Tracing NICE CXone SIP Signaling Messages with Voice API and Lua
A diagnostic tracing pipeline that captures SIP signaling messages, validates trace payloads against signaling engine constraints, intercepts messages via atomic registration, applies privacy masking, synchronizes with external packet analyzers via webhooks, tracks capture latency and success rates, and generates audit logs for network governance. This tutorial uses the CXone Diagnostic API, CXone Voice API Lua runtime, and Python orchestration.
- OAuth 2.0 Client Credentials grant configured in CXone
- Required scopes:
diagnostics:write,diagnostics:read,voiceapi:write,voiceapi:read - CXone API version: v2
- Python 3.9+ with
httpx,pydantic,typing - CXone Voice API Lua environment (Studio/Flow execution context)
- External webhook endpoint capable of receiving JSON payloads
CXone uses standard OAuth 2.0 client credentials. The following Python code retrieves an access token and caches it for reuse. The token expires after 3600 seconds.
import httpx
import json
from typing import Optional
class CxoneAuth:
def __init__(self, client_id: str, client_secret: str, org_id: str):
self.client_id = client_id
self.org_id = org_id
self.token_url = f"https://api.mypurecloud.com/oauth/token"
def get_token(self) -> str:
if self.access_token and time.time() < self.token_expiry:
return self.access_token
payload = {
"client_id": self.client_id,
with httpx.Client() as client:
response = client.post(
self.token_url,
data=payload,
headers={"Content-Type": "application/x-www-form-urlencoded"}
response.raise_for_status()
data = response.json()
self.access_token = data["access_token"]
self.token_expiry = time.time() + data["expires_in"] - 30
"Authorization": f"Bearer {self.get_token()}",
"Accept": "application/json"
Step 1: Construct and Validate Trace Payloads
The CXone signaling engine enforces strict schema constraints. Maximum capture duration defaults to 300 seconds. You must construct a trace payload containing signaling references, a message matrix, and a capture directive. The following code validates the payload against engine limits before submission.
import httpx
import json
from typing import Dict, Any
class SipTraceManager:
def __init__(self, auth: CxoneAuth):
self.auth = auth
self.base_url = "https://api.mypurecloud.com/api/v2/diagnostics"
def validate_trace_payload(self, payload: Dict[str, Any]) -> Dict[str, Any]:
max_duration = payload.get("maxDurationSeconds", 0)
if max_duration > 300 or max_duration <= 0:
raise ValueError("maxDurationSeconds must be between 1 and 300")
capture_directive = payload.get("captureDirective", {})
if capture_directive.get("protocol") != "SIP":
raise ValueError("captureDirective.protocol must be SIP")
message_matrix = payload.get("messageMatrix", [])
required_methods = {"INVITE", "ACK", "BYE", "CANCEL", "REGISTER"}
if not required_methods.issubset(set(message_matrix)):
raise ValueError("messageMatrix must contain core SIP methods")
return payload
def create_trace(self, payload: Dict[str, Any]) -> Dict[str, Any]:
validated_payload = self.validate_trace_payload(payload)
headers = self.auth.get_headers()
f"{self.base_url}/traces",
json=validated_payload,
headers=headers
retry_after = int(response.headers.get("Retry-After", 2))
time.sleep(retry_after)
headers=headers
return response.json()
Expected Request:
POST /api/v2/diagnostics/traces
"name": "sip-diagnostic-trace-01",
"traceType": "SIGNALING",
"maxDurationSeconds": 180,
"captureDirective": {
"protocol": "SIP",
"direction": "BOTH",
"includeHeaders": ["Via", "From", "To", "Call-ID", "CSeq", "Contact"]
"messageMatrix": ["INVITE", "ACK", "BYE", "CANCEL", "REGISTER", "100", "180", "200", "4xx", "5xx"],
"filterExpression": "call_direction == 'outbound' AND sip_domain == 'cxone.com'"
Expected Response:
HTTP/1.1 201 Created
"id": "trace-8f7a2b1c-9d3e-4f5a-b6c7-8d9e0f1a2b3c",
"status": "ACTIVE",
"createdTimestamp": "2024-06-15T10:30:00Z",
"protocol": "SIP",
"direction": "BOTH"
Step 2: Atomic Registration and Message Interception
Trace sessions require atomic registration to prevent race conditions during high concurrency. The Lua script below runs inside the CXone Voice API execution context. It registers the trace handler, verifies message format, and applies automatic filter triggers.
-- CXone Voice API Lua Trace Handler
local trace_id = "trace-8f7a2b1c-9d3e-4f5a-b6c7-8d9e0f1a2b3c"
local registered = false
function register_trace_handler()
if registered then
return true
end
local success, err = cxone.diagnostics.register_trace(
trace_id,
atomic = true,
format_verification = true,
filter_triggers = {
method_filter = {"INVITE", "BYE", "CANCEL"},
status_filter = {"487", "503", "603"}
if not success then
cxone.logger.error("Trace registration failed: " .. tostring(err))
return false
end
registered = true
return true
end
function on_sip_message(message)
if not register_trace_handler() then
return
end
if not verify_sip_format(message) then
cxone.logger.warn("Invalid SIP format detected, skipping message")
return
end
apply_filter_triggers(message)
cxone.diagnostics.push_trace_event(message)
end
function verify_sip_format(msg)
return msg.method ~= nil and msg.headers["Via"] ~= nil and msg.headers["Call-ID"] ~= nil
end
function apply_filter_triggers(msg)
if msg.method == "BYE" and msg.call_duration > 300 then
cxone.diagnostics.flag_event("LONG_CALL_BYE", msg)
end
end
Step 3: Privacy Masking and Sequence Verification
Diagnostic accuracy requires sequence number verification and privacy masking to prevent sensitive data leakage. The following Python code processes captured trace sessions, validates SIP CSeq progression, and masks PII fields.
import httpx
import json
import re
from typing import List, Dict, Any, Optional
class TraceProcessor:
def __init__(self, auth: CxoneAuth, trace_id: str):
self.auth = auth
self.trace_id = trace_id
def fetch_trace_sessions(self) -> List[Dict[str, Any]]:
sessions = []
cursor = None
while True:
params = {"traceId": self.trace_id, "pageSize": 100}
if cursor:
params["cursor"] = cursor
response = client.get(
f"{self.base_url}/trace-sessions",
params=params,
headers=headers
sessions.extend(data.get("entities", []))
cursor = data.get("nextPageCursor")
if not cursor:
break
return sessions
def mask_sensitive_data(self, message: Dict[str, Any]) -> Dict[str, Any]:
masked = message.copy()
headers = masked.get("headers", {})
for key in ["From", "To", "Contact", "P-Asserted-Identity"]:
if key in headers:
headers[key] = re.sub(r"[a-zA-Z0-9._%+-]+@[a-zA-Z0-9.-]+\.[a-zA-Z]{2,}", "***MASKED***", headers[key])
headers[key] = re.sub(r"sip:[^;]+", "sip:***MASKED***", headers[key])
masked["headers"] = headers
return masked
def verify_sequence_numbers(self, sessions: List[Dict[str, Any]]) -> Dict[str, Any]:
call_ids = {}
violations = []
for session in sessions:
call_id = session.get("callId")
cseq = session.get("cseq")
method = session.get("method")
if call_id not in call_ids:
call_ids[call_id] = {"last_cseq": cseq, "methods": []}
expected = call_ids[call_id]["last_cseq"] + 1 if method not in ["ACK"] else expected
if cseq != expected and method != "ACK":
violations.append({
"callId": call_id,
"expectedCSeq": expected,
"actualCSeq": cseq,
"method": method
call_ids[call_id]["last_cseq"] = cseq
call_ids[call_id]["methods"].append(method)
return {"callIds": call_ids, "violations": violations}
def process_trace(self) -> Dict[str, Any]:
sessions = self.fetch_trace_sessions()
masked_sessions = [self.mask_sensitive_data(s) for s in sessions]
seq_report = self.verify_sequence_numbers(masked_sessions)
"totalSessions": len(sessions),
"maskedSessions": masked_sessions,
"sequenceVerification": seq_report,
"privacyCompliant": True
Step 4: Webhook Synchronization and Metric Tracking
Synchronize tracing events with external packet analyzers via webhooks. Track latency, capture success rates, and generate audit logs for network governance.
import httpx
from datetime import datetime
class TraceMetricsAndWebhook:
def __init__(self, auth: CxoneAuth, webhook_url: str):
self.auth = auth
self.metrics = {
"total_events": 0,
"successful_captures": 0,
"failed_captures": 0,
"latencies_ms": [],
"audit_log": []
def sync_with_external_analyzer(self, event: Dict[str, Any]) -> Dict[str, Any]:
start_time = time.time()
payload = {
"source": "cxone_sip_tracer",
"timestamp": datetime.utcnow().isoformat() + "Z",
"event": event,
"traceId": event.get("traceId"),
"callId": event.get("callId")
with httpx.Client(timeout=10.0) as client:
self.webhook_url,
json=payload,
headers={"Content-Type": "application/json"}
self.metrics["latencies_ms"].append(latency_ms)
self.metrics["total_events"] += 1
if response.status_code in [200, 201, 202]:
self.metrics["successful_captures"] += 1
status = "SYNCED"
else:
self.metrics["failed_captures"] += 1
status = "FAILED"
audit_entry = {
"callId": event.get("callId"),
"status": status,
"latencyMs": round(latency_ms, 2),
"webhookStatusCode": response.status_code
self.metrics["audit_log"].append(audit_entry)
"status": status,
"auditEntry": audit_entry
def get_capture_report(self) -> Dict[str, Any]:
total = self.metrics["total_events"]
success = self.metrics["successful_captures"]
latency_avg = sum(self.metrics["latencies_ms"]) / len(self.metrics["latencies_ms"]) if self.metrics["latencies_ms"] else 0
"captureSuccessRate": round((success / total) * 100, 2) if total > 0 else 0,
"averageLatencyMs": round(latency_avg, 2),
"totalEvents": total,
"successfulCaptures": success,
"failedCaptures": self.metrics["failed_captures"],
"auditLog": self.metrics["audit_log"]
The following script combines authentication, trace creation, session processing, and metric tracking into a single executable module. Replace CLIENT_ID, CLIENT_SECRET, ORG_ID, and WEBHOOK_URL with your values.
import httpx
import json
# Import classes from previous sections
# from auth_module import CxoneAuth
# from trace_module import SipTraceManager, TraceProcessor
# from metrics_module import TraceMetricsAndWebhook
def run_sip_tracer():
auth = CxoneAuth(
client_id="YOUR_CLIENT_ID",
client_secret="YOUR_CLIENT_SECRET",
org_id="YOUR_ORG_ID"
trace_manager = SipTraceManager(auth)
webhook_sync = TraceMetricsAndWebhook(auth, webhook_url="https://your-analyzer.example.com/webhook/sip")
trace_payload = {
"protocol": "SIP",
"messageMatrix": ["INVITE", "ACK", "BYE", "CANCEL", "REGISTER", "100", "180", "200"],
"filterExpression": "call_direction == 'outbound'"
trace_response = trace_manager.create_trace(trace_payload)
trace_id = trace_response["id"]
print(f"Trace created: {trace_id}")
processor = TraceProcessor(auth, trace_id)
processed = processor.process_trace()
for session in processed["maskedSessions"]:
sync_result = webhook_sync.sync_with_external_analyzer(session)
print(f"Synced {session.get('callId')}: {sync_result['status']}")
report = webhook_sync.get_capture_report()
print(json.dumps(report, indent=2))
print(f"HTTP Error: {e.response.status_code} - {e.response.text}")
except ValueError as e:
print(f"Validation Error: {e}")
print(f"Unexpected Error: {e}")
run_sip_tracer()
Error: 400 Bad Request - Schema or Duration Constraint Violation
Cause: The maxDurationSeconds exceeds 300, the messageMatrix lacks required SIP methods, or the captureDirective.protocol is invalid.
Fix: Validate the payload against the engine constraints before submission. Use the validate_trace_payload method to enforce limits.
trace_manager.create_trace(payload)
print(f"Payload validation failed: {e}")
Cause: Missing or expired OAuth token, or insufficient scopes (diagnostics:write, diagnostics:read).
Fix: Ensure the OAuth client credentials are correct and the token is refreshed before each request. Verify scope assignments in the CXone admin console.
headers = auth.get_headers()
# Headers will automatically refresh if expired
Cause: Rate limiting triggered by rapid trace creation or session polling.
Fix: Implement exponential backoff. The create_trace method already handles a single retry using the Retry-After header. For polling loops, add a delay between requests.
time.sleep(2) # Respect rate limits during pagination
Error: 500 Internal Server Error - Signaling Engine Overload
Cause: The CXone signaling engine cannot allocate trace resources due to high concurrency or scaling events.
Fix: Reduce maxDurationSeconds, decrease the number of active traces, or implement a queue-based retry mechanism. Monitor trace status via /api/v2/diagnostics/traces/{traceId} before processing sessions.
