduces memory footprint and ensures that dynamically rendered components (like infinite scroll feeds) are tracked without re-binding. The SDK internally batches events and flushes them during idle periods or before page unload. You must register a beforeunload handler to force a final flush, otherwise in-flight events are lost when the user navigates away.
window.addEventListener('beforeunload', () => {
  peClient.flushQueue(); // Synchronous flush attempt before navigation
4. Routing Events to Predictive Engagement Rules & Journey Builder
Once events reach the Genesys Cloud platform, they are evaluated against Predictive Engagement rules and Journey Builder flows. The routing architecture relies on trigger matching, audience segmentation, and priority weighting. Misaligned trigger conditions or overlapping rules cause race conditions that manifest as multiple pop-ups, conflicting callbacks, or suppressed engagement.
In Journey Builder, you map the custom event name to a trigger node. The trigger evaluates the payload keys against defined conditions. You must configure rule precedence and mutual exclusion flags to ensure deterministic behavior.
  "trigger": {
    "type": "web_event",
    "event_name": "product_detail_viewed",
    "conditions": [
      { "field": "category", "operator": "equals", "value": "electronics" },
      { "field": "user_segment", "operator": "equals", "value": "returning_visitor" },
      { "field": "price", "operator": "greater_than", "value": 100 }
  "actions": [
      "type": "predictive_popup",
      "variant": "premium_support_offer",
      "priority": 1,
      "cooldown_seconds": 300
The Trap: Creating multiple triggers that evaluate the same event without explicit priority weighting or cooldown periods. When a user triggers product_detail_viewed twice in rapid succession, both rules evaluate as true simultaneously. The Predictive Engagement engine fires both pop-up variants, causing UI overlap, conflicting CTAs, and a degraded user experience. Additionally, without cooldown configuration, the system continues to evaluate the same user against the same rule on every subsequent event, leading to engagement fatigue and inflated conversion metrics.
Architectural Reasoning: We assign explicit priority values to every trigger and enable mutual exclusion at the campaign level. The SDK respects the cooldown_seconds parameter by maintaining a client-side state flag that suppresses redundant rule evaluations. We structure Journey Builder flows to branch based on payload values rather than duplicating triggers. This centralizes logic, reduces maintenance overhead, and ensures that rule evaluation scales linearly with event volume. We also configure fallback actions for events that fail to match any trigger, routing them to a default analytics bucket for later analysis. This prevents silent drops and provides visibility into tracking coverage gaps.
Edge Case 1: Event Payload Size Limits & Truncation
The failure condition: The SDK logs a warning indicating payload rejection, and Journey Builder triggers fail to fire despite the event name matching.
The root cause: Genesys Cloud enforces a strict payload size limit of 8KB per event. When client-side code attaches large strings, base64 encoded images, or verbose debug objects, the payload exceeds this threshold. The ingestion pipeline truncates the data or drops the event entirely to protect backend storage and indexing performance.
The solution: Implement a payload sanitizer that strips non-essential fields before transmission. Use reference IDs instead of embedding full records. For example, transmit order_id: 'ORD-9921' rather than the complete order object. Configure the SDK to log truncated payloads to a local error tracker for audit purposes. Validate payload size in staging using the Genesys Cloud Event Simulator before deploying to production.
Edge Case 2: Cross-Domain Tracking & Cookie Partitioning
The failure condition: User sessions reset when navigating between subdomains or third-party embedded content, causing Predictive Engagement rules to evaluate against cold session data.
The root cause: Modern browsers enforce SameSite cookie policies and partition storage based on top-level site origins. When the Predictive Engagement SDK sets session identifiers, cross-domain navigation isolates the storage context. The SDK cannot read the previous session token, resulting in a new session initialization and loss of event continuity.
The solution: Configure the SDK to use URL parameter passing for session handoff between trusted domains. Append ?pe_session={token} to cross-domain links and parse it on page load to restore the session context. For third-party iframes, implement postMessage communication to relay events to the parent domain before tracking. Ensure all domains share the same CSP configuration and that the SDK initialization script includes the crossDomainTracking: true flag. This maintains session continuity without violating browser privacy constraints.
Edge Case 3: SDK Load Failure & Graceful Degradation
The failure condition: The Predictive Engagement script fails to load due to CDN outage, CSP restriction, or ad blocker interference. No events are tracked, and engagement rules never evaluate.
The root cause: The SDK is loaded synchronously or without fallback handling. When the script tag encounters a 403 or network timeout, the JavaScript execution context halts. Subsequent calls to peClient.trackEvent throw reference errors because the client object was never instantiated.
The solution: Implement a wrapper that checks for SDK availability before firing events. Use dynamic script loading with timeout fallbacks. Queue events in localStorage when the SDK is unavailable, and replay them once connectivity is restored. Configure CSP to explicitly allow https://*.genesys.cloud and https://*.mypurecloud.com endpoints. Monitor SDK load success rates via a lightweight health check beacon that operates independently of the Predictive Engagement pipeline. This ensures tracking resilience during network instability or CDN degradation.
